Super Charger Removal
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tacoboy66, Nov 13, 2024.
  1. Nov 13, 2024 at 7:06 AM
    tacoboy66
    tacoboy66 [OP] Member
    Hello. I'm a second owner of 2014 Tacoma Sport with a super charged (200,000kms) installed when new at the dealer. It's still working great but it causes a lot more work when work needs to be done like replace spark plugs and altenator I recently replaced. I have all orginal parts and would like it removed. Does anyone know how many hours to switch it back? I can't get a time from two dealerships I've been talking to. Me and a mechanic I have want to know the hours so I have an idea what to pay.
  2. Nov 13, 2024 at 7:14 AM
    ThePositiveWay
    ThePositiveWay Well-Known Member
    SE Tennessee
    06' DCLB TRD Sport Super White
    Sony XAV-9000ES Headunit, Steering Wheel Controls, Sony ES Series Door Speakers, Alpine PWE-S8 Sub
    Here is Magnuson's page on a 1GR supercharger, I've read that it's basically the same minus TRD branding. They don't list a specific number of hours but say that "a pro can do it in about a day, an enthusiast can in a weekend". Call it 12 hours for a mechanic if you have all the stock parts? What's your plan for it when it's out of the truck?
  3. Nov 13, 2024 at 7:21 AM
    Calamity_taco
    Calamity_taco your friendly neighborhood weeb :3
    Jacob
    I have no idea. send help!
    2017 f-150, 23 Klx300R
    just a couple of things tbh
    you are going to miss the power of that....
  4. Nov 13, 2024 at 7:23 AM
    prise
    prise AZ's Toaster Strudel Low T Andrew
    Prise
    Rally Runner 04 GX470
    Where are you at? We can do it in a weekend easy
  5. Nov 13, 2024 at 7:29 AM
    tacoboy66
    I'm in Nova Scotia, Canada
    Slashaar likes this.
  6. Nov 13, 2024 at 7:54 AM
    Slashaar
    Slashaar Trail Limo Supreme & Certified Hole Massager
    Josh
    Kansas City, MO
    2015 Tacoma TRD-Sport DC LB
    Coastal HC Front, 6112s+650lb King Coils, JD 62 Swap + 14" Fox 2.0s
    Everyone on their way to Canada right now: :burnrubber:
  7. Nov 15, 2024 at 1:20 PM
    TegoTaco
    TegoTaco Well-Known Member
    Ontario, Canada
    ‘13 SUPERCHARGED DCLB TRD SPORT
    Whereabouts are you located??
  8. Nov 15, 2024 at 1:22 PM
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    He listed his location two posts up.
    TegoTaco[QUOTED] likes this.
  9. Nov 15, 2024 at 1:24 PM
    TegoTaco
    Ontario, Canada
    read first post and got excited about it lol!
    :anonymous:
    vssman[QUOTED] likes this.
  10. Nov 18, 2024 at 5:10 AM
    Slashaar
    Josh
    Kansas City, MO
    There I fixed it for you.
  11. Nov 18, 2024 at 11:53 AM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    I had @DOUBLLD install, and then remove my SC a year later (and install it on another truck). Both times he had both trucks running in about 4 hours. He is very good at his craft. If you were to do it yourself, Id guess at least 8+ hours, depending on how mechanically inclined you are.
    I also paid about $1500 usd, and pre-covid prices.
    DOUBLLD likes this.
  12. Nov 18, 2024 at 12:21 PM
    Sterling_vH111
    Sterling_vH111 Go do something real instead.
    Sterling
    socal
    2012 DCLB Prerunner V6
    Secretly Long Travel & Supercharged
    Experience installer, about 4-6hrs
    Experienced mechanic, probably about 8-10hrs
    Home driveway, no experience, about 12–16hrs
    also OP, you’ve got to think about all the small parts that are ditched from the stock setup:
    Idle pulley bolts, crank pulley, ECU tuning, injectors, lower radiator hose, intake manifold support brackests… etc
    (Are you sure the previous owner passed them all along? Or that you’ve got all the parts 100% correct?)
    if you are really only doing this because it’s a hassle to change plugs, doing this swap without any issues will be much more of a pain.
    Put some iridium or ruthenium plugs in there and let it be for 100k miles…
    Check out this thread.
    https://www.tacomaworld.com/threads/trd-magnuson-4-0-supercharger-tips-tricks-and-mods.518932/
    Slashaar and shmn like this.
  13. Nov 18, 2024 at 12:41 PM
    prise
    Prise
    Bring it down to Arizona and snowbird for the winter, then drive it back home after we switch everything out :)
  14. Nov 23, 2024 at 6:16 AM
    tacoboy66
    Yes I like having the SC of course and it was onlty the pain when/if certain work needs to be done and the truck is 10 yrs old. You are right it is a big hassle to remove it anf I'm not positive if I have all the orignal parts. I really do like having it so I decided to work with it. Thanks for all the information.
  15. Nov 23, 2024 at 8:19 AM
    Sterling_vH111
    Sterling
    socal
    I do get it!
    It makes some of the usually maintenance a bit more complicated, and even things like swapping in a new front a/c condenser was a bit more annoying.
    I’d you haven’t, I’d check out the supercharger thread I linked above.
    Tons of good info on maintenance, tips and tricks, & of course getting more power if you wish !
