Super Stuck Tie Rod End
Discussion in '1st Gen. Tacomas (1995-2004)' started by dirtyapron, Aug 31, 2024.
  1. Aug 31, 2024 at 6:18 AM
    dirtyapron
    dirtyapron [OP] Member
    Nic
    2003 Tacoma Ext Cab
    i’m doing the djm lowering kit rn and i’m trying to replace my old tie rod end, but the things stuck as a mug i been trying for bout an hour or two i’ve applied lots of pb blaster i’ve used heat the bastard won’t break loose any tips?
  2. Aug 31, 2024 at 11:23 AM
    FixMyTaco
    FixMyTaco Well-Known Member
    Lee
    Alaska
    96 ext cab 4wd mt 3rz 400k mi.
    Rebuilding seats with leather from furniture and extra padding. Might put leather on the dash and other interior parts.
    Try using a pickle fork? A bigger hammer? If you"re trying to knock it loose with a hammer maybe try putting something solid under it to get better shock value from the hammer impact.
  3. Aug 31, 2024 at 11:43 AM
    time623
    time623 Well-Known Member
    James
    AZ
    1995.5 White Tacoma 4x4
  4. Aug 31, 2024 at 11:48 AM
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    Being a tie rod.. what is actually stuck- the stud or the bit threaded into the inner TRE ?
  5. Aug 31, 2024 at 11:50 AM
    IvanhoeTaco
    IvanhoeTaco Well-Known Member
    Eastern NC
    2005 Supercharged Converted Prerunner
    Total Chaos 3.5 LT, King Coilovers, 35x11.5r17 on Falcon T2, ADV 4 inch fiberglass, 4.88 gears, FJ cruiser transfer case, 4 runner front diff, Cab mount relocate, archive hangers, shackles, king 2.5x14 rear shocks, icon rxt leaf springs, king hydro bumps
    When people say they've applied heat, it usually a small map torch. You need oxy/acetylene type of heat some times.
