super glue on paint
Discussion in 'Detailing' started by superwhite10, Jan 24, 2011.
  1. Jan 24, 2011 at 8:50 PM
    superwhite10
    superwhite10 [OP] Well-Known Member
    Garner, NC
    I hope this is in the right section, I figured some detailing guys would know the answer.
    I am actually asking for my cousin who painted his emblems black after I gave him the idea. I guess he did not listen to my directions on how to do it and now the paint is chipping off him emblems. I told him to just take them off and fix/repaint them, long story short turns out he super glued them back on his car. does anyone know a way to remove them and the excess glue left behind? would the glue have damaged the paint? thanks in advance!
  2. Jan 24, 2011 at 8:59 PM
    topgun155
    topgun155 Well-Known Member
    Zack
    Richmond, TX or College Station, TX
    08 Prerunner V6 Black
    Viper Alarm, In Pro Car Wear L.E.D. Tail Lights, Fog Lights, ScanGuageII, AvidOffroad Light Bar, Ammo Box Mod, Tailgate Theft Prevention Mod, Satoshi Grill, Hella 500ff behind the grill, blendmount, Cruise Control Mod, Fog Light Mod, 5100's @1.75, Toytec TSB AAL 1.5".
    Googone might work not sure if its made for super glue. Next I would try some gas. Then worst case some nail polish remover. But the last two might not be to healthy for the paint. Tell him to wax the area around it very well.
  3. Jan 24, 2011 at 9:05 PM
    t-frax
    t-frax Well-Known Member
    Cali
    08 PreRUNNER TRD Sports Pkg, Black
    Pop&Lock, Bakflip, spare tire lock, folding hitch step, alarm, n-fab steps, more to come hopefully
    nail polish remover will just take the paint off with it. there is Super Glue remover they sell at any walmart or craft store...not sure how safe it is on paint though.
  4. Jan 24, 2011 at 9:07 PM
    superwhite10
    Garner, NC
    yeah I have thought about the 3 options topgun said. but like yall said, I'm afraid theyll strip the paint as well.:notsure:
  5. Jan 24, 2011 at 9:19 PM
    topgun155
    Zack
    He could try and plastidip it. I'm not sure of the specifics, but it wipes off the paint.
  6. Jan 24, 2011 at 9:30 PM
    superwhite10
    Garner, NC
    ive googled how to remove super glue but i get nothing but mixed results. im off wednesday so we are going to try to figure somthing out. pay just tape the edges and touch up the bad spots if we cant find a solution to remove them 100% with no damage
  7. Jan 24, 2011 at 9:41 PM
    donovan6241
    donovan6241 Well-Known Member
    Donovan
    San Diego
    2017 TRD Sport Double Cab Long Bed
    try wd-40
  8. Jan 25, 2011 at 5:38 AM
    superwhite10
    Garner, NC
    morning bump, need some ideas if any
  9. Jan 25, 2011 at 6:31 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    This happened to me (In a round about way), and I used nail polish remover. It didnt affect the paint. This was on a white vehicle though, so a clear coated vehicle may need to be buffed out afterwards.
  10. Jan 25, 2011 at 10:28 AM
    Dadic 78
    Dadic 78 Well-Known Member
    Fil
    Edmonton, AB CANADA
    08 Double cab TRD
    That's a tough one man... I'd say try acetone, or paint thinners. If it doesn't start taking the glue off immediately, don't persist with it, as thinners can eventually soften, and eat through your clear.
    If thinners doesn't work, I would sand it out. If you get a piece of 1000 grit paper on a HARD BLOCK, and very gently sand the glue off. You'll have to polish the area afterwards, but sand with 1500, then 2500 or 3000 and you can polish it up by hand with a mild polish.
    That's the best advice I could give you man. Unless you just "half-assed" it, and once you remove the badges, use a silicone-based adhesive to re-adhere the badges to the doors, and just glue it right on top of the old glue.
    Good luck!
  11. Jan 25, 2011 at 11:37 AM
    superwhite10
    Garner, NC
    I guess a big issue would be how to remove an object (ie. The emblems) from the car first, then worry about what it left or didn't leave (if it takes the paint too). Seems like everyone says somthing different. One person says use fingernail polish removed another person says don't use it. May do some experimenting in an area not visible first. But for now im going to help him just tape off around the chips and spray back over where the chips are.
  12. Jan 25, 2011 at 5:10 PM
    Dadic 78
    Fil
    Edmonton, AB CANADA
    08 Double cab TRD
    Not sure what to recommend for removing the badges... Never tried to remove crazy-glued badges before, and working in a body shop, if we screw up a badge removal, it's OK because we're painting that panel anyway.
    If you must remove them, I'd take masking tape, and mask off AROUND the emblem. The purpose of the tape is to protect your paint, so put it on 2 pieces thick. You can get an emblem remover from a bodyshop supply store, it's really just a metal, or plastic trowel. Plastic will likely break from the strength of the crazy glue, so try a metal one, and GENTLY pry it underneath the emblem, and try and work it off. Be very careful not to dent the panel, or to scratch the paint.
    If you're not comfortable with this, I'd say just remove the paint off the emblems (since it's flaking off already) and leave them be. Chalk it up to a lesson learned...
  13. Jan 26, 2011 at 12:03 AM
    superwhite10
    Garner, NC
    thanks for the info guys! going to a body shop tomorrow that a family friend owns to drop off my satoshi grill to be painted and going to ask him what he thinks about it
  14. Feb 6, 2013 at 9:12 PM
    drewskie
    drewskie Well-Known Member
    Drew
    Burbank, CA.
    08 Prerunner 4 banger
    I'm gonna bump this thread up. I got crazy glue on my two day old painted plastic flares. It's not much, but it looks really bad on the new finish. Is there any way to take this off without ruining the paint? I am going to take it back the body shop to see what he says, but I am wondering if you guys have any tips.
  15. Feb 6, 2013 at 9:16 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Anything that'll remove the super glue will melt the plastic flares.
    Only thing you can do is carefully sand the superglue down as flush as you can without marring the paint with 600 or finer wet-or-dry sandpaper, then move to rubbing and polishing compounds to gloss it back up.
  16. Feb 6, 2013 at 9:19 PM
    drewskie
    Drew
    Burbank, CA.
    Thanks for the super quick response. I was afraid of that. The body shop has to do some sanding on the clear coat drips, so should they be able to sand the glued part down as well?
  17. Feb 6, 2013 at 9:28 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    Oh ya... if they're still working the paint, they could handle it.
    I didn't realize the PAINT was new... thought just the flares.
    Ya... try to pop that off and the paint will come with it.
    But super glue can be polished out very nicely. I know a lot of guys that use super glue to put a waterproof high-gloss finish on straight razor and shaving brush handles.
