Supercharged 3RZ
Discussion in '1st Gen. Tacomas (1995-2004)' started by jbv808, Apr 25, 2018.
  1. Apr 25, 2018 at 11:59 PM
    HamerMan
    HamerMan Well-Known Member
    Andrew
    North Bay Area
    '02 prerunner
    Not racetruck
    Damn, I was thinking like 8 haha.
    Speedytech7[QUOTED] likes this.
  2. Apr 26, 2018 at 4:46 AM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    can ecu be swapped to a newer one like the v6s?
  3. Apr 26, 2018 at 5:40 AM
    jgill21
    jgill21 Not Technically Stock Anymore
    Jake
    Nashville
    98 2.7 TRD PreRunner
    Anyone been dyno’d with the supercharger? 0-60 times?
    US Marine likes this.
  4. Apr 28, 2018 at 12:06 AM
    devinzz1
    devin
    2023 aclb trd or mt
    195-205hp with stock pully
  5. Apr 28, 2018 at 12:59 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Only the late ones 01-03 or so. Wiring changes almost every year for the 3rz. I suppose if you repin everything then yes, but some have more features than others. Like mine has a way different evap system that doesn't have a pressure sensor. I also have three extra VSVs that other 3rzs don't.
  6. Apr 28, 2018 at 1:35 AM
    jbv808
    jbv808 [OP] Well-Known Member
    Josh
    Maui, HI
    White 1995.5 Tacoma 2.7l 4x4
    -Kenwood Single Din Deck, 12" MTX Sledgehammer Sub, Orion 1500 Watt Amp -JBA Catback Exhaust w/ LCE Test Pipe and URD O2 Sensor Simulator -6 Inch Fabtech Lift (Hawaii Style!!) -Revolution Gear and Axle 4.88 Gears Front and Rear -5" Pro Comp Leaf Springs (More like 6"-7") -A340F Auto to W59 Manual Swap -2.5 Radflo Coilovers -JBA Offroad UCA's -Bilstein 5165 Rear Shocks -LC Engineering Headers -HPS Short Ram Intake -LC Engineering High Boost Supercharger w/ 5th Injector, pink top injectors, Walboro 190, Split Second Fuel/Timing Calibrator, AEM Water/Methanol Injected
    So for a simple low boost set up, what are the recommended parts needed to play it safe? I know LCE makes a kit but doesn't include much other than the charger and necessities itself.
  7. Apr 28, 2018 at 5:18 AM
    98tacoma3rz
    98tacoma3rz Well-Known Member
    lancaster, pa
    2002 Double Cab Trd
    I installed a supercharger on my 3rz when it had about 220k miles. Here is what I learned. A compression test and valve check/adjustment are highly recommended to make sure your engine is "healthy". Replace your fuel filter with an oem one if it hasn't been replaced. If your fuel pump is original and you have a lot of miles replace it with a higher volume one. Your fuel pump can weaken overtime and when you add forced induction you need more fuel and an old, weak pump simply cannot fuel enough.
    The stock ecu will do fine on the low boost kit. I found that the pink top injectors from the later model 3rz, paired with a walbro 190 fuel pump, urd 2.5" pulley, one step colder denso iridium, spark plugs, header, performance exhaust all work really well together. I would also highly recommend an air fuel ratio gauge so make sure it's running properly.
    jbv808[OP], cruiserguy and boostedka like this.
  8. Apr 28, 2018 at 5:20 AM
    98tacoma3rz
    lancaster, pa
    2002 Double Cab Trd
    For a low boost setup I would at minimum check compression, check/adjust valves replace fuel filter, fuel pump if it has a lot of miles, spark plugs and make sure you have some sort of intake. A header and higher flowing exhaust will help as well.
    jbv808[QUOTED][OP] likes this.
  9. Apr 28, 2018 at 6:52 AM
    Texasdynaryder
    Texasdynaryder Well-Known Member
    Chance
    Paris, Tx
    Kings Built Engine All the other small goodies
    May I ask what these are? Never heard the terminology.
  10. Apr 28, 2018 at 8:23 AM
    98tacoma3rz
    lancaster, pa
    2002 Double Cab Trd
    A good rule of thumb to follow is for every 75-100 hp you add, you should go one step colder on the spark plug's heat range. Since the added horsepower brings added combustion chamber heat, the colder spark plug will remove that extra heat and help prevent detonation and or/pre-ignition
  11. Apr 28, 2018 at 8:58 AM
    Texasdynaryder
    Chance
    Paris, Tx
    Interesting, thanks for the insight.
  12. Apr 28, 2018 at 10:23 PM
    Stout890
    Stout890 Well-Known Member
    Palmdale ca
    99 prerunner sr5
    10" sub, OME881 on Bilstein's, 3" all-pro leaf springs with billies in the back, JBA UCA's, bed cover with custom LED lighting, k&n intake and DT headers, OEM E-locker in the rear. 32" BFG KO2 on steel D window wheels, suicide knob. rebuilt 3RZ w/ stage 1 cam and balance shaft delete . big 3 mod, all new suspension and body mount bushings. cat back magnaflow exhaust.
    How does a spark plug remove heat?
  13. Apr 28, 2018 at 10:29 PM
    Speedytech7
    It doesn't, colder plugs just have a bigger isolator section to resist heat soak and preignition.
    US Marine and Stout890[QUOTED] like this.
  14. Apr 30, 2018 at 2:05 AM
    jbv808
    Josh
    Maui, HI
    My biggest issue is my truck being automatic and not being able to keep up with the charger if I decide to pull the trigger for one... Don't regret getting my truck but regret not getting a 5-speed.
    jgill21 likes this.
  15. Apr 30, 2018 at 3:37 AM
    #35
    devinzz1
    devin
    2023 aclb trd or mt
    transgo makes a shift kit
    BikerinBlak909 and jgill21 like this.
  16. Apr 30, 2018 at 6:26 AM
    #36
    boostedka
    boostedka Well-Known Member
    James
    NM
    2013 DCSB 6MT, 2004 4runner
    A lot of people will do a valve body upgrade as well as an aftermarket trans cooler.
    jgill21 likes this.
  17. Apr 30, 2018 at 8:48 AM
    #37
    Speedytech7
    I don't think even at 8psi that the 4cyl would have enough oomph to mess with the trans. It is the same trans behind the V6.
  18. May 5, 2018 at 12:44 AM
    #38
    jbv808
    Josh
    Maui, HI
    With that being said i've also read on a few threads that the 95.5-96 tacoma's ecu's don't do well with boost? Any 95.5-96 owners can prove that right or wrong? I considered doing a manual swap or v6 swap but did a lot of research on both and takes a lot of time, money, and patience(ironic because a supercharger is around a couple grand plus at the least lol).
  19. May 5, 2018 at 12:46 AM
    #39
    Speedytech7
    That rule is for the V6, 95.5-97 4cyl ecus are fine with boost, but the later ones can handle more for sure. As it is I am running 6.5lbs just fine, ideally I'll be able to run 10 with just the addition of meth injection and my bigger injectors.
    jbv808[QUOTED][OP] and Dalandser like this.
  20. Nov 6, 2018 at 3:18 AM
    #40
    jbv808
    Josh
    Maui, HI
    Haven't been keeping up with my threads :p lol but thanks for the reply's guys. Just dropped some mulah getting 5-speed swapped into my truck thanks to some great advice and threads from a few members here. Could've got me a low boost kit from LCE I should say :notsure: but loving my truck a lot more now that its a totally different animal but maybe sometime in the future I'll throw a supercharger in it lol :D
    96degreesindashayd likes this.
