Super Truck
Discussion in '2nd Gen. Tacomas (2005-2015)' started by White Lightning87, Aug 13, 2014.
  1. Aug 13, 2014 at 11:34 AM
    White Lightning87
    White Lightning87 [OP] Member
    Nathan
    Midland, Tx
    09 TRD 6" Lift 35's
    6" Pro Comp Lift, 35" Nitto Trail Grapplers on 20" Moto Metal Wheels, Fender Flares, Road Armor Stealth Front Bumper w/ Warn Winch, K&N Cold Air Intake, Flowmaster Dual Exhaust. Doug Thorley Long Tube Race Headers
    If you were building a 'Super Truck' and cost didn't matter, what would you do?
    Best Motor
    Best Transmission
    Best Axles/Gears
    Best Exhaust
    If you wanted to out run, out pull, and just all around out perform every other truck, what would you do. TIA
    -White Lightning87
  2. Aug 13, 2014 at 11:52 AM
    Large
    Large Red
    Street truck? NA LS7 / T56, bassani exhaust, 4.56s
  3. Aug 13, 2014 at 11:57 AM
    White Lightning87
    Nathan
    Midland, Tx
    09 TRD 6" Lift 35's
    Yes, I'd like for it to still be street legal
  4. Aug 13, 2014 at 11:58 AM
    Wiggins
    Wiggins Well-Known Member
    Jacksonville
    14 MGM DCSB 4x4 TRD OR
    TRD Sport Hood, ICON 3" Lift - 700lb coils, Total Chaos UCAs 5% Tinted Windows Crystal Front Window Film 2.5 resi shocks front and rear, dakar leaf packs Wheelers Bump Stops All-Pro Offroad APEX Front Plate Bumper, PIAA Fog Lights, PIAA Fog Lights, Black Line-X All-Pro Offroad Skid Plates, Black Line-X All-Pro Offroad APEX Rear Plate Bumper, Side Armor for Plate, Hidden Receiver Hitch, Black All-Pro Offroad APEX Sliders,Line-X All-Pro Offroad APEX Pack Rack, Black Line-X, 16" height ScanTool 427201 OBDLink LX Bluetooth Hankook Dynapro ATM 285/75/16 Vision Manx 16"x8" rims, 4.5" Backspacing Warn M8000-s Winch, Factor55 Flatlink, Factor55 1" Hawse Fairlead RIGID Industries Ditch Lights Tractor Supply Bed Box 260amp H.O. Alternator Big 3 Cable Replacement NorthStar AGM34 battery Pelfreybilt Battery Cage Plefreybilt Fuse Plate BlueSea fuse block Kenwood TS-B2000 Short Wave Radio, Remote face, Pack Rack Mounted Antenna Uniden Bearcat CB Cab Mount Chop (BAMF Inserts) TODO: ARB Air System ARB Rear Air Locker w/ 4.88 gears ARB Front Air Locker w/ 4.88 gears HID Retrofit Headlights Rigid Industries RDS-Series 54" Midnight Edition LED Rigid Industries R2-46 Combo Round Light (x2)
    Tatra 10x10 -- built by Russians to withstand Siberian Everything, stolen from pre-WWII US Truck Technology... the best of both worlds.
    https://www.youtube.com/watch?v=6Yw7Ao8BI8Y
    Probably a couple grand in Diesel for a weekend of fun.
  5. Aug 13, 2014 at 11:58 AM
    Large
    Large Red
    I was just asking in general. I'd have a different drivetrain if I could afford a street truck, a whoop hitter and a crawler in 1 garage.
  6. Aug 13, 2014 at 12:01 PM
    pruchai
    pruchai KAMA3
    San Diego, CA
    ‘07 Saab 9-7x 4.2i (it identifies as a Tacoma)
    Not enough...
    Kamaz
  7. Aug 13, 2014 at 12:53 PM
    Flowin
    Flowin Well-Known Member
    Acworth, Georgia
    2014 DCSB TRD OFF ROAD
    OME 3" lift, 265/75/16 KO2s, 35% tint
    UNIMOG
  8. Aug 13, 2014 at 2:12 PM
    josh0351
    josh0351 Californication
    Josh
    VA
    Supercharged '13 TRD OR | '96 4X4 Reg Cab (RIP)
    Some stuff...
    X3
  9. Aug 13, 2014 at 2:13 PM
    Dr_Kevorkian
    Dr_Kevorkian Well-Known Member
    California
    2nd Gen Pyrite Mica AC
    x4!!!!!
  10. Aug 13, 2014 at 2:16 PM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    Ummmmm.... My truck with a valve body upgrade
  11. Aug 13, 2014 at 4:56 PM
    pruchai
    pruchai KAMA3
    San Diego, CA
    Not enough...
    Oh yeah, this one dude comes to my range in a Power Wagon. That thing is beautiful.
    There is a shop that custom builds them, but i don't think his is from them http://www.legacypowerwagon.com/
  12. Aug 14, 2014 at 12:40 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    God I love those old Dodge Power Wagons. The first garage I worked in had one for the junk yard, that beast was unstoppable.
  13. Aug 14, 2014 at 4:59 AM
    ThomasMore66
    Dallas/Fort Worth & Durango
  14. Aug 14, 2014 at 5:17 AM
    ThomasMore66
  15. Aug 14, 2014 at 5:31 AM
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    lol. you aren't gonna outrun anything in a unimog.......
  16. Aug 14, 2014 at 5:32 AM
    Hairy Taco
    Hairy Taco Jungle of Love
    North of Hell
    08 TRD
    Nice. I'll take one
  17. Aug 14, 2014 at 5:33 AM
    ThomasMore66
    Not a Unimog. Kinda looks like one, but it's bad ass!
  18. Aug 14, 2014 at 5:36 AM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
  19. Aug 14, 2014 at 5:39 AM
    RearViewMirror
    RearViewMirror Saw things so much clearer once you... were in my
    Craig Christ
    State of Love and Trust
    2023 Subaru WRX GT Manual
  20. Aug 14, 2014 at 5:43 AM
    JustinL
    JustinL Well-Known Member
    Justin
    Berlin, CT
    2009 TRD OffRoad DCSB Pyrite Mica
    2012 Conversion
