SuperCharger Boost Numbers..?
Discussion in 'Performance and Tuning' started by AWF ROWD, Nov 1, 2013.
  1. Nov 13, 2013 at 7:43 PM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    Some of us had the bung welded in the y pipe after it merges to 1 pipe and just before the exhaust flange.
    Works for me.
    Exhaust is very open here and like I posted before, still pulls 6psi normally (I'm usually at 800ft above sea level). At same altitude at night its pulled 6.5
    When at sea level or lower on a cold night she pulls very hard.... At least the butt dyno says its pulling like a freight train.
  2. Nov 13, 2013 at 8:53 PM
    AWF ROWD
    AWF ROWD [OP] ...eats at the " Y " often....
    Doc
    40.102° N, 82.804° W
    '13 BLOWN 4X4 Sport
    TRD Supercharger, Walbro 255 FP Upgrade, aFe Stage 2 si CAI, TRD Acrylic cover by Coupe ADD 1 OIL Catch can/SS hoses, TRD cat back exhaust, URD 2.8" Stealth pulley, 3" lift, Toytec/Bilstein C/O's, Toytec Progressive AAL's, LR UCA's, 5100 Rear Billies, Bi-Xenon HID BHLM Retro's w/ Halos RED LINE Tuning Hood Rods Swaybar Relocate, Line X'd Bull Guard/Step, Hitch, Craven Speed Dual Gauge mount, AEM Boost/AFR Gauges, Windows 20% tint, Weather Tech deflectors, GrillCraft upper and lower, Tacoma Raptor letters, LED Interior/Exterior lighting, Lund 6" Color Matched Oval Side Bars, Webasto 700 II sunroof, Heated Two toned custom leather TRD logo'd, Kenwood Multimedia 6990 HD head unit ,JL Stealthbox sub, Hertz Component speakers,, Entire cab damped with hushmat, Viper Security/Remote start, Weather Tech Liners, Blackened exterior LED Lights, Undercover Top w/LED's, Carbon fiber TRD windshield decal,, TRD stitched leather shift knob, TRD steering wheel emblem,
    Same ..Bosch 4.2
  3. Nov 13, 2013 at 9:20 PM
    Amo-cat3
    Amo-cat3 Wizard Sleeve Master
    Maui, Hawaii
    07 TRD Blown dubcab
    TRD Supercharged 4.0 w/ 2.5" Quick change Pulley, UCON EMS, URD 7th injector, AFE Stage II intake, DT Longtubes, MBRP 2.5" dual exhaust w/ Vibrant Ultra resonator, URD Y-pipe w/ vibrant v-bands (Cat free), Walboro 255 fuel pump, SS Oil catch can, Aeroforce gauges, Icon CDC 2.5 coilover set at 3", 1.5" Wleelers Progressive aal, Light racing uca, 17x8.5 Fuel Anza 4.5" backspace/-6 mm offset, Kelly Safari a/t 265/70/17, scanguage 2, AMP electric steps, bed extender, Low-pro tonneau cover, 20% tinted windows/headlights/taillights, tacoma seat covers, Image dynamic sound system w/ Pinoneer avh3200 head, assrtd stickers................
    Here on Maui on a cold morning at ground zero sea level i can push 8 psi. I've got no cats and full open exhaust (2.5" back pipe) plus i got my apr x1 in the mix. Sorry no video proof Yet!:D
  4. Nov 13, 2013 at 9:20 PM
    TRON
    TRON Well-Known Member
    All Wheel Drive X-runner
    TRD Blower, 2.3 Pulley, NST OverDrive Pulley Kit, B&M Shifter, TR Lowering Kit, Spec Clutch, Xrunner Body Kit
    Changing out the catback on our trucks has minimal hp gains and will not effect boost compared to changing out the exhaust manifolds and/or ypipe. Those two are much more restrictive and therefore more power can be made with aftermarket free flowing designs. Boost is relative; MAF makes real power.
    If the AFR sensor is having to read though the stock cats in the ypipe; then the AFR guage will be less accurate.
  5. Nov 13, 2013 at 9:33 PM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    Trust me...... The truck is far from stock
  6. Nov 14, 2013 at 7:14 AM
    TRON
    ^^^ Nice!!
  7. Dec 8, 2017 at 1:12 PM
    HBMurphy
    HBMurphy Ban Pending
    Paul
    So California Coast
    09 Off Road Delete Model
    None
    I've had a bower for a number of years. Today I thought I would check to see what kind of boost my ECU is reporting 33.1 psi to my Torque app! Lol
  8. Jan 20, 2018 at 7:53 PM
    1997tacomav6
    Denver
    All depends on your altitude, sea level or Denver at 6500 feet will vary
  9. Jan 20, 2018 at 8:12 PM
    HBMurphy
    Paul
    So California Coast
    None
    I live at sea (and also seal) level and if my standard setup is producing more than two atmospheres of pressure, I will eat an over oiled K&N filter.
  10. Jan 27, 2018 at 6:37 AM
    tfeltz73
    tfeltz73 That's greasy Ricky
    central Wisconsin
    2013 supercharged long travel thing
    I get 5-6 with the 2.8 pulley and open exhaust. I plan to move to the 2.55 and the ucon once all the new suspensions paid for so I can still beat my brothers jcw Mini Cooper he keeps modding to beat my truck on the drag strip. :)
  11. Jan 28, 2018 at 8:20 AM
    HBMurphy
    Paul
    So California Coast
    None
    One way to make a small fortune from racing is to start with a large one.
    tfeltz73 likes this.
  12. Sep 27, 2018 at 3:40 PM
    2013 Blown Baja
    2013 Blown Baja Member
    Blower, sliders, Snugtop, Bedslide, more coming!
    I know this is an old post, but I need some help.
    Where do you tap into the TRD blower for boost pressure for a gauge?
    Much appreciated!
  13. Sep 27, 2018 at 3:43 PM
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    There's a "nipple" on the back of the blower that will most likely have a red cap on it. You shouldn't be able to miss it!
    Torspd likes this.
  14. Sep 28, 2018 at 4:40 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    To the rescue!
    memario1214[QUOTED] likes this.
  15. Sep 28, 2018 at 5:34 AM
    #35
    AWF ROWD
    Doc
    '13 BLOWN 4X4 Sport
    Nipple FTW....
  16. Sep 28, 2018 at 7:07 AM
    #36
    memario1214
    Colton
    Missoula, MT
    They tend to treat me well
    BassAckwards likes this.
