Super squeaky front suspension. HELP!!!!
Discussion in '1st Gen. Tacomas (1995-2004)' started by bodhi armor, Apr 12, 2022.
  1. Apr 12, 2022 at 12:41 PM
    bodhi armor
    bodhi armor [OP] 02’ Dbl Cab- "The Luck Dragon"
    Joshua
    East TX
    2002 4x4 Dbl Cab Jade Green
    Holy hell!!
    Just like the Pirate who put a steering wheel in his pants, THIS IS DRIVING ME NUTS!!
    My 02’ 4wd has King coilovers & Camburg upper control arms.
    I replaced the 1” uniball joints about 6 months ago. Since then there has been a squeak devolving in my front suspension that has gotten very loud! As of 2 days ago it now squeals like Ned Beaty in “Deliverance” when I turn the wheel either direction.
    Few things annoy me more than noisy racket coming from my truck! I’ve spent a lot of money making this truck awesome, but this makes it sound like rolling scrap.
    If anyone has an idea of what the problem may be please help a brother out!
    As always, THANK YOU!
    Wulf likes this.
  2. Apr 12, 2022 at 12:44 PM
    knayrb
    knayrb Well-Known Member
    Bryan
    Somewhere in the square states
    2010 Dbl-Cab Off-Road
    Pure stock
  3. Apr 12, 2022 at 1:28 PM
    Toyoda213
    Toyoda213 Well-Known Member
    Jimmy
    SoCal
    2003 V6 dlbc Prerunner 4x4 converted
    maybe power steering belt squeaking???
  4. Apr 13, 2022 at 4:00 PM
    bodhi armor
    Joshua
    East TX
  5. Apr 13, 2022 at 4:00 PM
    bodhi armor
    Joshua
    East TX
    Yeah that’s possible
  6. Apr 13, 2022 at 9:41 PM
    knayrb
    Bryan
    Pure stock
    Yes. The stuff is a rubber rejuvenator made for leaking transmission gaskets but works great on any rubber product.
  7. Apr 14, 2022 at 12:53 PM
    foothill96tacoma
    foothill96tacoma Well-Known Member
    I had a similar problem as well. AT-205 was not going to help in my case, as the rubber bushings in my lower control arms were completely worn out. I hope that's not the case for you. My point is that if something like this is thoroughly worn out and causing your issue, you'll need to replace it. Diagnosing it may be tricky, but you can always pay a reputable repair shop to do the diagnosis. Different things can cause a squeaky suspension.
  8. Apr 14, 2022 at 12:59 PM
    Minny Taco
    Minny Taco For the Horde!
    Minnesota
    2015 TRD Off Road DCSB
    - Dobinsons shocks and leaf pack - Level 8 MK6 wheels - 265/70/17 Goodyear Wrangler Duratracs load C - SPC UCA - Moog LCA - TRD Pro headlights - Bullet Proof Fab skid plate w/ Line-X - 3M Matte Black roof vinyl - Astrostart remote - Debadged - Black shifter bezel - Front window tint 50% - Color matched grill surround - MESO LED red/white map lights - Osram Super Bright H4 bulbs - Headlight Services upgraded wiring harness - Auxito LED reverse lights - Zulu Nylon Gear MOLLE visor cover - Truxedo Lo Pro QT tonneau - Weathertech floor mats - Weathertech vent visors - Redline Tuning Elite hood struts - OEM bed mat - AJT Design custom shift knob - AJT Design custom climate knobs - Center console organizer - Salex glove box organizer - 1" driver seat spacers - AntennaX 14" antenna - AVS door sill protectors - Trimmed OEM mud flaps - Candyapple red tow hook - Painted pinch weld and radiator frame - Custom radio knobs from Hondo Garage - Xtunes black tail lights - Black LED third brake light - Ruff Tuff Kryptek Typhon seat covers - ACEkraut license plate relocation bracket - Cali Raised Side Shooter ditch lights w/ lo-pro mounts - Subaru tweeters + Rockford Fosgate speakers - Thinkware F800 Pro dash cam - Stickers n shit
    I had this going on too. For a few days it was really squeaky over every bump and turn, then it got less and less to the point I thought it had magically fixed itself. Then it came back but not as bad so I took it in. Dealership says you have worn out tie rod ends. OK, replace those. Few days later there's a faint squeak again for about a day and now it's been silent. So I dunno wtf...
  9. Apr 14, 2022 at 7:15 PM
    dave72peter
    dave72peter New Member
    is there bearings in the upper and lower areas of your king shocks,if so check those
    Digiratus likes this.
  10. Apr 14, 2022 at 10:40 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    How many miles on the Kings. Sounds like it could be the lower spherical bearings on the shocks. Spray them with a water hose and see if the noise changes any. Not a fix but easy identifier.
  11. Apr 15, 2022 at 6:16 AM
    bodhi armor
    Joshua
    East TX
    Kings have around 80k. I’ll try that today
  12. Apr 15, 2022 at 8:36 AM
    Digiratus
    Roaming the PNW
    The RedHead
    80K is a lot, even if it is only street driving. Throw some offroading into the mix and your shocks are overdue for a rebuild, even if a seal isn't leaking yet.
    FWIW, that lower bearing is what goes first on mine. I usually change them before they start to squeak. I typically get 25-30K out of a set and at that point they are getting very loose. Squeaking indicates a metal on metal situation where their teflon lining is completely gone. Eventually they will start to wear in their mount. Once that happens, it starts to get more expensive to fix. A COM10T bearing will cost you about $10 each for the cheaper versions.
  13. Apr 17, 2022 at 6:02 PM
    bodhi armor
    Joshua
    East TX
    Seriously?! Only 25k on a thousand dollar set? That’s kinda shitty..
    oh well I guess.
    How hard are these to rebuild?
  14. Apr 18, 2022 at 10:40 PM
    Digiratus
    Roaming the PNW
    The RedHead
    The lower spherical bearings are an easy swap. And range in price depending on quality. I have found the FK brand with their F1 spec to last the longest. Of course you pay a little more than the plain old COM10T bearings.
    https://www.summitracing.com/parts/fkb-com10tf1
    https://www.summitracing.com/parts/qa1-com10t
    SR-71A likes this.
  15. Apr 21, 2022 at 8:50 AM
    bodhi armor
    Joshua
    East TX
    Excellent! Thanks for the info.
    I’ve noticed over the last couple months that my tires are wearing unevenly . More wear on the inside. All of my previous sets of front tires wear the same way eventually, after an alignment they wear evenly for 6months to a year, then back to wearing on the inside.
    could this be evidence that my tie rod ends need to be replaced ? Or something else perhaps ?
