Super Ultimate 3rd Brake Light Build
Discussion in '3rd Gen. Tacomas (2016-2023)' started by MESO, Nov 30, 2017.
  1. Oct 2, 2019 at 9:04 AM
    #2921
    Tacospike
    Two Trucks
    No, still gonna be a little while I imagine
  2. Oct 3, 2019 at 9:06 PM
    #2922
    2d Dragoon
    2d Dragoon Member
    PreRunner
    I noticed like PapaRee post #2924 that one of my KCs had a cracked lens. Think it might be that I loosened a few screws for a test of how tight they are and maybe when I re-tightened the torque difference was enough to cause a crack. I'm not to worried about it, but don't think I'm going to loosen any more screws, as I was going to paint the PCBs black. If the others crack, then there is something else going on, but wouldn't think so, they are going to have lots of heating and cooling cycles in their life (screws were just a little more than snug).
    PapaRee likes this.
  3. Oct 3, 2019 at 9:17 PM
    #2923
    2d Dragoon
    2d Dragoon Member
    PreRunner
    My concern is about leaking of the KC 4 on a 2d gen. found the thread for 2d gen and there it suggests buying another thick foam gasket if you damage the original gasket, and saving the chrome plastic piece (water intrusion in a 2d gen can't be good, they didn't come with sunroofs which would include drainage channels at least around the sunroof.
    I guess 3d gens are supplied a gasket, but not 2d gens. I'm going to wait to spring before disturbing the third brake light, so I'll have time to see if I'll need to RTV the whole thing, and maybe I'll find a better gasket for the job.
  4. Oct 5, 2019 at 10:06 PM
    #2924
    Sr5coma
    Sr5coma Well-Known Member
    Pete
    Texas
    2017 Super White Sr5
    Really wanted to wait for the Meso plug and play harness. But I’ll be doing sharkathon down in South Texas so I went with @forrest1st ‘s mock up :thumbsup:
    forrest1st likes this.
  5. Oct 7, 2019 at 7:18 AM
    #2925
    xMaverickx
    xMaverickx Well-Known Member
    Jeremy
    New Brunswick, Canada
    2016 MGM Limited V6 4X4 DCLB
    I had one of my clears do this exactly in the same spot as your first picture. Though I was really careful and only went snug but must have went a bit to tight. All of my other lights are fine and are holding back water from the pressure washer no problem. Cracked ones not leaking either, can only see it if you’re on top of it.
    PapaRee[QUOTED] likes this.
  6. Oct 7, 2019 at 11:07 AM
    #2926
    PapaRee
    PapaRee Pro Tuner
    Kreg
    Prairieville, Louisiana
    2016 Black TRD Sport, Tuned, BHLM OEM LEDs
    GTS Dobinson's lift, 33"-Wildpeak Atw3-18x9 -6 Offset ,265/70/18 tires, Raceline Assault wheels, Backflip G2 bed cover, Magnaflow exhaust, Pro tail lights, Pro fog lights, Pro grille, Raptor grille lights, Predator side steps, RedLine Hood Struts, Toyota bedmat, tinted windows, Retrofitted-BHLM-Amber Halo-Amber DRL-HID headlights, LED Highbeams, LED Hood Scoop lightbar, LED hidden bumper lightbar, LED under hood light, LED Bed lights, LED license plate lights, Tacoma tailgate 3d letters, Tacoma glovebox 3D letters, removed air dam, Custom TRD Sport emblems, Pro Shift Knob with Meso ECT Stealth button, Meso LED dome and map lights, Meso V3 smoked mirror turn signals, Meso Stage 2 Tail lights, Meso Mirror Puddle lights, Meso KC-5 Brake/Cargo light, Meso center console bucket with OG lid, Tailgate PNP kit, Garage door opener button in overhead console, Meso Minimalist keyfobs, Matte black Pro hood decal, KTJO4x4 Led door handle LED lights, Pioneer 6x9 3 way front speakers, Rockford Fosgate 6.75' rear speakers, TacoTunes tweeters, AJT black vent rings, JDM Gas cap cover.
    Yea, I haven’t had any water in the light yet either. I’m gonna leave it alone while I start saving up for new $30/each lights again. I just wish that I could buy the lenses only.
  7. Oct 7, 2019 at 11:20 AM
    #2927
    xMaverickx
    Jeremy
    You and me both, I got one spare red one if the reds ever crack but not clear’s. Cyclones are usually 50$ up here, Amazon sometimes has them on sale for 39$.
    When I was buying lights for this mod I actually ended up finding a Jeep 4 rock light kit in red on amazon for 100$!! It was 25$ a light, I only needed 3 but it was still way cheaper than buying 3 individually, + now I got harnesses and a bus bar if I ever feel like doing rock lights. That kit is normally 399 up here so it was a hell of a deal. Might even put rock lights on the taco now.
  8. Oct 7, 2019 at 11:28 AM
    #2928
    PapaRee
    PapaRee Pro Tuner
    Kreg
    Ha! I’ve got 2 extra lights now with no lenses. Might be a good idea to use them as some sort of rock lights. Just need to construct some sort of home made lenses. Maybe I can buy some thin sheet plastic and cut some out?
  9. Oct 7, 2019 at 8:11 PM
    #2929
    pop.tremuloides
    pop.tremuloides Well-Known Member
    Colorado
    2019 TRD OR DCSB
    DBACK HD, Armor, SP9100, lights...etc
    Awesome work Forrest!
    I had a similar issue on my 2019 OR with the mounting bolts and did a slight “ream out” with the drill to make it fit. Very simple and glad you mentioned it in your video.
    forrest1st[QUOTED] likes this.
  10. Oct 8, 2019 at 12:53 PM
    #2930
    airmac_11
    airmac_11 Well-Known Member
    2019 Cement DCSB Premium/ Tech TRD 4x4 Sport
    Forrest,
    Well done.
    Add one vote for more install videos. I bought the same set up with the cam and I'm curious to what system you will be using to bring video into the etune system. Right now I'm leaning toward the Crux system so I can add a front video or "Grille Cam" later. But I highly encourage you to video more as I'm sure there are others who like and need this help. Thanks again.
    BTW- I think you and I got the same "unpainted" MESO 3rd brake light. Did you end up painting yours? I'm thinking of painting mine even though the unpainted version could work as is.
  11. Oct 8, 2019 at 10:15 PM
    #2931
    forrest1st
    forrest1st Well-Known Member
    Forrest
    Flagstaff, AZ and Antarctica
    2017 Barcelona Red DCLB TRD Off-Road
    On my way to full on mall crawler status. Pelfreybilt Aluminum front bumper with Smittybilt 8K synthetic, Rigid SAE Fog lights, and Baja Design 30" light bar C4 Fabrication Rock sliders SCS SR8 Wheels wrapped in 265/75/R16 Goodyear Wrangler Duratracs ATH Fabrication High clearance rear bumper with Baja Design Squadron rear work lights Leitner Designs aluminum bedrack with a Wilderness Hard shell RTT Morimoto XB Headlights 1794 edition style leather seats
    I went with a module off Amazon, https://www.amazon.com/gp/product/B07DKH6J4W/ref=ppx_yo_dt_b_asin_title_o07_s00?ie=UTF8&psc=1
    It works well, but I would be interested in the CRUX system you mentioned. I have a grill camera, but the module I have doesn't allow me two have two cameras and still use my backup camera. that's why I never posted a install video, because I really am not happy with the outcome quite yet and would like to deliver the best info possible.
    I thought that it didn't look painted. I ended up just leaving it. I'm about to head to the antarctic for several months and may take it off and paint match when I return now that I know it isn't actually painted.
  12. Oct 9, 2019 at 8:20 AM
    #2932
    airmac_11
    FYI: I don't know if I read it from MESO or another thread but I think they used
    SEM Satin Black Chipguard - to paint the housing. I'm still assembling parts for a major mod that will include the 3rd brake light but I'm waiting for Black Friday to make some final purchases for things to fall into place.
  13. Oct 9, 2019 at 8:23 AM
    #2933
    airmac_11
    Also there are more threads about multi-camera use but here's one talking about the crux system- in this thread there are dealers who can provide the unit for multi-cameras.
    https://www.tacomaworld.com/threads...d-view-dvr-record.614827/page-5#post-21739035
  14. Oct 11, 2019 at 9:17 PM
    #2934
    Meeks13
    Meeks13 Well-Known Member
    Seattle
    2017 4Runner Cement Pro
    King Suspension-SPC UCAS and Dobinson C59-327 Rear Springs-Duratracs 285/70/17-Shrockworks Sliders-K9 Full Roof Rack-CVT Awning 79”-Canvasback Liners -Morimoto HID -SCS Ray 10s 17x9 -38 Matte Black -OEM Audio Plus Reference Package with Gain Adjuster and Second Dedicated Sub Amp -TRD CAI-ARB Twin air compressor -Rago Fabrication Driver Side Panel -C4 Rear Dual Swingout-C4 Lo Pro- Baja S8-Anytime Front/Rear Camera-Nitro Gears 4.88-RCI Aluminum Transmission/Integration Skids
    Anyone with the BD5 experience after install the key fob not working or the door unlock lock when the bed light is in the on position?
    FishnTx likes this.
  15. Oct 11, 2019 at 10:02 PM
    #2935
    FishnTx
    South East Texas
    ‘17 OR
    I have a bd4 After installing I have to damn near get right up to the truck to unlock /lock . Prob lost at least 3/4 of the distance I use to have
    Meeks13[QUOTED] likes this.
  16. Oct 11, 2019 at 10:08 PM
    #2936
    Meeks13
    Seattle
    There seems to be a mix of Bd5 and BD4 having the fob issue. Right now I have the bed light in the off position and the fob works like normal but of course defeats the whole purpose of having the bed lights would love to hear if anyone else has come up with a solution would love to be able to use the bed lights again but the doors locking and unlocking without me standing there till the dome and map lights go out to do so does not make any sense
    FishnTx[QUOTED] likes this.
  17. Oct 12, 2019 at 6:12 PM
    #2937
    mutely
    mutely Well-Known Member
    TRD Pro in metallic primer
    Thanks for the heads up. I’ve was concerned with the wire gauge since it only looks like 22gauge (at most) in the factory harness. I’ve also been 1/2 thinking of wiring up them to come on with the reverse lights as well, which would mean running extra wire up there and moving them onto a separate circuit that’s switched from either reverse or bedlights. Since there is obviously a power draw issue, you just made up my mind to do that. I’ve got to pull the interior apart to run the camera wires, so may as well run the extra wire at the same time.
    I’ll test both circuits and report back if moving them onto their own fixes the issues.
  18. Oct 12, 2019 at 6:21 PM
    #2938
    Meeks13
    Seattle
    Yes please report back!!
  19. Oct 12, 2019 at 6:23 PM
    #2939
    su.b.rat
    su.b.rat broken truck
    is the cause clear?
    does this affect the MT key fobs?
    wonder if I should wait to install. everything's ready to go, just need a little time. maybe it's now time to wait..
  20. Oct 12, 2019 at 6:36 PM
    #2940
    Meeks13
    Seattle
    No clear cause yet meso has some ideas but a lot of them require removal of the molding once it’s already siliconed on so most people haven’t tried them...it’s not all the Bd4 or bd5s but with more people stepping forward it seems to be something worth looking into.
    su.b.rat[QUOTED] likes this.
