Super Charger Questions
Discussion in '1st Gen. Tacomas (1995-2004)' started by veg hed, Jan 27, 2015.
  1. Jan 27, 2015 at 10:44 AM
    veg hed
    veg hed [OP] Well-Known Member
    Utah
    04 Toyota TRD SR5 V6 Access Cab
    Bilstein 5100s, Toytec 620 springs, OME Dakar Leafs, ARB Bumper, Warn 8000 Winch, Grey Wire Mod.
    I know this has probably been covered on here somewhere but I have been reading about S/Cs for a while and haven't seen the answer. So my questions are;
    1) Do I always have to use premium gas if I get a S/C? What happens if I don't?
    2) What is the advantage of the URD 7th injector kit? If I have this kit will I always have to use Higher Octane gas.
    3) How hard is it to install a S/C?
    I really want a S/C but around here 91+ Octane gas is around .40 cents higher per gallon.
  2. Jan 27, 2015 at 11:29 AM
    ian5538
    ian5538 Member
    ian
    San Jose
    07 PreRunner
    American Thunder exhaust system
    x2
  3. Jan 27, 2015 at 11:31 AM
    tomtom
    tomtom Well-Known Member
    The Desert SW
    2012 FJ
    You really should run premium. The actual octane will vary by altitude. I run 91 but I live at 5800 ft. Premium is something like 93 or above at sea level. If you don't run a high enough octane you'll get pre-detonation, leading to knocking and pinging and premature engine death.
    The injector kit keeps you from going lean which can create too much heat and melt the piston heads. It also allows you to adjust the timing, putting in more spark retardation than the stock ECM allows.
    Can easily be done in a day, even with the 7th.
    You've got to pay to play.
    There are reports of guys living at high altitudes (Denver, Albuquerque, etc.) that run without the 7th just fine. However, last time I was at the dealership, got to talking to the parts guys about S/Cs and one mentioned they've done many installs without the 7th and the lean code kicks on after a couple days.
    To me, the possibility of grenading my engine isn't worth trying to save $900.
  4. Jan 27, 2015 at 12:24 PM
    Mikeybuck
    Mikeybuck Well-Known Member
    SW WA
    2018, 2010, Tacoma
    Who has the best price/kit?
  5. Jan 27, 2015 at 12:36 PM
    tomtom
    The Desert SW
    2012 FJ
    lowest price I found on the S/C unit was through trdparts4U, $2600 + free shipping.
    URD offers the 7th, runs about $900. You'll want to get the 170 degree t-stat as well.
    I could not find the TRD 7th anywhere. I don't think it is available from Toyota anymore. No idea who might have it sitting on a shelf.
  6. Jan 27, 2015 at 12:44 PM
    Roman
    Roman Member
    Roman
    Franklin, TN
    I can order one and have it in a day or so. The supercharger price has gone up recently, but it can still be had for about $2700.
  7. Jan 27, 2015 at 12:55 PM
    SCRunner12
    SCRunner12 Tundra Troll
    Robert
    Santa Cruz, CA
    2006 Tundra DC, TRD, 4wd
    As stated above always run premium. It's really only about $3-4 per fill up difference, so pretty negligible IMO. Definitely worth it for me.
    In regards to the install it's really not that hard. I did it in a few hours the first time and with no engine maintenance experience prior.
  8. Jan 27, 2015 at 4:40 PM
    SpoilsofWar
    SpoilsofWar Well-Known Member
    Wilmington NC
    2014 DCLB 4x4 TRD Sport Super Charged
    Come drive mine...I'm 2 hours away...you will be hooked. I might be in Boone on Feb 2nd if you want to get up.
  9. Jan 27, 2015 at 5:15 PM
    SCRunner12
    Robert
    Santa Cruz, CA
    He will, then he will get in his 1st gen and cry because even with a chargers it's slower than a 2nd gen stock....haha
  10. Jan 27, 2015 at 5:27 PM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    :p
  11. Jan 27, 2015 at 6:00 PM
    hurley842002
    hurley842002 Well-Known Member
    Dan
    Thornton, Colorado
    02 SR5 TRD
    Bone stock (for now)
    Wish I was close by! Anyone in the Denver area with a 1st gen SC, preferably auto tranny lol.
  12. Jan 27, 2015 at 6:06 PM
    TashcomerTexas
    TashcomerTexas My truck is a whiner
    2003 TRD DC Supracharged
    Any tips or anything I need to take note on? I'm probably gonna put mine up myself. Save the $
  13. Jan 27, 2015 at 6:25 PM
    tomtom
    The Desert SW
    2012 FJ
    with the ETCS and no EGR, it is fairly straight forward.
    You'll have to transplant the throttle body studs from the intake plenum over to the S/C unit.
    There is a vacuum port on the backside near the throttle body that a few of us forgot to cap.
    The instructions in mine were a bit outdated. If you do have the ETCS, pay attention to the instructions for the later year 4 Runners.
    Also, the plenum gasket was in good enough shape to re-use but I ordered another one just in case. Part # 17176-62040
  14. Jan 27, 2015 at 6:39 PM
    Madjik_Man
    Colorado Front Range
    So it's true... if you say "S/C" three times TomTom appears.
    :eek:
  15. Jan 27, 2015 at 6:53 PM
    tomtom
    The Desert SW
    2012 FJ
    you forgot the whole "while looking in a mirror" part.
  16. Jan 27, 2015 at 9:51 PM
    SCRunner12
    Robert
    Santa Cruz, CA
    Depends on what version you have. Overall it's very simple and pretty straightforward. With a 1st gen, just be careful putting on two nuts that hold down the SC. Other than that just follow the instructions and enjoy the boost!
  17. Jan 27, 2015 at 10:26 PM
    DSMJRV
    DSMJRV Well-Known Member
    justin
    Corona, CA
    where did u year that?
  18. Jan 27, 2015 at 10:42 PM
    SCRunner12
    Robert
    Santa Cruz, CA
    Personal experience. I don't have my 7th set up yet but my parents 4th gen v6 (2003) would spank my SC'd 2000.
  19. Jan 27, 2015 at 11:26 PM
    DSMJRV
    justin
    Corona, CA
    ah are you running 33 MTs? but yeah no fuel mods would make it close..
    in my experience head to head in dirt and sand its a spanking but i have fuel mods :/ never raced one on the street, my buddies wont do it and for good reason, the ticked would suck...
  20. Jan 28, 2015 at 7:41 AM
    tomtom
    The Desert SW
    2012 FJ
    You may really want to consider getting the 7th. Stock ECM doesn't provide enough timing retard and stock fuel pump is marginal in supply. Running lean + early spark = bad things.
    Also, if you haven't regeared for bigger tires, it isn't a fair comparison.
    I've had no issue keeping up with 2nd Gen Tacomas.
