Supercharged Striped Tacoma
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jeffhorton, Oct 27, 2013.
  1. Oct 27, 2013 at 3:44 PM
    jeffhorton
    jeffhorton [OP] Active Member
    Jeff
    GA
    Supercharged 2013 4x4 Offroad
    TRD S/C
    Put 12" Silver stripes over my Spruce Mica Tacoma. The front bumper and hood were fairly easy. the tailgate handle area was the most difficult. The 1/4 circles are not easy to cut out and i could not put vinyl in indention b/c of creasing. i have some ideas to make visually better before removing and re-doing all the way.
    there's a 3" gap between the stripes.
    This was my 2nd attempt (former Dakota R/T) of striping a truck, i have plenty more material to redo some mistakes.
    Have not decided on roof top yet. may leave that part alone.
    Thought i'd share.
    2013 Tacoma 4x4 S/C
  2. Oct 27, 2013 at 3:54 PM
    jmg256
    jmg256 Calmer than you are
    Al Tonter
    TRD Offroad
    Bilstein 5100 front/rear (front at .85), Hayden 678 Trans Cooler, 20% tint, Curt Hitch/Wiring Harness, Weathertech Digital Fit Floor Mats (Black), Wet Okole Seat Covers (Black), Cooper Discoverer ATP 265/75/16, LED Map/Dome lights, ImMrYo bracket, Debadged, Extang Tuff Tonno.
  3. Oct 27, 2013 at 3:55 PM
    ChamYota
    ChamYota Crash Bandicoot Or Groot AKA Cham "Scottalot" Yota
    Cam
    Columbia,South Cakalacky
    05' Taco 4x4 swapped/ 2007 Toyota Land Cruiser
    H1 Morimoto projector with XB35 4300K bulbs with Mini-gatling gun shrouds, BHLM. Debadged,OEM roof rack,TW sticker,Sockmonkey Beside decals,265/70/16 Nitto terra grapplers with dick cepek DC'2 wheels,weathertech floor liners(front/back),USA Spec Ipod reader,Scanguage II,Bestop Supertopper and more in the works...
    Im not a fan but whatever floats your boat! :D
    Looks.. Different. Its not something that everyone does.
  4. Oct 27, 2013 at 3:56 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    I like it.
    Leave the roof. Wrapping the rear of the cab will be worse than the tailgate.
  5. Oct 27, 2013 at 3:56 PM
    Dizo
    Dizo Well-Known Member
    Oliver
    North of 62°, Canada
    2005 DCLB TRD Sport
    Aux Audio-input, 5100's @ 1.75", 2" Wheeler's AAL, LED Underhood Lighting, Anytime ABS-Off Switch,
    Looks ... like a dodge.
  6. Oct 27, 2013 at 3:57 PM
    TripleThreat
    TripleThreat Vance@freevancewriting.com
    They keep callin me cowboy but its not my name...
    Socal but I am still a southern Florida guy
    Toyota Tacoma 4x4 slightly modified
    nothing special.... wanna race?
    Nice job on your truck mod I don't see alot of trucks with pin stripes. Let us know what your next mod is!
  7. Oct 27, 2013 at 3:59 PM
    Loco38SUP
    Loco38SUP Well-Known Member
    North Seattle, WA
    2011 Double Cab SR5 4X4
    Loud as hell URD exhaust!
    I think it looks good. :thumbsup:
    You should definitely do the cab.
    RJM
  8. Oct 27, 2013 at 4:10 PM
    novanut21
    novanut21 Well-Known Member
    Brent
    North Central,WV
    2009 TRD SPORT
    AFE CAI, Magnaflow cat-back, TRD S/C, TRD Quickshifter, URD Fuel Pump Kit, Wet Okoles Front&Rear, WeatherTech Mats, Sockmonkey Decals, Satoshi grille, JBA "shorty" headers, URD Y-Pipe, TTC Oil Catch Can, Lotek Dual Apillar gauge pod w/ Autometer Phantom II AFR & Vac/Boost, URD Pulley, HID Retrofit.
    I like the idea. I would like to see some flat black stripes. Good work!
  9. Oct 27, 2013 at 6:34 PM
    AEmedic
    AEmedic Well-Known Member
    Boise, ID
    2014 DCLB 4X4 TRD Sport Supercharged
    TRD Supercharger, Toytec Adj. Coil-Overs, Bilstein 5100's, JL Audio system w/Kenwood DNX9980HD HU
    Looks interesting!
  10. Oct 27, 2013 at 7:21 PM
    mikebuyscars
    mikebuyscars Well-Known Member
    Fenton, MI
    21 Toyota Tacoma double cab TRD Off-Road Voodoo Blue
    2 inch lift
    I will try to say this with the utmost respect: YUCK! I figure you are asking for opinions since you put it on here. If you want an opinion, I say if you really want stripes, get another Dakota. For some reason it looks ok on a Dakota, but I can't stomach it on a Tacoma! Good luck!
  11. Oct 27, 2013 at 7:27 PM
    RearViewMirror
    RearViewMirror Saw things so much clearer once you... were in my
    Craig Christ
    State of Love and Trust
    2023 Subaru WRX GT
    If I were going to stripe it (admittedly you didn't ask nor would I ever dream of striping mine) I would have put about a 6" stripe more to the drivers side with a 3" stripe parallel to it over the hood, roof, and tailgate. It wouldn't take up so much real estate on the truck and would look more classic I would think. Something else to consider with vinyl is to clean the area (obviously) and then spray the area that you are going to apply the vinyl to with a spray bottle filled with water and a small amount of soap. This allows you to move the vinyl into the position that you want. Use a squeegee to remove the water from underneath the vinyl and you are good to go.
    As far as curves go... use a heat gun (hair dryer works but is slower) to mold the vinyl into those hard to fit places.
    As it sits right now I'm not a fan but it's your truck and if you are happy that is all that matters. :)
  12. Oct 27, 2013 at 7:57 PM
    jeffhorton
    Jeff
    GA
    TRD S/C
    thanks for the positive and negative replies back. i do understand stripes are not for every one or every vehicle, but i'm very pleased with the results. thanks!
  13. Oct 27, 2013 at 8:03 PM
    RearViewMirror
    Craig Christ
    2023 Subaru WRX GT
    That's all that matters. Looks like you did a good job putting them on.
  14. Oct 27, 2013 at 8:10 PM
    Lord Helmet
    Lord Helmet Prepare To Attack
    Nick
    '24 GX550 Overtrail+
    I'd remove the front bumper stripe. Looks better without it. Everything else looks good. Do what you like :thumbsup:
  15. Oct 27, 2013 at 8:10 PM
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Bethel Park, PA. Burb of da Burgh.
    2010 MGM Mostly Stock Off-Road 4x4
    TRD Cat-back Exhaust. Semi-Debadged. Trimmed down stock Antenna. Weathertech vent visors. TRD FJ Cruiser Center Cap Wheel Mod. 265/75/16 Firestone Destination A/T,s . Inverter tapped into for outlet in cab. Tacomaworld sticker which adds 5 hp.
    I like it more than I thought I would. To be honest, the part I don't like is on the bumper. If it was me, I'd just leave the hood and tailgate, and take it off the bumper.
  16. Oct 27, 2013 at 8:18 PM
    ToyotaKTMracing
    ToyotaKTMracing The Blue Warrior
    Shay
    West Virginia
    2008 DCSB Ink 4WD Auto
    285 BFG ATs, Custom dual exhaust system, 4" total lift (adjustable billies with 885 coils in front and AALs with 1" block in rear), interior LED lighting, LED reverse lights, LED license plate lights, fog light anytime mod, JVC KW-R500 stereo, 20" okledlightbars.com LED light bar, coverking seat covers
    This. I actually like it. I probably wouldn't do it (mainly because I suck at putting large vinyls on something) but I think flat black would look decent too.
  17. Oct 27, 2013 at 8:37 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    Wrong livery.
    Mustangs and Vipers carry racing stripes because old American race cars had them. Toyota race cars (and trucks) never had the two racing stripes:
  18. Oct 29, 2013 at 11:18 PM
    Dragons Taco
    Dragons Taco Well-Known Member
    Derek
    Cary/Raleigh NC
    06 Black TRD-S 4WD 4D 6SPD and MINE!
    Can ya spell Tonneau
    I wouldn't do the roof if I were you. Too many paint problems listed.
    I had stripes, and now I have 2 stripes of rust on the roof.
  19. Oct 29, 2013 at 11:38 PM
    benbacher
    benbacher Purveyor of Fun Vendor
    Anchorage, AK
    '10 Tacoma 4x4 LBDC SR5 TRD Sport
    Too many to list now.
    Huh, I like it actually. Nice job!
  20. Oct 30, 2013 at 4:38 AM
    ATHiker
    ATHiker Well-Known Member
    Tom
    Tennessee
    15 Tundra DC 4X4 SR5 OR 5.7L
    I agree. I like it except for the front bumper.
