Supercharged 3RZ
Discussion in '1st Gen. Tacomas (1995-2004)' started by jbv808, Apr 25, 2018.
  1. Nov 6, 2018 at 6:15 AM
    #41
    Sebz13
    Sebz13 appy polly loggies
    Shane
    Maui Hawaii
    03 Reg Cab, 99 3 Link SC ext cab.
    a dropped one and a high one
    Who did your swap? Also on Maui.
  2. Nov 6, 2018 at 1:28 PM
    #42
    jbv808
    jbv808 [OP] Well-Known Member
    Josh
    Maui, HI
    White 1995.5 Tacoma 2.7l 4x4
    -Kenwood Single Din Deck, 12" MTX Sledgehammer Sub, Orion 1500 Watt Amp -JBA Catback Exhaust w/ LCE Test Pipe and URD O2 Sensor Simulator -6 Inch Fabtech Lift (Hawaii Style!!) -Revolution Gear and Axle 4.88 Gears Front and Rear -5" Pro Comp Leaf Springs (More like 6"-7") -A340F Auto to W59 Manual Swap -2.5 Radflo Coilovers -JBA Offroad UCA's -Bilstein 5165 Rear Shocks -LC Engineering Headers -HPS Short Ram Intake -LC Engineering High Boost Supercharger w/ 5th Injector, pink top injectors, Walboro 190, Split Second Fuel/Timing Calibrator, AEM Water/Methanol Injected
    Sorry bro, can’t say atm but a good friend of mine... don’t want these guys getting blown up because a lot of people been asking. I’ll talk to them and see if they’re willing to do more projects if you’re willing to do the swap too.
  3. Nov 6, 2018 at 5:47 PM
    #43
    Sebz13
    Shane
    Maui Hawaii
    Oh, I already have a 5 speed on both my trucks, haha. Just was wondering if I knew them.
  4. Nov 6, 2018 at 10:52 PM
    #44
    Stout890
    Stout890 Well-Known Member
    Palmdale ca
    99 prerunner sr5
    10" sub, OME881 on Bilstein's, 3" all-pro leaf springs with billies in the back, JBA UCA's, bed cover with custom LED lighting, k&n intake and DT headers, OEM E-locker in the rear. 32" BFG KO2 on steel D window wheels, suicide knob. rebuilt 3RZ w/ stage 1 cam and balance shaft delete . big 3 mod, all new suspension and body mount bushings. cat back magnaflow exhaust.
    Post pics of how they modified the crossmember location for the 5 speed. Im still trying to find the best solution for that.
  5. Nov 7, 2018 at 1:47 AM
    #45
    jbv808
    Josh
    Maui, HI
    Oh I see haha, wouldn't have done it if I couldn't find the parts and my friends were up for the project. Good learning experience for sure but a lot of good advice from some members here too.
    I'll take a pic when I get a chance but basically my buddies welded the manual and auto crossmember together but cut a couple of inches off of each side of one of them so we could bolt the crossmember back up. Idea inspired by @sd_N
  6. Nov 7, 2018 at 1:52 AM
    #46
    Sebz13
    Shane
    Maui Hawaii
    I do have solid mechanic buddies, but for body work I do not, you know anyone solid you could point a fellow tw maui guy too?
  7. Nov 13, 2018 at 2:57 PM
    #47
    jbv808
    Josh
    Maui, HI
