Supercharge 3rd Gen or Trade for 4th Gen?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Fartherdegree3, Jul 29, 2024.
  1. Jul 29, 2024 at 12:29 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    4th gen. Get off the couch.
  2. Jul 29, 2024 at 12:46 PM
    tcaustin
    tcaustin Well-Known Member
    Tom
    Columbia, SC
    2022 Electric Lime Pro 6MT
    I wonder how expensive it will be to replace the hybrid battery when it fails?
    I say supercharge your 3rd gen but I'm biased. The 4th gen looks great but I wouldn't buy the first model year of a totally redesigned vehicle. I've done that and regretted it. I'd give it a couple of years for them to work out all the bugs. If you buy now you're basically a beta tester for Toyota.
    And I just can't get over how much they increased the price. It's way more than is justified even with a redesign and inflation. It seems as if Toyota overplayed their hand.
    KingZee, auskip07 and Speedbird like this.
  3. Jul 29, 2024 at 2:36 PM
    medicfung
    medicfung Well-Known Member
    richie
    2019 DC TRD OFFROAD 4x4 6ft bed quicksand
    My supercharged 3rd gen makes enough low end power that i dont struggle getting up the steepest grades at the hollister hills SVRA here in California. My truck motors on up big passes and mountains it used to struggle up. I keep it at 1800 rpm 6th gear and it chugs at 70 mph. I get 17 mpg of i keep it that way with a fully loaded rig.
    auskip07, 9pm, tcaustin and 1 other person like this.
  4. Jul 29, 2024 at 2:57 PM
    Fartherdegree3
    Fartherdegree3 [OP] Active Member
    CO
    2019 Voodoo Blue TRD Pro
    5.29s + OTT 265/75/16s
    Nice! Any gears or aftermarket tune?
  5. Jul 29, 2024 at 3:01 PM
    Fartherdegree3
    CO
    Agree, the cost is tough to swallow, if the price were comparable to when I bought my truck, I don’t think I’d be struggling with the decision as much.
    tcaustin[QUOTED] likes this.
  6. Jul 29, 2024 at 3:05 PM
    Fartherdegree3
    CO
    LOL I can’t help but admire the Hummer EV, i think they’re ridiculously cool. I’ll go full EV once they start to invent quick change over power supplies or can get more range. Until then I’ll probably stick with internal combustion on my vehicles.
  7. Jul 29, 2024 at 3:07 PM
    Fartherdegree3
    CO
    Congrats! What kind of lead time are you expecting?
    tcaustin likes this.
  8. Jul 29, 2024 at 3:26 PM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    I think options 2 or 3 are the only ones I’d consider truly practical. The Maggy SC is neat but I can’t see it being the final purchased to all of a sudden make the 3rd gen “fixed”. Per input from many folks, the torque down low is still going to be very minimal. I have no hard evidence of it but Toyota seems to build it into the ECM that it not let you lug the motor down low, which makes it feel like there is an extreme lack of torque (and as such, actually makes it feel like it lugs). To date, my testing with all the tunes on the market have helped with that a little bit; but not a lot. I don’t think the supercharger tunes can do away with that behavior either. And of course, naturally by design, SCs build more torque with more rpm, so again, the help you do get will be at higher speeds no matter if the SC was stock or aftermarket, that’s just how they boost.
    I personally think the 4th gen is the best route. I want to go that direction, I’m just giving it some time for kinks and they are very expensive, which sucks because I rack up miles quickly. So for now I am burning miles on the 3rd gen. I also put a lot of money into my 3rd gen which is some of the motivation for keeping it, and adds to why I would probably keep it even if I did get a 4th gen.
    Option 3 certainly is not a bad one if you can get past the revving thing. I regeared my manual to 5.29s 1.5 years ago and I have only run 30.5”-32” tires in the 33K miles since the regear. That means I have been above 3,000 rpm in 6th gear any time I’m going more than about 73-75 mph. I will cruise 80-85 mph all day long at 3500 rpm and it does nothing but take it and continue to run smoothly. My temps are lower due to the increased cooling from the faster fan speeds. I have absolutely 0 fear of rpm and personally, I believe my situation to be better for the engine than a stock truck trying to run 1700 rpm in 6th with absolutely no torque at all at that rpm. I will add that I choose to run a thicker oil which seems like a good idea for continued high rpm use, although the oil pump pressurizes any oil pretty strongly with any added rpm, so there isn’t much concern no matter what you run. But you might get a bit more protection out of something in the 30 or 40 weight range if you’re concerned about long term sustained high rpm.
  9. Jul 29, 2024 at 3:41 PM
    Cetacean Sensation
    Cetacean Sensation Never lost in a parking lot
    PNW
    6MT ELM Taco (slow) // N54 BMW 135 (fast)
    What happens if the gasoline internal combustion engine craps out in full ICE off roader, and warranty, expired? Motor alone, cost more the ICE off roader itself.
    RX1cobra and crazysccrmd like this.
  10. Jul 29, 2024 at 3:42 PM
    auskip07
    auskip07 Well-Known Member
    Skip
    Atlanta, Ga
    2019 TACOMA SR V6 SC , 4X4, AUTO, 4.88, 265/75 r16
    told 4-6 weeks ill install my gauges and im still trying to decide if i want to tackle or just hand it over to a shop.
    tcaustin and Speedbird like this.
  11. Jul 29, 2024 at 3:54 PM
    Fartherdegree3
    CO
    Haha the anticipation would be killing me. A few years ago I might have just done it on my own, but having done simpler repairs like replacing alternators, radiators, head gaskets and seeing how easily a quick job can turn into an all day type of ordeal, I’ll just give mine to a shop and have them deal with any unexpected headaches. Lots of folks have commented on how smooth of an install it was for them, but then others have also posted their troubles with it. I just don’t feel like dealing with it if it’s the latter. R4T seems to have a good reputation, stands by their work, and is certified by magnuson, so unless they quote me something absurd I’ll probably go with them.
    auskip07[QUOTED] likes this.
  12. Jul 29, 2024 at 4:02 PM
    auskip07
    Skip
    Atlanta, Ga
    I was quoted something absurd by a performance shop. 2x what Magnuson charges. Magnuson charges 2100
  13. Jul 29, 2024 at 4:07 PM
    Fartherdegree3
    CO
    Yeah great points about the low end boost, I could probably study some SC dyno results a bit more to see what I could expect, just don’t know how to translate that into real world impact and if the truck could at least hold gears better.
    How does your gas mileage hold up cruising at 3500 rpm? With regear and tune cruising at 80 mpg drops me down to 16ish mpg. Anything over 65 and it gets much less efficient.
  14. Jul 29, 2024 at 4:13 PM
    Fartherdegree3
    CO
    Gross, I was anticipating something around the $2K range…good luck, hopefully you can find something cheaper!
  15. Jul 29, 2024 at 4:20 PM
    #35
    auskip07
    Skip
    Atlanta, Ga
    A toyota dealer quoted me 2300 with the oil change and radiator fluid change. that seems pretty reasonable since i cant drive to magnuson
  16. Jul 29, 2024 at 4:43 PM
    #36
    BLtheP
    Plano, TX
    Probably 14.5-15 at 85. I drove a 4.5 hour trip on Saturday, 75-85 and my mpg was 16.1. My record mpg is actually a random tank I had on the 5.29s. It was 18.4 for 4 hours of driving 75-80 with stock sized tires, which means 3200-3400 rpm. 18.4 is not amazing, but the mpg has always been terrible on this truck for me. I never drive at a sustained 65, so I’m not sure what I could achieve if I really tried.
    I think I actually did have one tank when I was stock tire size and stock gears that achieved 19.3, but it was a short trip (40 miles or so) and wind was helping me. I think overall my mpg average dropped by about 1 from the regear, probably because I use the acceleration so much more in town.
  17. Jul 29, 2024 at 5:36 PM
    #37
    OZ TRD
    OZ TRD Well-Known Member
    Central Coast CA
    6sp Manual TRD PRO - Lunar Rock '21
    Evo A SmartCap, Cali Raised Sliders (0 degree), 2WD low Mod, Puddle Pods, 3 switch overhead panel, 8 slot middle console panel, Custom driver's switch panel, Rek Gens, 265 75 16 Falkens, lil B Bed Stiffeners, All new Speakers, Diff Breather, AC Drain, Many interior bits...
    See below
    I think we've seen MANY more brand new engine failures recently, across the various brands building ICE engines for 100 years, than battery failures... (And boy - there are many folks paying attention to EV Failures!).
    Batteries in the first Teslas (OLD technology) are now starting to clock in with higher lifetime mileage than the typical ICE - without the ICE maintenance costs. AND warranties for EV Batteries are much better that any offered on any ICE engine.
    Degradation is less than was initially expected. Used/ crapped out EV batteries are valuable as they have plenty of capacity for MANY other uses - I want one, but can't find any at an affordable price! - even a royally crapped out one.
    Batteries are getting hugely better every day... (ICE tech is not). Solid state batteries are available now for some applications (Still not yet available for EVs, but they are coming!) - Dramatically lighter weights, much higher energy densities, faster charging... progress.
    I recently ran into the below newspaper clipping from 1899. It is reacting to news of the spread of "Evil Electricity". It's unpredictability would result in all kinds of horrors in society.
    Maybe some folks fearing the evils of EVs may recall it! :D
  18. Jul 29, 2024 at 6:34 PM
    #38
    tcaustin
    Tom
    Columbia, SC
    I hate to burst your bubble but one of my colleagues is on her third battery in her Tesla. And it has like 60k miles or maybe less. And when they have to replace the battery you have to be without the car for like 3 weeks.
    Another coworker had the hybrid batter die; it was going to cost more than the car was worth to replace it so they just got rid is the car.
    I don’t believe a batter will last nearly as long as an internal combustion engine. Can the ones in the future? Maybe. But not the current ones. That’s just dreaming. The reality is that current EV technology just isn’t where we want it to be.
    hopefully when they figure out solid state battery technology that will be the big leap. But I sure wouldn’t buy an electric vehicle now. Sure they have lots of torque and are fun to drive. But burning coal is required to charge them and people just get rid of them before they get to 100k miles because of battery degradation. The resale value is atrocious. The depreciation is way worse than ICE vehicles.
    until you can recharge one in the same amount of time it takes to fill up your tank with gas and the range improves and the prices go down, these will continue to sell in only relatively small volumes.
    BLtheP likes this.
  19. Jul 29, 2024 at 6:44 PM
    #39
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    One of the greatest quotes people love to throw around and it’s just not true, like most complaints about EVs. Coal accounts for 16.2% of power generation in the US compared to 18.6% nuclear or 21.4% renewables. In other words it’s less likely that an EV is powered by coal than it is to be powered by clean energy.
  20. Jul 29, 2024 at 6:55 PM
    #40
    tcaustin
    Tom
    Columbia, SC
    depends on the state
    it’s higher in some than others
    there’s a map showing the percentage in each state; I’ll see if I can find it
    But EVs aren’t as clean as Americans seem to think. I’m not saying they’re all bad and it seems like the government is going to force me to buy one eventually.
