Supercharger and CAI
Discussion in 'Performance and Tuning' started by jfs6398, Apr 5, 2012.
  1. Apr 5, 2012 at 7:12 AM
    jfs6398
    jfs6398 [OP] New Member
    Pennsylvania
    '09 TRD OFF-Road S/C
    S/C, TRD Cat-Back Exhaust, K&N CAI, TRD Rims, TRD Quick-Shifter
    I recently had a supercharger installed on my 2009 Tacoma, which has a K&N CAI. The service rep said that Toyota doesn't recommend using a CAI with a S/C, but he could not explain why. I saw other threads that had both installed. Does anyone know the reason for this?
  2. Apr 5, 2012 at 7:25 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Because the carbon filter is probably removed, could be one reason. Simply that in states like Cali, that might make it non CARB approved.
