Supercharge 2TR-FE - Tuning questions
Discussion in 'Performance and Tuning' started by 05Taco4x4, Jul 24, 2017.
  1. Oct 21, 2017 at 7:23 PM
    #101
    05Taco4x4
    05Taco4x4 [OP] ToyotaHubs
    2TR-FE Enthusiast
    FJ Tcase, Manual Hubs, 2017 Head unit, Mirror Riser
    Installed the PLX VAC/BOOST, I’ll install the AFR tomorrow.
    Hits a little boost, then holds at 0.
    I think I have a leak ¿?¿
    Edit: I didn’t add any check valves, probably blowing air out everywhere I shouldn’t be. Check valves on order smh
  2. Oct 21, 2017 at 7:58 PM
    #102
    05Taco4x4
    2TR-FE Enthusiast
    Kiwi OBD does NOT show VAC/BOOST and AFR. It does show OPEN/CLOSED loop, though.
    I just found out yesterday that the 2TR-FE is always CLOSED loop to 4500 RPM, then goes to OPEN. So this app is worthless to me.
    Kiwi MultiGauge (free) shows VAC/BOOST and AFR, so I’ll be using that.
    Torspd likes this.
  3. Oct 22, 2017 at 4:04 PM
    #103
    05Taco4x4
    2TR-FE Enthusiast
    PLX should offer this
  4. Oct 25, 2017 at 10:45 PM
    #104
    05Taco4x4
    2TR-FE Enthusiast
    I found a GREAT location to mount my PLX.
    The back of this bracket is curved, so I hammered it flat. Then I cut it to 2-5/8” to slide in the PLX housing.
    I didn’t care for the plastic face of the latest gen AFR gauge, so I took my coping saw and file to the back panel. PLX Ackley Improved :rolleyes:
  5. Oct 26, 2017 at 6:36 AM
    #105
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Pretty innovative right there.
    05Taco4x4[OP] likes this.
  6. Oct 26, 2017 at 6:36 AM
    #106
    05Taco4x4
    2TR-FE Enthusiast
    Do you know of a 170-180 thermostat for the 2TR-FE?
  7. Oct 26, 2017 at 6:39 AM
    #107
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    LCEPerformance.com or Paradiseracing.com one of those should have it, of it is the same as the 3rz?
    If it is the same as the 1GR, then URD.
  8. Oct 26, 2017 at 6:44 AM
    #108
    05Taco4x4
    2TR-FE Enthusiast
    I was being lazy lol, I’ll look into it. I’m super tired, trying to kill time. 3:44am here, 20 hrs into my 24 hr watch :bored:
  9. Oct 26, 2017 at 6:55 AM
    #109
    05Taco4x4
    2TR-FE Enthusiast
    170: Duralast 4107
    180: Duralast 4108
    Material: Stainless and copper
  10. Oct 26, 2017 at 7:43 AM
    #110
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Duralast are in a lot of cases made by Motorad. Good quality. :thumbsup:
  11. Oct 26, 2017 at 4:47 PM
    #111
    05Taco4x4
    2TR-FE Enthusiast
    Finally welded in the AFR bung.
    I’ve been welding a lot of aluminum lately, then went to stainless o_O Actually, is first time I’ve ever welded stainless. I didn’t have my helmet shade correct, burned a whole the size of a dime and never saw it coming
    :annoyed:
    Combine all that with tight quarters and working on my back directly under it and you get this
    :oops:
    Not really to my standard but meeh
    Location is good, crossmember is directly in front/below it.
    BassAckwards and yota243 like this.
  12. Oct 26, 2017 at 6:47 PM
    #112
    05Taco4x4
    2TR-FE Enthusiast
    Bad news...
    Boost still leaks out at mounting flange, gasket didn’t work out. I’ll have to remove and rework the base
    :annoyed:
    yota243 likes this.
  13. Oct 26, 2017 at 6:54 PM
    #113
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    If it aint one thing, its two. You'll get it man
  14. Oct 26, 2017 at 7:09 PM
    #114
    MrCrowntown
    MrCrowntown Well-Known Member
    Alyn
    Ky
    06 Extended cab Prerunner 2.7
    Dirt King Mid travel with King 2.5 coilovers, Baja Kits chase SUA with 14in fox smoothies under custom hangars.
    Make sure things are still true, and get some Toyota FIPG and try again
    Torspd likes this.
  15. Oct 26, 2017 at 7:45 PM
    #115
    05Taco4x4
    2TR-FE Enthusiast
    The 1/8" aluminum flange isn't ridged enough. I'm going to get a used factory manifold and cut the flange from it and weld onto my base. My SC came with one but I tossed it because I didn't have the tools I'd of needed, so I just fabbed one with scrap plate. I should have used it as an excuse to buy them, like I am now :cool:
    MrCrowntown[QUOTED] likes this.
  16. Oct 26, 2017 at 7:49 PM
    #116
    yota243
    E.J.
    north Alabama
    Would 1/8" steel work? If that would be easier that cutting up a manifold
  17. Oct 26, 2017 at 7:53 PM
    #117
    05Taco4x4
    2TR-FE Enthusiast
    Cutting the manifold won't be an issue, I just need a band saw. I could use my sawzall and file/sander (which I considered originally but decided against it). I didn't think I could sawzall it very well because my vise isn't large enough to secure it.
    yota243[QUOTED] likes this.
  18. Oct 26, 2017 at 7:54 PM
    #118
    05Taco4x4
    2TR-FE Enthusiast
    I may only get 3psi of boost, but come hell or high water, I'm going to see this through
    MrCrowntown likes this.
  19. Oct 26, 2017 at 8:25 PM
    #119
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    You'll get it all sorted out.
  20. Oct 27, 2017 at 8:24 PM
    #120
    05Taco4x4
    2TR-FE Enthusiast
    Found a hole, crack where I grounded a weld to make way for a bolt head. I brazzed it
    I’m now at 2 PSI
