Super Ultimate 3rd Brake Light Build
Discussion in '3rd Gen. Tacomas (2016-2023)' started by MESO, Nov 30, 2017.
  1. Mar 31, 2020 at 7:46 PM
    #3081
    su.b.rat
    su.b.rat broken truck
    do you have more info? details?
    i have the unit wired and ready, but connecting to the truck has been holding me back for that reason ^. if you have a specific relay and wiring diagram or similar handy, would you please share? if i get that part square then i'm ready to go with it.
  2. Mar 31, 2020 at 7:59 PM
    #3082
    mutely
    mutely Well-Known Member
    TRD Pro in metallic primer
    No diagram, it’s about as basic as it gets. you can pickup the power from the factory switch from behind the drivers kick panel. If you look at the Toyota OEM install pdf for cargo lights, it shows you that power. Simply run that to the coil of a relay and the other side of the coil to earth. Then run power from battery (through fuse) to the contact of the relay, and the other side of the contact up to the light. (Ran that on passenger side of vehicle). When you put in the light, simply use the OEM brake light power (not cargo power or earth). Then use your new cargo power and use your own earth. There is a good earth by the rear seatbelt anchor. Personally recommend you use AWG 18 or lower wire.
  3. Mar 31, 2020 at 8:38 PM
    #3083
    su.b.rat
    thank you. i have the wire and planned to use the seatbelt anchor so I'm good there. which relay did you use?
  4. Mar 31, 2020 at 9:06 PM
    #3084
    LandLover
    LandLover Well-Known Member
    Andrew
    17 Tacoma Limited
    I'll give you $5 if you draw this on a big chief tablet and post :anonymous:
  5. Apr 1, 2020 at 10:00 AM
    #3085
    tomgru
    tomgru Well-Known Member
    Thomas
    PNW
    2021 TRD Pro
    Please!!!!
  6. Apr 1, 2020 at 4:28 PM
    #3086
    LandLover
    Andrew
    17 Tacoma Limited
    Got the BD4 in Thanks @MESO you were right it was alot of sanding but very happy with the final result.
    Sandy94, ksanti808, Jonicus and 5 others like this.
  7. Apr 1, 2020 at 5:18 PM
    #3087
    MESO
    MESO [OP] Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    It’s a lab out of love:D. And that turned out killer!
    Ennui likes this.
  8. Apr 1, 2020 at 6:42 PM
    #3088
    mutely
    I’ll draw something up and post. Use any 12v relay that has appropriate contact amps, standard automotive is way more than adequate for this. So that’s probably your best option as it’ll match all the other relays.
    su.b.rat[QUOTED] likes this.
  9. Apr 2, 2020 at 11:25 AM
    #3089
    mutely
    Here you go.
    Skydvrr and su.b.rat like this.
  10. Apr 2, 2020 at 11:29 AM
    #3090
    LandLover
    Andrew
    17 Tacoma Limited
    I dont see factory switch ma I missing something?
  11. Apr 2, 2020 at 11:54 AM
    #3091
    mutely
    "Tap power for cargo lights from drivers side kick panel" this is AFTER the factory switch. So factory cargo switch will work exactly as before, but using the new circuit.
    Per previous reply, look at the Toyota bedight install PDF for the exact wire (it's different for double & extended cabs) Page 13 in below link.
    http://toyotaparts.sparkstoyota.com/install/00016-35087inst.pdf
    su.b.rat likes this.
  12. Apr 2, 2020 at 12:01 PM
    #3092
    LandLover
    Andrew
    17 Tacoma Limited
    Yup installed those thanks so much !
  13. Apr 3, 2020 at 11:56 AM
    #3093
    Boomer3731
    Boomer3731 Well-Known Member
    2017 DCSB TRD Sport
    Why not just relay the brake lights as well?
  14. Apr 3, 2020 at 5:22 PM
    #3094
    mutely
    Go back to a previous post that's explained. They both cause interference with the keyfob, but it's only the cargo that are on and therefor causing a problem when you lock the doors, so there is no real need for the brake lights. But if for some reason you need to lock / unlock with brake lights on, then you should absolutely run the brake lights through a relay.
    Boomer3731[QUOTED] and su.b.rat like this.
  15. Apr 3, 2020 at 5:27 PM
    #3095
    su.b.rat
    unexpected entrainment of the day. been told i have an odd sense of humor.. :spy:
  16. Apr 3, 2020 at 10:08 PM
    #3096
    Kleach18
    Kleach18 Well-Known Member
    2016 TRD Offroad
    Does anybody know if the new MESO brake light setup that is in development will have the same issue with causing interference while locking the truck? For now I just turn the bed lights to off all the time and only turn them on when I need to use them. That seems to limit the interference for the most part. Just curious if when he releases the new setup with the different lights if it will cause the same problem?
  17. Apr 4, 2020 at 4:57 AM
    #3097
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Damn, I need to catch up on this thread. Mine has pretty bad interference
    JasonT87 likes this.
  18. Apr 13, 2020 at 1:27 PM
    #3098
    jophis33
    jophis33 Well-Known Member
    Joseph
    2018 Tacoma TRD Sport Dbl Cab
    n/a
    Anyone know where I can purchase a plug n play harness to install a Meso brake light?
    Unaverage_Taco likes this.
  19. Apr 13, 2020 at 2:42 PM
    #3099
    PapaRee
    PapaRee Pro Tuner
    Kreg
    Prairieville, Louisiana
    2016 Black TRD Sport, Tuned, BHLM OEM LEDs
    GTS Dobinson's lift, 33"-Wildpeak Atw3-18x9 -6 Offset ,265/70/18 tires, Raceline Assault wheels, Backflip G2 bed cover, Magnaflow exhaust, Pro tail lights, Pro fog lights, Pro grille, Raptor grille lights, Predator side steps, RedLine Hood Struts, Toyota bedmat, tinted windows, Retrofitted-BHLM-Amber Halo-Amber DRL-HID headlights, LED Highbeams, LED Hood Scoop lightbar, LED hidden bumper lightbar, LED under hood light, LED Bed lights, LED license plate lights, Tacoma tailgate 3d letters, Tacoma glovebox 3D letters, removed air dam, Custom TRD Sport emblems, Pro Shift Knob with Meso ECT Stealth button, Meso LED dome and map lights, Meso V3 smoked mirror turn signals, Meso Stage 2 Tail lights, Meso Mirror Puddle lights, Meso KC-5 Brake/Cargo light, Meso center console bucket with OG lid, Tailgate PNP kit, Garage door opener button in overhead console, Meso Minimalist keyfobs, Matte black Pro hood decal, KTJO4x4 Led door handle LED lights, Pioneer 6x9 3 way front speakers, Rockford Fosgate 6.75' rear speakers, TacoTunes tweeters, AJT black vent rings, JDM Gas cap cover.
    Noticed today that I have cracks in almost all my KC Cyclone lenses with water condensation in all. Everything is still working okay. But I need some new lenses.
    Has anyone ever found a place to buy lenses only? Or a fix to stop them from cracking?
  20. Apr 13, 2020 at 2:48 PM
    #3100
    cruiserhead
    cruiserhead Well-Known Member
    Curtice
    2018 TRDOR Cement DCSB. 1980 FJ40. 1978 FJ40
    I have this exact same problem with these exact same lights. But my lights don't work any longer...only some of the LEDs shine. I asked Stew if the housing could be causing it, but he said no. Sounds like maybe the bolts were too tight or something. I just submitted a warranty claim with KC.
