Super Ultimate 3rd Brake Light Build
Discussion in '3rd Gen. Tacomas (2016-2023)' started by MESO, Nov 30, 2017.
  1. Mar 22, 2019 at 6:38 PM
    #1861
    Jakoda
    Jakoda beep boop
    Jackson
    SoCal
    2017 TRDOR DCSB
    Bunch O Shit
    Heck ya this is dope
    Now to take it 1 step further can you take that and incorporate the wire pass through from
    I love these lights but with plans for a snug top and roof racks the flat antenna with wire pass through would be way legit
  2. Mar 22, 2019 at 6:45 PM
    #1862
    MESO
    MESO [OP] Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    Already designed. It’s for a new upcoming roof rack company :)
  3. Mar 22, 2019 at 6:53 PM
    #1863
    Jakoda
    Jakoda beep boop
    Jackson
    SoCal
    2017 TRDOR DCSB
    Bunch O Shit
    Ohhhhhhh duhhh the uptop one! I knew you were making light pods for them didn’t know about the antenna thing. Guess I have to go back and re read that thread.
  4. Mar 22, 2019 at 7:41 PM
    #1864
    Black1Tacoma
    Black1Tacoma #TRUKTOY
    Carlsbad
    2017 Black Tacoma TRD OffRoad 4x4
    What company?
  5. Mar 22, 2019 at 7:46 PM
    #1865
    Black1Tacoma
    Carlsbad
    Here is my set up with the KC version. I love it and they look great!! I also swapped out to all black screws.
  6. Mar 22, 2019 at 7:46 PM
    #1866
    06toyoboy
    06toyoboy Well-Known Member
    How hard was the install?
  7. Mar 22, 2019 at 7:49 PM
    #1867
    Black1Tacoma
    Carlsbad
    Install was easy once the old light was taken off. In my opinion that is the hard part! I am also have never pulled apart the back of roof headliner before.
  8. Mar 22, 2019 at 7:50 PM
    #1868
    MESO
    State of Jefferson
  9. Mar 22, 2019 at 8:00 PM
    #1869
    06toyoboy
    Do you think it would just ve easier to bust out the OEM one instead of pulling down the headliner?
    Black1Tacoma[QUOTED] likes this.
  10. Mar 22, 2019 at 8:00 PM
    #1870
    MESO
    State of Jefferson
    YES
    Black1Tacoma likes this.
  11. Mar 23, 2019 at 12:25 AM
    #1871
    Caboose117
    Caboose117 foul mouthed Marine
    Chad
    Kentucky
    ;IGY6 Rescue Truck
    smashed this, broke that, covered it up with tape and paint
    uploadadventure and Maveric like this.
  12. Mar 23, 2019 at 6:40 AM
    #1872
    metwo
    metwo Member
    Stew - can you please provide one more revision :
    Add a NMO mount to the low profile puck and provide a flat top (no ribs/text against ice buildup in winter ). All we need is space for the XM radio antenna (for traffic / weather). The FM/AM signal can be retrieved from the NMO antenna (+ some RF pass band filters ).
  13. Mar 23, 2019 at 7:00 AM
    #1873
    metwo
    metwo Member
    And for those that don't care about XM, they only need the FM (HD radio) feed for Weather / traffic. Makes it even simpler!
  14. Mar 23, 2019 at 7:48 AM
    #1874
    JdevTac
    JdevTac Well-Known Member
    Josh
    GA/WA
    2nd gen
    I just thought about something. Don’t NMO mounts need some metal mounting surface to properly ground? They usually have teeth on the bottom to bite into the mounting surface for proper grounding.
    So to run one with good performance on one of these plastic brake lights we’d need a NGP NMO.
  15. Mar 23, 2019 at 7:50 AM
    #1875
    MESO
    State of Jefferson
    Correct. You would use a NGP antenna
  16. Mar 23, 2019 at 8:40 AM
    #1876
    cruiserhead
    cruiserhead Well-Known Member
    Curtice
    2018 TRDOR Cement DCSB. 1980 FJ40. 1978 FJ40
    You mean just hit it with a hammer and start pulling it apart from the outside in?
    Caboose117 likes this.
  17. Mar 23, 2019 at 8:41 AM
    #1877
    MESO
    State of Jefferson
    If you don’t want to mess with the headliner you could take a flat head and pry the lens off the stock light from the outside. Then drill the plastic in the 2 spots where the mounts are.done
  18. Mar 23, 2019 at 9:06 AM
    #1878
    Nv2056
    Nv2056 Hunt, fish, trap, repeat
    Rural Nevada
    17 DCSB TRD OR
    Icon suspension stage 3 with Toyo MT 255 85 16
    @mesojdm After months of pestering you it finally happened:bananadance: the email alert worked perfectly! Thank you!
    Caboose117 and MESO[OP] like this.
  19. Mar 23, 2019 at 9:33 AM
    #1879
    Nettleberger
    Nettleberger Well-Known Member
    2017 Tacoma TRD Pro DCSB Super White
    Would you mind posting a shot from the back part of your truck so I could see it in relation to the whole tail?
  20. Mar 23, 2019 at 9:34 AM
    #1880
    MESO
    State of Jefferson
    keep in mind, this is version1. Baja changed their rock light size, so the new one is a little larger.
