Super Werty goes URD!!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Super Werty, Apr 2, 2013.
  1. Apr 2, 2013 at 4:57 PM
    #41
    Super Werty
    Super Werty [OP] Sleeper 4x4
    Arizona
    07 TRD Tacoma
    air and fuel
    bridgestone duelers....stock size
  2. Apr 2, 2013 at 5:05 PM
    #42
    TucsonMike
    TucsonMike Blank
    Tucson, AZ
    2021 AG TRD Off Road
    TRD OEM lift kit bronze sema wheels
  3. Apr 2, 2013 at 5:12 PM
    #43
    TacoCat
    TacoCat These pretzels are making me thirsty
    Johnny-5
    Chantilly, VA
    25 Crosstrek Premium CVT (first ever automatic!)
    Wow. Looking forward to the vids.
  4. Apr 2, 2013 at 6:52 PM
    #44
    cookee62
    cookee62 Well-Known Member
    Lake Mary, FL
    06 DBL Cab
    URD SS, URD Y-Pipe, DTLT Headers, 3" URD Cat Back, Fox 2.5 CO, TC UCA, Fox Rear Resi, SS brake Lines, All pro 1.5" leafs, Halo Projector Headlights, WE Bead-lock Rims, 33 BFG AT, No Sway Bar
    NICE!! I cant wait to see the videos of this
  5. Apr 2, 2013 at 7:15 PM
    #45
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    I thought twin screw was better than centrifigul ? And roots dc was the most effective. I realize turbos are centrifugal but opperate at much higher rpms to compensate. I dont have a lot of boosted experience but have always been intrigued by u and what u have done
  6. Apr 2, 2013 at 7:20 PM
    #46
    Corndawg
    Corndawg Well-Known Member
    Corey
    Utah
    2007 double cab TRD off road Radiant Red
    2.5 inch pro comp lift Cobra XRS 9745 Detector 15 band scanner Pioneer DEH-P6900UB Python 991 remote start/ security. Tinted license plate covers Fog Light Mod PIAA Extreme White 4000K Replacement bulbs Red LED Dome and Map lights LED replacement tail light bulbs Black Weather Tech Floor Liners front and rear
    BAD ASS !
  7. Apr 2, 2013 at 7:25 PM
    #47
    Sje1124
    Sje1124 Well-Known Member
    Sean
    Louisiana
    2010 DBL Cab TRD OR 4x4
    Just a few
    Can't wait to see the dyno results.
  8. Apr 2, 2013 at 7:28 PM
    #48
    RAD
    RAD Well-Known Member Vendor
    Rad
    LAX & LOGAN
    Woah! That is insane. What is even nicer is the URD Bling displayed in the grill! :eek:
  9. Apr 2, 2013 at 7:32 PM
    #49
    taco terror
    taco terror 1st gen = best gen
    USA
    1996 Black Tacoma, 3.4L
    4.56 ECGS regear, Wheelers 6 leaf pack, Eibach coils, Bilstein 5100s, AR Baja wheels, 33 BFG ATs, Line-x
    Thats what I thought, but its because this centrifugal pumps out more psi than the trd right?
  10. Apr 2, 2013 at 7:36 PM
    #50
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    .............................subbed x2
  11. Apr 2, 2013 at 7:37 PM
    #51
    07 sport 4x4
    07 sport 4x4 Well-Known Member
    Blake
    Southeast
    2017 Duramax
    See post #11
  12. Apr 2, 2013 at 7:40 PM
    #52
    HIst8ofMIND
    HIst8ofMIND Defend Hawaii
    PJ
    Maui
    2013 MGM DCSB TRD-OR
    Rotrex has a planetary gear design that makes it more efficient than a normal centrifugal sc. It pumps out a powerband unlike any other. Way better than a turbo. Way better than a roots or a twinscrew. Whereas the roots and twinscrew provide low end torque and the turbo at the higher rpm. The rotrex starts at low psi at low rpm and high psi at high rpm. Just don't go past the maximum impeller speed.
  13. Apr 2, 2013 at 7:44 PM
    #53
    Super Werty
    Arizona
    07 TRD Tacoma
    air and fuel
    It's all about flow and (thermal properties)aka heat... not psi. This rotrex flows a lot more, and does so while creating almost zero heat.
    Ive seen this rotrex on an S2000 making 20 psi....so there is a ton of potential in this kit with a built engine:eek:
  14. Apr 2, 2013 at 7:55 PM
    #54
    Sje1124
    Sean
    Louisiana
    Just a few
    Ah I missed that part...
  15. Apr 2, 2013 at 9:38 PM
    #55
    SoCalTacos
    SoCalTacos Turd runner
    socal
    2017 4Runner TRD Pro
    Led head/dtr lights.
    so do you run in 4hi?
    ive seen some xrunners run a quarter at 13.3...what do you expect out of this setup?
  16. Apr 2, 2013 at 9:45 PM
    #56
    wrmathis
    wrmathis Dark Lord of the Sith
    Bonaire, GA
    2006 Tacoma TRD OR 4x4
    parts and stuff
    he has a vid of him running 12.720 @ 106.20 over on xr-underground.com . and he shifts from 4wd on launch into 2wd down the track.
    hopefully he can get traction with his new setup and run a lot faster
  17. Apr 2, 2013 at 9:48 PM
    #57
    SoCalTacos
    socal
    nice...thanks for clarifying.
    12.72 on this setup or past?
  18. Apr 2, 2013 at 9:51 PM
    #58
    wrmathis
    Bonaire, GA
    parts and stuff
    that was on his TRD setup. happened 2 years ago
  19. Apr 2, 2013 at 9:55 PM
    #59
    05Aztacoma
    05Aztacoma Well-Known Member
    05 Tacoma 4x4
  20. Apr 2, 2013 at 10:19 PM
    #60
    SoCalTacos
    socal
    so who's gonna set an over/under on what this setup will run?
