Supercharged engine rebuild
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ak97taco, Jul 18, 2025.
  1. Jul 21, 2025 at 7:53 AM
    ak97taco
    ak97taco [OP] Well-Known Member
    Keegan
    Williston, ND
    2016 Tacoma DCSB
    Exterior 2.5" leveling kit Rocktrix 17" wheels 285/65/17 Yokohama Geolandar's Leer shell Diode Dynamic fogs Morimoto XB Amber headlights Alpharex taillights Body Armor Hiline bumper Prinsu roof rack TRD Pro Grille Caliraised LED 42" amber light bar 2 - bumper light bars and 2 pods behind grille Overland Equipped aux power tray Meso Customs puddle pods with switch Interior LED light kit Meso Customs stealth pro shift knob Oostroma dual latching relay for shift knob Clazzio leather seat covers Clazzio seat warmers Quick charge USBs Dual, amber & white lightbar switch from Cali Raised N2 Designs remote start with app Meso customs interior black out kit AJT Designs interior black out kit Taco Garage DSM phone mount
    I picked up a 31" extension for my 1/2 impact, was able to lower the trans about 2 inches to access the top bell housing bolts no problem. Ready to pull the engine.. not exactly sure how we're gonna sling it to hoist it yet. I did see a video where they bolted brackets to the intake manifold, not sure i like lifting the engine by 4 bolts on top of the engine tho.. ideas?
  2. Jul 21, 2025 at 7:56 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Did you get that monster extension from O'Reillys? After doing one TOB with every extension that I had, which robbed all of the impact hits, that long ass beast made the work so much easier. Saw the set hanging there and knew that I needed it. Haha!
    helix66 likes this.
  3. Jul 21, 2025 at 7:58 AM
    ak97taco
    Keegan
    Williston, ND
    2016 Tacoma DCSB
    Lol no I found one at a local tool store, its legit 31" long, still had enough torque, didn't have to hammer on it, will take a picture soon
    tonered[QUOTED] likes this.
  4. Jul 21, 2025 at 7:58 AM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    I bet those 4 bolts are way more than fine...the 2GR is around 350 lbs or so. I pick up 500 lb Jeep cast iron 6 cylinders with 2 bolts, just one per side securing the chain to the cylinder head.
    jmneill and ak97taco[QUOTED][OP] like this.
  5. Jul 21, 2025 at 7:59 AM
    BLtheP
    Plano, TX
    I bought a set of long 3/8" extensions for my transmission removal...regretted going 3/8". They were twisting a bit before the bolts would break loose. Definitely 1/2" is the way to go.
    ak97taco[OP] likes this.
  6. Jul 21, 2025 at 8:54 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    ak97taco[QUOTED][OP] likes this.
  7. Jul 21, 2025 at 6:01 PM
    ak97taco
    Keegan
    Williston, ND
    2016 Tacoma DCSB
    Ig the dealer actually in fact did not have a block on hand, and/or won't have one, so I found a full engine on ebay, has everything on it for 5k, prolly just gonna get that, dont quite wanna dick around with buying a 80k miles block with no crankshaft, rods, pistons. Just a straight up block. I almost would rather get a used engine with 23k miles and drop that thing straight in and supercharge it.
    Just about got the engine pulled, all we gotta do is take the oil filter housing off and should be clear :thumbsup:
  8. Jul 21, 2025 at 6:03 PM
    BLtheP
    Plano, TX
    For what it’s worth, the short block is a full rotating assembly. It’s the block, pistons, rods, crank all assembled and in a box. What it lacks are cylinder heads, oil pans, timing cover and components, valve covers, etc.
  9. Jul 22, 2025 at 6:50 AM
    ak97taco
    Keegan
    Williston, ND
    2016 Tacoma DCSB
  10. Jul 22, 2025 at 9:14 AM
    RX1cobra
    RX1cobra Well-Known Member
    19 OR
    Damn! Did you put a chain hoist on 1 truss and pull the motor out? You're braver than me.
    WilliamJames likes this.
  11. Jul 22, 2025 at 10:35 AM
    ak97taco
    Keegan
    Williston, ND
    2016 Tacoma DCSB
    Lol we spanned 3 trusses and had 2 4x4s
    RX1cobra[QUOTED] likes this.
  12. Jul 22, 2025 at 10:36 AM
    ak97taco
    Keegan
    Williston, ND
    2016 Tacoma DCSB
    All pulled!!
    casper_sgv, WilliamJames and tonered like this.
  13. Jul 22, 2025 at 10:39 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Looks like a good time for a Tundra steering rack.
    #toosoon
  14. Jul 22, 2025 at 11:41 AM
    ak97taco
    Keegan
    Williston, ND
    2016 Tacoma DCSB
    Pulled the valve covers off, the cam rocker arm was completely briken off.. hmmmm
  15. Jul 22, 2025 at 11:47 AM
    #35
    BLtheP
    Plano, TX
    Broken? They just sit there in top of the valves. It might have been out of place, but the only thing to “break” would be the roller/needle bearings.
  16. Jul 22, 2025 at 12:01 PM
    #36
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    That's wild.
    There was a person recently that found an extra rocker hanging out in there.
    Barsoom and ak97taco[QUOTED][OP] like this.
  17. Jul 22, 2025 at 1:40 PM
    #37
    ak97taco
    Keegan
    Williston, ND
    2016 Tacoma DCSB
    It wasn't broken actually, but def came dislodged from its spot, probably why that particular cylinder overheated?
  18. Jul 22, 2025 at 1:43 PM
    #38
    BLtheP
    Plano, TX
    Odd that it came from out of its spot. Was the engine revved beyond redline? Typically that is what makes these fall out of place. Is the roller seized at all?
    Could definitely be why that cylinder overheated, as you're trying to force all your exhaust air out of half the valve area.
  19. Jul 22, 2025 at 4:13 PM
    #39
    ak97taco
    Keegan
    Williston, ND
    2016 Tacoma DCSB
    I was thinking thats why the cylinder blew up, it had 70psi.. everything else seemed fine
  20. Jul 22, 2025 at 4:15 PM
    #40
    ak97taco
    Keegan
    Williston, ND
    2016 Tacoma DCSB
    Ig now I'm just completely tearing down to look for any signs of the installer messing up, since I got an entire engine coming
    WilliamJames and mistareeman like this.
