Super Ultimate 3rd Brake Light Build
Discussion in '3rd Gen. Tacomas (2016-2023)' started by MESO, Nov 30, 2017.
  1. Nov 30, 2017 at 12:49 PM
    MESO
    MESO [OP] Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    EDIT:
    Orders are open here:
    https://www.tacomaworld.com/threads/meso-customs-3rd-brake-light-housings.600147/
    It's me again:wave: Messing with more stuff.
    I wanted to build a new 3rd brake light that incorporated @Baja Designs LED rock lights.
    Being all the same size, and available in different colors I decided I wanted 3 red Brake, and 2 white cargo.
    So the design started. The stock shape is a little funky and has slight curves that match to the body. I HATED the fact Toyota made the new lights "not removable" from the outside anymore...well I'm gonna change that.
    From drawing to in hand. Sweet! 3D Printed Super strong and durable Nylon
    Also made a 2nd Gen while I was at it
    It was then coated with SEM "chip guard" for a nice and durable finish
    Lights installed next to the crappy stock one
    Next was the prep and install.
    After dropping the headliner, and removing the 2X 10mm Nuts holding the stock one in..this is what it looks like
    I installed "jack nuts" or crush nuts that will give me a threaded insert. Now I can pull the brake light out FROM THE OUTSIDE if needed.
    I designed it so a rubber gasket can be recessed to seal it. Also I put some RTV in the wire holes for added insurance
    And if the seal wasn't good enough, I put a bead around it for double protection
    The access screws are behind the Left and right LED lights, just move them out of the way to tighten the bolt down. New bolt(1/4-20) with rubber O-ring
    Press the end lights back in
    Wiring was next. I dropped the new wires into the headliner, and grabbed them from outside the slider window. I could have sourced the OEM connector... bit ain't nobody got time for that.
    OEM WIRING COLORS ARE AS FOLLOWS
    white/blk- ground
    Green-Cargo
    Purple-Brake
    All done!
    Top View.
    Side view. I am VERY happy with the fitment and light placement. The housing matches the cab perfect and the lights are exactly vertical
    I guess you want to see some light pics???
    Brake:
    No joke..these are BRIGHT
    Both on:bananadead:
    UPDATE:
    I have now designed a KC version for their CYCLONE lights!
    Robe30, CMutt8145, HondaGM and 183 others like this.
  2. Nov 30, 2017 at 12:51 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
  3. Nov 30, 2017 at 12:52 PM
    MESO
    State of Jefferson
    :rasta:
  4. Nov 30, 2017 at 12:54 PM
    KTJO 4x4
    KTJO 4x4 Well-Known Member
    Katie
    Oregon
    2017 TRD OFF-ROAD 4x4 DCSB BARCELONA RED
    Nitro 4.88 Gears OVTune 1.05 91Oct DirtyDeeds Exhaust
    Take my money!!!!!
  5. Nov 30, 2017 at 12:58 PM
    nachyotaco
    nachyotaco Well-Known Member
    Taylor
    2017 MGM Tacoma TRD Off-Road
    :bowdown:
    RobP62 likes this.
  6. Nov 30, 2017 at 1:01 PM
    Comb
    Comb Known Member
    2017 TRD Sport 4x4 DCSB 6MT BBP ABCDEFG
    OVTune Verified Purchase
    You need to slow down, take a deep breath, relax. You're moving way too fast. :rofl:Looks fantastic though.
    Squidink and RobP62 like this.
  7. Nov 30, 2017 at 1:03 PM
    MESO
    State of Jefferson
    SLOW DOWN? Life's too short.. must go fast and mod all the things.
  8. Nov 30, 2017 at 1:03 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    sergeantc and RobP62 like this.
  9. Nov 30, 2017 at 1:06 PM
    Broccoli
    Broccoli Well-Known Member
    Airdrie Alberta
    2016 trd sport blazing blue,
    Price and im sold, also instead of drilling out for nutserts couldnt you potentially use these? Nut clips?
  10. Nov 30, 2017 at 1:06 PM
    Comb
    Comb Known Member
    Everyone else wants to mod all the things too. Send some of that goodness our way! We're waiting to throw money at you!
    edit: See? Above post ready to buy!
    RobP62 likes this.
  11. Nov 30, 2017 at 1:06 PM
    MESO
    State of Jefferson
    Yas. But these mo betta
  12. Nov 30, 2017 at 1:08 PM
    Broccoli
    Airdrie Alberta
    I dont like drilling into my new truck, learned that the hard way with some cali raised 52” lightbar brackets.
    NorrinRadd, DAS Taco, AZROTTI and 6 others like this.
  13. Nov 30, 2017 at 1:26 PM
    over60
    over60 Over70 & still a "Grumpy Old Guy"
    Muskoka, Ontario
    2016 Inferno (Punkin) TRD 4X4 Sport DCLB w/upgrade & tech pkg..!!
    Toyota running boards/Solid Fold 2.0/custom stickers/Anti-Dark LED light under hood/Derped grill/Scoop, etc.
    You da man @mesojdm ....!! Looks cool..:thumbsup::canada:
    RobP62 and MESO[OP] like this.
  14. Nov 30, 2017 at 1:27 PM
    MESO
    State of Jefferson
    You'll come around. But ya.. holes in the roof for a BRO bar is a no-no.
  15. Nov 30, 2017 at 1:32 PM
    BlkTaco47
    BlkTaco47 Unhinged
    2018 TRD PRO Midnight Black Metallic
    sheesh! awesome work as always man.
    keep waiting to see a thread from you: Just built my own Tacoma! :D
  16. Nov 30, 2017 at 1:37 PM
    Radarninja
    Radarninja Safety 3rd
    Northern California
    06 taco
    Chromed out radiator cap
    Wow looks bitchin!
  17. Nov 30, 2017 at 1:46 PM
    su.b.rat
    su.b.rat broken truck
    cracked my OE cargo lamp so I'm all in for this. any plans to produce a few or just a DIY today?
    RobP62 and ChadsPride like this.
  18. Nov 30, 2017 at 2:02 PM
    Radarninja
    Northern California
    06 taco
    I'm subbed and interested in 2 gen. Also like to see if you do a kc high lite version.
    Taylor@KC HiLiTES likes this.
  19. Nov 30, 2017 at 2:05 PM
    1bad2k
    1bad2k Well-Known Member
    Lone Star State
    2017 Tacoma TRD PRO
    MesoCustom... Lol. Very cool!
    RobP62 likes this.
  20. Nov 30, 2017 at 2:08 PM
    JdevTac
    JdevTac Well-Known Member
    Josh
    GA/WA
    2nd gen
    I know it was brought up in the other thread, but will you be potentially making one that can fit KC cyclones?
