Supercharged 3RZ
Discussion in 'Performance and Tuning' started by JoePacheco, Jan 19, 2014.
  1. Jan 19, 2014 at 3:16 PM
    JoePacheco
    JoePacheco [OP] Member
    Joe
    Usa
    2 inch lift
    I have a 95 with the 2.7 and 4 wheel drive. Im really wanting to give it more power so I've been looking into supercharger kits. I also considered a small block V8 swap but that would be way more worl. I just want to get some more information on what all I would need to do for a supercharger. Someone mentioned that I need to run low compression internals, is that true? And would I need to do anything to the drivetrain or anything? Any thoughts are appreciated.
  2. Jan 19, 2014 at 4:34 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    You wont need to do anything internal, unless you go over 8 psi boost, or so. I supercharged my 2000 2.7, and ran 7 psi boost with no issues at all.
  3. Jan 20, 2014 at 7:49 AM
    VAYoder4167
    VAYoder4167 Well-Known Member
    Frank
    Lynchburg, VA
    Lifted 04 toyota tacoma sr-5
    Magnaflow dual catback exhaust, 5100 bilsteins all around with 1" body lift and stock coils, 33" BF Goodrich sitting on a set of 15" Alloy Ion wheels
    How hard was it too do? How much did it run you in all price range I've been looking at the LCE supercharger? If you have any advice I'd appreciate it?
