Supercharger Boost Problem
Discussion in 'Technical Chat' started by SeekingZero, Jan 20, 2017.
  1. Jan 20, 2017 at 1:23 PM
    SeekingZero
    SeekingZero [OP] Well-Known Member
    Ben
    Sierra Mountains, CA
    01 Xtracab 4x4 SR5 TRD Supercharged
    Hey folks,
    I just did a weekend trip to Tahoe, and as soon as the truck got to elevation, something happened with my S/C. I figured it was a loss of boost due to the elevation even though it was drastic and that it would go away once I got back. Unfortunately it didn't.
    Right now, the S/C operates normally up to 0 PSI. Once it gets to 0 PSI, it stops and I get no more boost. If I run the truck WO throttle, as soon as my RPM reach around 4-4500RPM, the boost kicks in fully at about 8 PSI.
    Any thoughts on what happened? The belt seems the right tightness and I don't hear any squealing or slipping.
    This is a Black Gen 2 Supercharger on a 2001 3.4 V6. Truck has 148k, supercharger has 128k, and was just rebuilt a month ago.
  2. Jan 20, 2017 at 1:25 PM
    mightytacoman
    mightytacoman Mighty-known Member
    Kel
    4.5L 1grfe
    Brian Crower stroker kit, Carrillo pistons moly/ceramic coated, BC sportsman rods, arp s2000 head bolts, Darton M.I.D sleeves, Kelford race cams, Magnusson supercharger, hp tuner tuned, 650cc flow matched fuel injectors, CSF radiator, Walbro 255 fuel pump. pulleyboys quick change pulley with 2.3", fpr mod, NST crank, water and alternator pullies, 160° mishimoto thermostat. Puma On-board air, Radflo CDC ext coilovers with 14" 700# springs, extended length rear Radflo shocks with CDC, Dakar leak pack, Brute Force Fab front bumper galvanized and powder coated, DTRL mod, yellow fogs, fog anytime mod, relocated rear differential breather, synthetic fluids, custom airbox, tundra sized intake. 76mm throttle body, secondary air filter removed, Airflow snorkel, 4x innovation sliders powder coated, URD equal length headers, DT y-pipe, Aero-Turbine 2525xl exhaust dumped over axle, seat belt chime disabled, Warn 8000i winch, 1- 20" slim light bar in grill, 42" curved roof light both with custom brackets. Mesh grill, Brute Force Fab rear bumper with extra reverse lights, u bolt flip kit, SS extended brake lines, hockey puck bump stop extension, AT shackle flip kit, Light Racing UCA's, 4crawler 1.5" bodylift. custom built front and mid skid plates, re-geared to 4.56s, windows tinted 25%, Sony stereo, 8" skar sub-woofer, 1000 watt mono amp, retrofit headlights with legal demon eye, Kryptek Marathon seat covers. North Star agm 27f battery, Helo 791 rims, 315/75/r16 Mt/r ARB front air locker
    ummmmm. So it goes to 0 from vacuum then jumps to 8 psi at the stated rpm? ya pull the negative to see if that helps reset the problem. subbed for outcome
  3. Jan 20, 2017 at 1:26 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    Pull the neg cable for a bit
  4. Jan 20, 2017 at 1:43 PM
    SeekingZero
    Ben
    By negative, you mean the battery cable?
  5. Jan 20, 2017 at 1:45 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    You sir, have a clogged cat
  6. Jan 20, 2017 at 1:52 PM
    SeekingZero
    Ben
    Aww, don't tell me that! I have two flowmaster hi flo cats that are only two years old... It better not be that!
  7. Jan 20, 2017 at 1:56 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    Unbolt the exhaust on the flange before the first cat and slide it out of the way. Go for a quick test drive and see. It will be lout af, but easy diagnostic.
    I only say it's the cats because you are describing exactly what happened to mine. There is no reason you should be boosting 8 psi unless the cats are clogged enough to increase manifold pressure.
    loginfailed likes this.
  8. Jan 20, 2017 at 2:01 PM
    SeekingZero
    Ben
    Argh! You better be wrong! I try it tonight when I get home.
  9. Jan 20, 2017 at 2:05 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    If it's not that, there's really only a couple other possibilities. Could be vacuum leak or the vacuum bypass actuator is about to shit the bed.
  10. Jan 20, 2017 at 2:11 PM
    SeekingZero
    Ben
    I do boost 8 psi at WO normally, but not from 0 straight to 8. I figured you were speaking from experience so I'll see what I can find out.
  11. Jan 20, 2017 at 2:14 PM
    mightytacoman
    Kel
    4.5L 1grfe
    I had a clogged cat and was getting cylinder misfires and certainly wasn't able to get up in engine load or rpm.
  12. Jan 20, 2017 at 2:15 PM
    SeekingZero
    Ben
    What negative were you talking about pulling?
  13. Jan 20, 2017 at 2:15 PM
    mightytacoman
    Kel
    4.5L 1grfe
    battery cable to reset in the event the problem was electrical
  14. Jan 20, 2017 at 2:18 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    Boost is mechanical, not electric. ECU reset can reset fuel trims and timing retard. But the factory ECU only allows for 7 degrees of retarded and certainly won't cause a boost lag and sudden burst of boost to 8 psi.
    ramonortiz55 likes this.
  15. Jan 20, 2017 at 2:21 PM
    wheeliest
    wheeliest ///////////////////
    Json
    TMPE AZ
    05-SWB-DCSB-4X4-V6-SR5-SPORT
    NO SWAYBAR, Spacer lift with dirty4's
    What are the chances the bypass valve is stuck open?
    jberry813 likes this.
  16. Jan 20, 2017 at 2:25 PM
    mightytacoman
    Kel
    4.5L 1grfe
    Good point. So I guess my advice is null and void OP. The ecu doesn't allow you to go full retard
  17. Jan 20, 2017 at 2:26 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    Also a good test OP. I zip tied my bypass valve closed and went for a test drive in my troubleshooting.
  18. Jan 20, 2017 at 2:55 PM
    SeekingZero
    Ben
    What is the reaction I should get when driving with it closed?
  19. Jan 20, 2017 at 2:57 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    No boost lag. The bypass acutuator is vacuum based. Meaning under vacuum, the valve allows some air to be recirculated rather than forced into the intake. Under boost, the valve closes and directs all air into the intake.
    mightytacoman likes this.
  20. Jan 20, 2017 at 2:58 PM
    mightytacoman
    Kel
    4.5L 1grfe
    It should boost up accordingly with your rpm if zip tied closed
    edit: dammit jberry you beat me to it
