Supercharger/Armor and HIGH Heat, How to cool it??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TACOconvert2012, Jun 21, 2016.
  1. Jun 22, 2016 at 11:06 AM
    #41
    TACOconvert2012
    TACOconvert2012 [OP] My truck hates you. My wallet hates you.
    Socal
    SC'd 2012 MGM TX/Pro 4x4
    never ending..
    I go
    I go to a local car wash and use their light pressure mode with a wand and spray through the radiator. I don't see a ton of mud so that isn't an issue. I inspect the radiator for bent fins and the such during washings as well.
  2. Jun 22, 2016 at 11:08 AM
    #42
    TACOconvert2012
    Socal
    never ending..
    I am just running the 50/50 mix from toyota for both the charger and the rad. Thought about the mixture but never experimented with it in the past. I'm in socal so freezing temps are few and far between. Usually hotter here.
  3. Jun 22, 2016 at 11:13 AM
    #43
    2015WhiteOR
    2015WhiteOR Well-Known Member
    Gainesville TX
    I tried looking on your profile for pics of your truck but couldn't find any.
    Would you mind posting some pics of your front end and also in the engine bay? Maybe we can identify something that you need to change.
    Also - You can do a test for us since you have a scangauge. Next time you go for a drive, monitor the engine temp. These trucks come with a 190*F thermostat, so when you're just driving around town, you should eventually see the engine temp stop at 190 and sit around the for the most part. It may fluctuate up a little bit but shouldn't exceed 200*F.
    digitaLbraVo likes this.
  4. Jun 22, 2016 at 11:17 AM
    #44
    digitaLbraVo
    digitaLbraVo Derka Derka
    Covered in stickers and chrome stick-ons for extra horse torques and foot powers. Icon sticker gets me tons of travel, dozens of milimeters.
    It sounds to me like you aren't getting air to your existing cooling components.. or they aren't functioning properly.
    Chemistry tells us it is A LOT harder to heat up something the hotter it gets and the fact is if it's 90 or 100 or 110 *F outside the engine is still quite a bit warmer and so 100 degree air is quite nice at that point*. You said ARB bumper, plate right? You may be restricting fresh air from getting in.
    *Consider, you're 98-ish, right? 45 degree air is fucking cold.
  5. Jun 22, 2016 at 11:20 AM
    #45
    TACOconvert2012
    Socal
    never ending..
    Snapping a few pics really quick on my lunch break. Around town temp stays about 198 200s when sitting and idling for long periods.
  6. Jun 22, 2016 at 11:21 AM
    #46
    TACOconvert2012
    Socal
    never ending..
    Front bumper is pelfrey
  7. Jun 22, 2016 at 11:22 AM
    #47
    digitaLbraVo
    Hm it looks plate in your avatar, right?Ther's none on your profile that show it well.
  8. Jun 22, 2016 at 11:24 AM
    #48
    2015WhiteOR
    Gainesville TX
    Seems a smidge high. My guess at this point is you've either got insufficient air flow or the thermostat is faulty.
    You can grab one of these next time you're at the auto parts store to check if your coolant is chemically still OK. https://www.amazon.com/Prestone-AF-1420-Antifreeze-Coolant-Tester/dp/B000BOA9RY
    RogueTRD and digitaLbraVo like this.
  9. Jun 22, 2016 at 11:24 AM
    #49
    TACOconvert2012
    Socal
    never ending..
    Phone acting weird I think the photos are attached. Now no flaming because of dusty motor. My op said I JUST got back from my trip haven't cleaned her up yet. If they don't post give me a few to get back to my desk and I can upload
    Edit:not seeing photos on my end on my phone. Be back to my desk in a few
  10. Jun 22, 2016 at 11:30 AM
    #50
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    When checking your rad, a common place to look is between your rad and A/C heat exchanger. As much as possible, recommend you don't drive it as an overheating engine will ruin your day. Head gasket replacements are not fun or cheap.
    12TRDTacoma likes this.
  11. Jun 22, 2016 at 11:32 AM
    #51
    TACOconvert2012
    Socal
    never ending..
    yeah, that is why I am hoping I can get a little more insight into what I might be lacking when it comes to cooler here. This is my only vehicle and I have to drive her. Now that I am home and just doing my usual driving I am not seeing the what I considered crazy high temps.
  12. Jun 22, 2016 at 11:33 AM
    #52
    digitaLbraVo
    Do you have a tow package/tranny cooler?
  13. Jun 22, 2016 at 11:34 AM
    #53
    TACOconvert2012
    Socal
    never ending..
    yes sir
  14. Jun 22, 2016 at 11:34 AM
    #54
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    If the rad is clean of dirt/mud, I would do a drain and flush. While Im at it, I would check/replace the thermostat. Again, these temps are not normal even with the mods you've made on your truck. There is something wrong with your cooling and we need to troubleshoot.
    To keep the engine running as cool as possible (your gonna hate this), open your windows and blast your heater on the highest setting. Don't use the A/C!
    Edit: A way to trouble shoot flow/thermostat issues is check the temp on the upper and lower radiator hose after the engine warms up. They should be the same. If one is hotter than the other, you have a flow issue.
  15. Jun 22, 2016 at 11:35 AM
    #55
    TACOconvert2012
    Socal
    never ending..
    lmao I am a polar bear and these socal heats are killing me... blasting heat feels like hell on wheels hahaa :bananadead:
  16. Jun 22, 2016 at 11:36 AM
    #56
    TACOconvert2012
    Socal
    never ending..
    waiting for email to come through on my work computer... takes time due to security.. posting as soon as they come through.
  17. Jun 22, 2016 at 11:36 AM
    #57
    gottaToy
    gottaToy Well-Known Member
    JJ
    movin' on up to the east side
    1985 Moped
    Rancho RS66903R7 @2.5", 2x4 block in rear. strait pipe, 37" super swampers
    Good chance you are just making mud and packing it farther into the radiator. proper cleaning would be from the back side, as the dirt come in the front and gets trapped. With the intercooler, trans cooler, condensor, and radiator all together no way you are getting it clean. Plus, behind the winch on the plate bumper is where things really collect and it is really hard to get it clean back there. I waste a lot of water flushing mine out every once in a while. it is quite the pain in the ass to really get it clean with a plate bumper, winch, and lightbar on there.
  18. Jun 22, 2016 at 11:37 AM
    #58
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Haha, heard that. My old 1980 Tercel used to overheat and I didn't have a choice. In fact, I didnt even have A/C. Black Pleather seats didn't help either!
  19. Jun 22, 2016 at 11:41 AM
    #59
    digitaLbraVo
    Going through hills and such is going to heat your transmission up a lot and the tranny cooler is the little quarter sized radiator in front of the AC condenser behind the grille. Extra heat was likely coming off that reducing the already low amount of cool air making it to the actual radiator.
  20. Jun 22, 2016 at 11:46 AM
    #60
    TACOconvert2012
    Socal
    never ending..
    yeah, when I took it to Toyota for a rear main seal leak I told them to check the AC system due to how it would start blowing humid hotish air when parked or idling for long periods in traffic. they said the AC system was fine, but the extra charger cooler was restricting too much air flow. which after taking a harder look at it I thought to myself well... that could be logical.. but why would they offer this system if they hadn't tested those types of functions. main reason I am looking to the far more experienced minds on here. I had seen a thread on a guy adding another trans cooler inline with the existing ones and having great results per his posts, but my worry is... I would be adding yet another rad/cooler in the front blocking more airflow to the engine rad and AC condenser.
