Super Ultimate 3rd Brake Light Build
Discussion in '3rd Gen. Tacomas (2016-2023)' started by MESO, Nov 30, 2017.
  1. Dec 9, 2021 at 3:28 PM
    #3461
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    Good question. Maybe behind the rear seats as low as possible? That might be the most muffled. Wrap in some MLV maybe? Not sure.
  2. Dec 9, 2021 at 3:39 PM
    #3462
    RoostrC0gburn
    RoostrC0gburn Well-Known Member
    Oregon
    2017 Super White DCLB TRD Sport 4x4
    yeah... like maybe not even "mounted" just wrapped in foam and left to dangle behind the seat storage or something. i'll have to figure that out when i dig into it
    daveeasa[QUOTED] likes this.
  3. Dec 10, 2021 at 6:30 AM
    #3463
    mutely
    mutely Well-Known Member
    TRD Pro in metallic primer
    Mine are under the dash, that way they are next to the fuses and easily accessible. You don’t hear them and it’s also a very common OEM relay location from most manufacturers so.
  4. Dec 10, 2021 at 11:58 AM
    #3464
    mutely
    Made a small bracket to mount relay holders and new fuses next to the OEM location.
    Used the parts linked below, the relay holders clip into to the fuse box. Also like this style of fuse holder as it gives you the option to run each fuse from a separate power / join them together or any combination. Mine are configured as 2 fuses powered direct from battery and 2 fuses on ignition power.
    https://www.amazon.com/gp/product/B000CO7I04?ie=UTF8
    https://www.amazon.com/gp/product/B017VDI0GY?ie=UTF8
  5. Dec 10, 2021 at 1:19 PM
    #3465
    Boomer3731
    Boomer3731 Well-Known Member
    2017 DCSB TRD Sport
    Mine are all in a Bussmann relay box under the hood.
  6. Dec 10, 2021 at 2:28 PM
    #3466
    kmorgan3
    kmorgan3 Redside Electric, LLC | VLEDS
    Kyle
    PNW
    2020 4Runner SR5 Premium | RAM 1500
    I've built a few of these for people with Double Cabs. I just used 2 micro relays and they seemed to fit just fine up in the brake light area. At least I haven't had any complaints from the people that asked me to do it.
  7. Dec 16, 2021 at 1:53 PM
    #3467
    JDAISE
    JDAISE Well-Known Member
    Jeremy
    Lancaster, Pa
    17' SR5
    DOBINSONS 3" DIRT KING UCA True North Fab Front bumper DIY rear bumper 285/75/16 FALKEN WILDPEAK ATW3 METHOD 701 Diode Dynamics Fogs
    I need to jump on these ASAP
  8. Dec 29, 2021 at 7:34 AM
    #3468
    5hanman
    5hanman Member
    Columbia, Missouri
    2021 Tacoma SR 4x4 ACLB Silver Sky (Beskar)
    I put the KC4 on my 21 Access Cab last weekend. Only 2 screws to remove. Kit has 3 bulb plugs to wire up to the 4 KC lights (I wired the 2 center ones together) then just pull the existing bulbs and insert plugs. Used the existing rubber seal and two screws to mount it up…and done. So easy, and what a difference. A+ from me.
    Ahomeofbones and BOMBS like this.
  9. Jan 17, 2022 at 7:36 PM
    #3469
    TACO5AU5
    TACO5AU5 Well-Known Member
    New york
    2020 Tacoma Trd offroad
    SSO slime line hybrid bumper Baja design s8 Baja design ditch lights Eibach coilovers Icon rear leaf springs
    I’m
    So for the Bd5’s a relay is required it seems that a relay would sit on the liner might cause some noise inthe cab
  10. Jan 17, 2022 at 7:39 PM
    #3470
    kmorgan3
    Kyle
    PNW
    That’s why they’re wrapped in loom tape — it’s a felt texture and makes it very quiet. You can also tape it to the inside of the lip.
    TACO5AU5[QUOTED] likes this.
  11. Jan 28, 2022 at 1:10 AM
    #3471
    Dcallicoat
    Dcallicoat Member
    Dalton
    2005 blue Toyota Tacoma Pre-runner
    Roof rack, tires wheels, lift, suspension
    Where can you order the 3rd brake light for a 2nd gen?
  12. Jan 28, 2022 at 3:29 AM
    #3472
    NoOne
    NoOne El Taco Guapo
    Ø ©
    Gulf South
    2022 Tacoma DCLB OR (AT) - BC
    2018 SR5 - (Sold) 2018 OR - RIPieces 2022 OR - BluCrush
    daveeasa likes this.
  13. Feb 1, 2022 at 7:34 PM
    #3473
    buntcake
    buntcake Well-Known Member
    Booboo
    2020 TRD OR Cement
    This might be a bit overkill for what you're doing, but engine bay mounted relay boxes are the direction I went and I'm pretty happy with them. Good to have everything in one place imo. Bought them off Amazon. I'm having the same power issues with mine even though I ran a 16ga ground from the lights so I guess one of the spare relays will have to be cargo light power like y'all sayin
  14. Feb 2, 2022 at 7:39 AM
    #3474
    BOMBS
    BOMBS Well-Known Member
    2017 Black Tacoma TRD Off Road
    That looks insane! o_O:eek::)
    Skydvrr likes this.
  15. Feb 7, 2022 at 7:01 PM
    #3475
    Ahomeofbones
    Ahomeofbones Member Well-Known
    2021 TRD OR
    Can anyone confirm that the new gasket for the third brake light recall fits with the BD4?
  16. Feb 7, 2022 at 7:22 PM
    #3476
    NoOne
    NoOne El Taco Guapo
    Ø ©
    Gulf South
    I’m not sure that it does. The BD4 has its own gasket (“O” ring) and was designed around the lights and the roofline, not the original light shape. My personal thought is that it is a worse gasket than the MESO design, which can easily be supplemented if you felt it necessary.
    Ahomeofbones[QUOTED] likes this.
  17. Feb 22, 2022 at 7:38 PM
    #3477
    Ahomeofbones
    2021 TRD OR
    I see now. Mine actually didn't come with an "O" ring, which is why I looked into the recall gasket. Thanks for the response. I'll submit a ticket.
    BOMBS and NoOne[QUOTED] like this.
  18. Feb 22, 2022 at 7:40 PM
    #3478
    daveeasa
    David
    PNW
    That’s a nice looking CHMSL
    Ahomeofbones likes this.
  19. Feb 22, 2022 at 7:41 PM
    #3479
    MESO
    MESO [OP] Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    Sorry about that. Must have slipped past me! I’ll get it taken care of:) Install is very easy, the round print just presses into the channel.
    BOMBS, NoOne and Ahomeofbones[QUOTED] like this.
  20. Feb 22, 2022 at 7:48 PM
    #3480
    Ahomeofbones
    2021 TRD OR
    Thanks to @kmorgan3
    Best CS there is. :fistbump:
    BOMBS likes this.
