Super Ultimate 3rd Brake Light Build
Discussion in '3rd Gen. Tacomas (2016-2023)' started by MESO, Nov 30, 2017.
  1. Jun 1, 2019 at 5:53 PM
    #2481
    MESO
    MESO [OP] Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    Precisely
  2. Jun 1, 2019 at 6:50 PM
    #2482
    dkhorse74
    dkhorse74 Well-Known Member
    Where you want to be
    @MESO or anyone.. Are the 2 outer holes supposed to be precisely aligned with the KC light hole or just a tad bit off? Mine is a bit off:
  3. Jun 1, 2019 at 6:51 PM
    #2483
    MESO
    State of Jefferson
    Off. They have to align with the truck mounting holes.
    FishnTx and Inferno__Taco like this.
  4. Jun 1, 2019 at 7:18 PM
    #2484
    dkhorse74
    Whew! Thanks for the quick reply
  5. Jun 1, 2019 at 8:55 PM
    #2485
    lowtaco
    lowtaco Well-Known Member
    San Diego, CA
    I sent you a message about buying the prototype if its still available.
  6. Jun 2, 2019 at 9:20 AM
    #2486
    texbaz
    texbaz Well-Known Member
    "Buffalo Creek" TX
    2018 Tacoma Silver Sky Metalic 4WD DCSB TRD OR
    Meso, are the KC5 housings still going to be available, anytime soon? If so, any idea time frame.
  7. Jun 2, 2019 at 9:41 AM
    #2487
    stiles88
    stiles88 Well-Known Member
    Seattle (Bothell WA)
    2020 GLE 350, 2008 FJ
    I'm having an issue with two of the red lights in my BD5. One of the lights is working intermittently and the other one looks like it is running at about 50% power. I'm fairly confident my extremely amateur wiring skills are to blame. Would you guys think it's the ground or the power wires that I need to rewire? I'm assuming power because the two white lights seem to work perfectly. Thanks for the help!
  8. Jun 2, 2019 at 12:41 PM
    #2488
    Rparker017
    Rparker017 Well-Known Member
    2018 Tacoma TRD Pro
    ShiftSense Pro
    Do yourself a favor and pick up a some quality heat shrink butt end connectors, a ratcheting crimper, and a heat gun. It will be $50 spent today that will pay dividends for years to come. I’m not necessarily recommending the tools linked below, just providing a couple modestly priced examples. Happy modding!
    Titan Tools 11477 Ratcheting Wire Terminal Crimper https://www.amazon.com/dp/B0069TRKJ0/ref=cm_sw_r_cp_api_i_5tc9CbBZ9QZQ1
    REXBETI 1800W Dual Temperature Heat Gun, 140℉-1210℉(60℃-654℃) High Power Hot Air Gun, Ergonomic Body Design, 2 Nozzle Attachments, Fast Heating In Seconds, No Smoke Issue https://www.amazon.com/dp/B0759MHB45/ref=cm_sw_r_cp_api_i_svc9CbXTNYED3
    mtip, Boomer3731, Wengel21 and 2 others like this.
  9. Jun 2, 2019 at 7:17 PM
    #2489
    JdevTac
    JdevTac Well-Known Member
    Josh
    MD/GA
    2nd gen
    Post a pic or a diagram of what you have so we can see what you have going on.
  10. Jun 3, 2019 at 5:43 AM
    #2490
    dead.fm13
    dead.fm13 Well-Known Member
    Chesapeake, VA
    2017 Tacoma TRD Sport
    5100/888's front, JBA UCA's, 5160's/Dakar's rear, Ray 10 MDB 17", 285/70/17 Ridge Grapplers, Hondo Garage Radio Knobs, MESOJDM Ultimate Turn Signals, MESOJDM Ultimate Combo Maps/Dome, MESO Total Tail Stage II, MESO Puddles
    I might have a housing already made up and ready to wire in if you're interested.
    PapaRee likes this.
  11. Jun 3, 2019 at 9:14 AM
    #2491
    Wengel21
    Wengel21 Well-Known Member
    Ben
    SoCal
    2017 DC LB TRD OR
    If that's the tool to crimp the pins for the all weather connectors I THANK YOU SIR!! I've been looking for that tool forever!
  12. Jun 3, 2019 at 10:11 AM
    #2492
    Boomer3731
    Boomer3731 Well-Known Member
    2017 DCSB TRD Sport
    Wiring is one of those things where having the right tools makes a HUGE difference. I used to struggle and curse my way through it but now I actually kind of enjoy it...
  13. Jun 3, 2019 at 10:31 AM
    #2493
    Wengel21
    Ben
    SoCal
    2017 DC LB TRD OR
    The curse for me is not knowing the right terminology for the electrical wiring and not having any supply shops for wiring where I can just as them the question lol
  14. Jun 3, 2019 at 10:41 AM
    #2494
    JdevTac
    Josh
    MD/GA
    2nd gen
    If you are using the run of the mill crimp connectors then yeah, but if you mean the weatherpack/Delphi type connectors then no.
  15. Jun 3, 2019 at 2:33 PM
    #2495
    stiles88
    I don't have a wiring diagram unfortunately. My lights go like this: Red-White-Red-White-Red. I have the power wires for the two white lights connected together, then the power wires for the three red lights connected together, and last the five ground wires connected together essentially making three separate wires. I can't remember the colors from the stock wires, but everything was connected and working previously.
    It's going to be kind of a pain to undo those wires and reconnect, so I guess I'm just looking for validation that starting with the power wires for the three red lights makes the most sense? The two white lights seem to always work, so I'm assuming there is a bad connection in the power wires for three red lights.
  16. Jun 3, 2019 at 2:40 PM
    #2496
    JdevTac
    Josh
    MD/GA
    2nd gen
    Idk to be honest. I’d start with the connections but to me the LEDs shouldn’t be like 50% dim and then one unit not lit at all. If the connection was crap I would’ve thought they’d be on/off not in between but idk. LEDs aren’t exactly the same as incandescents. If wired in parallel they do have the ability to hog current. Maybe that’s what’s happening but I would think a lot more people would be having that issue.
    stiles88[QUOTED] likes this.
  17. Jun 3, 2019 at 2:48 PM
    #2497
    stiles88
    Thanks man, I appreciate the response. That's why it's kind of weird to me. If the connection was bad for the three that are connected together, I would expect all three of the lights to be having issues. Not one working at 50% power, one working correctly sometimes but not at all at other times, and one working correctly at all times.
  18. Jun 3, 2019 at 5:49 PM
    #2498
    texbaz
    "Buffalo Creek" TX
    Thanks for the offer, think I'm still on the fence about the ultimate 3rd brake light. I really like the KC5 design its so, in your face when lit up. I just worry about durability.
    Meso, hasn't had his housings subject to the most extreme environments like Texas in the summer for months on end. least I haven't found anyone to put a review up on his housing. Ive seen reports of corrosion on the KC lights along with water intrusion this concerns me especially when the existing factory light is such a dork design.
    Love the KC5 design it is very functional fits the body lines of the Tacoma well. But for four hundred plus to replace my light I'm slightly apprehensive. If Meso, has a bonafide affordable, Ip69 rated LED he's designing from the ground up thats easily obtainable (for spares) and replaced then the HEX series will be the ultimate 3rd brake light I'll invest in. But again thanks for the offer.
  19. Jun 3, 2019 at 9:13 PM
    #2499
    Ronzio
    Ronzio Well-Known Member
    Pennsylvania
    17 DCSB TRDOR
    Anyone know the best way to remove the “KC silkscreen logo”? from the lens without messing it up? I’m thinking acetone would probably ruin it.
    Jonicus likes this.
  20. Jun 3, 2019 at 9:28 PM
    #2500
    Naughty
    Naughty Well-Known Member
    Chicago
    haha thats so killer dude. everytime i look at it i like it more. :thumbsup::woot::yes:
    WHIT4K3R and Beretta4x4 like this.
