Supercharged 3.4 2001 Spec sheet on fuel trims
Discussion in '1st Gen. Tacomas (1995-2004)' started by BGRED01, Apr 27, 2023.
  1. Apr 27, 2023 at 5:31 PM
    BGRED01
    BGRED01 [OP] Member
    Brian
    01 TRD Radiant Red Magnuson SC
    Magnuson SC 2021 Wheels and tires
    Having a heck of a time getting my fuel trims dialed in on my 01 3.4L TRD supercharged little beauty. Do any of you TRD guys have any data sheets on fuel trims, or anything that will help me get on top of this thing?
  2. Apr 27, 2023 at 6:37 PM
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    Fuel trims should ideally be 0. What are you tuning with?
  3. Apr 27, 2023 at 10:16 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    What are you using to monitor the fuel trims? What are the actual numbers you are seeing for both short term and long term. Remember, trim numbers can be both negative (rich) and positive (lean).
    As Trey implied, are you running a fuel and timing management add-on system? A little history on your SC setup might help here.
  4. May 2, 2023 at 5:01 PM
    BGRED01
    BGRED01 [OP] Member
    Brian
    I bought the truck used with the s/c installed. Mysteries abound with this and that. Trims are -3 on short term, and 19. on the long term. Been looking for a vacuum leak, but now luck. Have had cyl #4 misfire and are looking at checking compression both wet and dry. Don't know if the injectors are stock, factory installed or aftermarket. Will find out soon. Experience no ping on 93+ premium. Shifting isn't an issue. Fuel mileage is crap. Only drive her in town. Average about 50 miles a week. Has 100K original miles. Everything is factory correct inside and out (less the S/C and what I don't know). A good friend of mine is a certified Toyota tech so I'm using his tools, his tech, and his time. Anything you can say will be forwarded to him for consideration. Thanks you guys for being here, and willingness to help.
    otis24 likes this.
