supercharged 1GRFE timing chain failure and other weak points
Discussion in 'Performance and Tuning' started by Turboencabulatr, Nov 22, 2016.
  1. Nov 22, 2016 at 12:30 PM
    Turboencabulatr
    Turboencabulatr [OP] Member
    Los Angeles
    2007 trd prerunner
    I'm About to bolt a URD stage 2 supercharger kit on to a 2ng gen with some miles on it and I'm wondering if there are any weak points on the engine that i might want to upgrade or replace with new, such as a timing chain or valve springs?
  2. Nov 23, 2016 at 8:31 AM
    inwood customs
    inwood customs Roaming potato
    Dave
    2006 v6 potato bugTuRD
    K&n, flowmaster, plastidip, chipped, hids, daves
    Not sure bout the engine but id either upgrade the clutch or get the IPT or level10 vb upgrade.
  3. Nov 23, 2016 at 5:35 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Is yours auto or manual?
  4. Dec 3, 2016 at 1:56 PM
    Turboencabulatr
    Los Angeles
    2007 trd prerunner
    Auto tranny.
    yes a valve body is on the list
  5. Dec 3, 2016 at 2:05 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    @Torspd can help you. He has been up and down this engine and knows it's ins and outs like the back of his hand at this point.
  6. Dec 3, 2016 at 4:34 PM
    inwood customs
    Dave
    FIFY
    rmepilot and 12TRDTacoma[QUOTED] like this.
  7. Dec 3, 2016 at 7:29 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
