Supercharger Advice
Discussion in '1st Gen. Tacomas (1995-2004)' started by chaosrob, Jan 1, 2017.
  1. Jan 1, 2017 at 8:39 AM
    chaosrob
    chaosrob [OP] Well-Known Member
    Disregard please
    License2Ill likes this.
  2. Jan 1, 2017 at 8:45 AM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    Oil is a no brainer.
    7th kit is a good investment if you have the money
    chaosrob[OP] likes this.
  3. Jan 1, 2017 at 8:57 AM
    kigmob
    kigmob Well-Known Member
    James
    New Orleans
    97 TRD S/C 4x4 V6 5spd
    ICON/TC TRD Supercharger URD 2.2 and 7th
    New belt and make the idler pulley is ok.
  4. Jan 1, 2017 at 12:18 PM
    CD20H
    CD20H Well-Known Member
    Ben
    North Texas
    2004 Double Cab TRD 4x4 Limited
    Magnuson Kompressor, OME lift kit, JBA Headers, junky Sony radio.
    Sounds like you have good plan. See the little vacuum port at the top of the picture.....make sure you cap that. I didn't and I had a P0171 code that I chased for 3 days. I think it is for a boost gauge.
    Also, put a good quality set of headers on your list to things to "get". The log type exhaust manifolds are shitty and do not flow enough to get the true benefit of the supercharger.
  5. Jan 1, 2017 at 12:22 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    Is that for a 2.7l? It looks different from the 3.4's supercharger.
  6. Jan 1, 2017 at 1:23 PM
    devinzz1
    devin
    2023 aclb trd or mt
    Looks like every other 2nd gen 3.4 charger ive seen?
  7. Jan 1, 2017 at 1:24 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    I guess you're right.
  8. Jan 1, 2017 at 4:43 PM
    CD20H
    Ben
    North Texas
    Ultimately you want the TRD headers. Toyota does not make them anymore.
    Doug Thorley makes some very nice ones....but they are expensive
    OBX makes some nice one also, but rumor has it they have had fitment issues in the past. They are a lot cheaper in price, but I don't know about the quality.
    JBA has the same reputation as OBX with the fitment issues.
    I am in the market for some headers also. I will probably go with the Doug Thorley's.
  9. Jan 1, 2017 at 4:44 PM
    02hilux
    Planet: EARTH
    I'll invest into the 7th injector first, header and cai
  10. Jan 1, 2017 at 4:47 PM
    02hilux
    Planet: EARTH
    DT header leaks. I need a few guys with it and always have to adjust them. Don't buy ebay junk, my personal opinion. TRD are good are very small tubing. JBA are good, nice size tubing and use 3 bolt pattern flange
  11. Jan 1, 2017 at 4:51 PM
    02hilux
    Planet: EARTH
    Must have not read about your 7th kit.
    Header will be a good investment...
  12. Jan 1, 2017 at 4:58 PM
    Clay_916
    Clay_916 Well-Known Member
    Fort Collins, CO
    2000 x-cab 4x4
    5100's, All Pro 3" Standard leafs, 32" KM 2's
    Thorleys are the best. Jba are trash they leak and have tons of figment issues. Depending on your mech skills you'll get much better performance from a set of bigger injectors and a piggyback like a fic 6. Depending on your ethanol bias you can get crazy gains running e85 with the sc. methanol injection is great too. Relatively cheap and reliable IMO but most wouldn't agree.
    If you're set on the 7th I'd also consider the URD afr calibrater. The 7th alone has no closed loop fuel management what so ever and these trucks are in CL for 95% of driving.
  13. Jan 1, 2017 at 5:00 PM
    TashcomerTexas
    TashcomerTexas My truck is a whiner
    2003 TRD DC Supracharged
    The 2.2 pulley will really help. Do you know the last time the s/c was serviced?
  14. Jan 1, 2017 at 5:06 PM
    02hilux
    Planet: EARTH
    Want to see final product
  15. Jan 1, 2017 at 5:09 PM
    TashcomerTexas
    Really there's no way to tell from smell on these. But I'm more referring to the bearings, seals, and needle bearings in the rear of the housing. Personally I would service it all before putting this all together otherwise you'll need to take the s/c off along the way when it really needs the service.
  16. Jan 4, 2017 at 9:25 AM
    chaosrob
    Well after going ahead with a full rebuild and porting on the Supercharger I just got word from URD that they do not have the 7th injector kits in stock so I asked for a refund and will be going bigger injectors and throwing on a Haltech I have had sitting here in the box for awhile. Not a fan of Standalone ECU's on a truck I plan to use as a DD but such is life
  17. Jan 4, 2017 at 10:31 AM
    Clay_916
    Fort Collins, CO
    2000 x-cab 4x4
    You'll be way happier IMO. The 7th injector only really helps at WOT which, why bother with a sc.
  18. Jan 4, 2017 at 10:59 AM
    chaosrob
    well the way I read the new 7th injector setup was that you could also control fuel and ignition timing with it. If that is the case it seems like it would be somewhat simple to retard the timing a bit where it is detonating and/or add fuel.
  19. Jan 4, 2017 at 11:01 AM
    Clay_916
    Fort Collins, CO
    2000 x-cab 4x4
    All the extra fuel will get trimmed out in closed loop. You really need an afr/o2 skewing device to control closed loop fueling.
  20. Jan 4, 2017 at 11:03 AM
    chaosrob
    gotcha, thanks
