Supercharger break in?
Discussion in 'Performance and Tuning' started by Foozer, Jun 11, 2014.
  1. Jun 11, 2014 at 1:49 PM
    Foozer
    Foozer [OP] Well-Known Member
    Utah
    2021 TRD Pro - MGM
    265/75/16 BFG KO2
    Just got the TRD S/C on my 2012 4.0L auto. I am a little disappointed as I can't seem to break traction and spin the tires on launch. I was wondering if there is a break in period for the S/C or if anyone had any tips on how to roast the tires a little with the S/C.
    I live in Utah at about 4,500ft elevation so that probably doesnt help either.
    Thanks!
  2. Jun 11, 2014 at 4:20 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Does the truck start to break traction, then stop being able to? As if it is losing power?
  3. Jun 11, 2014 at 4:23 PM
    hmcclung
    hmcclung Well-Known Member
    Heath
    St. Louis
    14 Superwhite S/C DCSB TRD OR
    I have read many comments on how it sometimes takes a while for the ECU to fully accept the new reflash
  4. Jun 11, 2014 at 8:24 PM
    Jefes Taco
    Jefes Taco Well-Known Member
    Denver, CO
    14' DCLB TRD Sport supercharged
    Mine seemed to get more power after a thousand or so miles after install. But mine was also installed w/ only 800 miles on the ODO.
    I can break traction but not light 'em up. At least I haven't really tried after I initially broke traction. I've been able to power brake it at a stop. But since it's a truck and light in the rear to begin with, I was never really too impressed with either of those.
    I'm thinking it will get better w/ some miles as that is what most have stated after installing the supercharger.
  5. Jun 11, 2014 at 8:33 PM
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    When I initially put the S/C on at 5500 feet I couldn't roll my big mud tires. You should be able to spin stock ones with a good brake boost no issues. Does the truck feel noticeably more powerful all the time? There is no "break-in" on the S/C.
  6. Jun 12, 2014 at 2:00 PM
    Foozer
    Utah
    2021 TRD Pro - MGM
    265/75/16 BFG KO2
    Not really, it just launches quickly but doesnt really lose traction at all. Why do you ask?
  7. Jun 12, 2014 at 2:05 PM
    Foozer
    Utah
    2021 TRD Pro - MGM
    265/75/16 BFG KO2
    I dont have stock tires, I have BFGs ATs at 265/65/18, maybe the altitude is killing me idk
  8. Jun 12, 2014 at 2:06 PM
    Foozer
    Utah
    2021 TRD Pro - MGM
    265/75/16 BFG KO2
    thanks for the other comments
  9. Jun 12, 2014 at 2:09 PM
    Warped
    Warped N4LJ
    Jim
    Eastern Ky
    2024 Tacoma TRD Off Road
    You need to turn off the traction control before you can "spin the tires"
  10. Jun 12, 2014 at 2:35 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    The pedal recall is mandatory. You truck will have it. If it senses a ~20 mph difference between the front and rear tires, it will stop you from giving it and more gas, by cutting the throttle.
    Try removing your ABS fuse. Then try a burn out again.
  11. Jun 12, 2014 at 2:49 PM
    Foozer
    Utah
    2021 TRD Pro - MGM
    265/75/16 BFG KO2
    How do you remove the ABS fuse, and are there any negative consequences of doing so?
    Thanks for the input
  12. Jun 12, 2014 at 3:03 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Just pull it out. Truck off of course. ABS light will come on. Turn truck off and re-install what ready. Light will go off.
  13. Jun 12, 2014 at 5:16 PM
    Foozer
    Utah
    2021 TRD Pro - MGM
    265/75/16 BFG KO2
    Isn't it dangerous to drive without abs? And where is the fuse found under the hood?
  14. Jun 12, 2014 at 5:19 PM
    memario1214
    Colton
    Missoula, MT
    Im just gonna say that the ABS in my pickup has gotten me into far more trouble than it coild ever get me out of. The cycle on these trucks is horrible.
  15. Jun 12, 2014 at 5:25 PM
    Large
    Large Red
    Ehh I could burn my 33s fresh off the ECU reflash from the dealer, disable the trac control
  16. Jun 12, 2014 at 5:41 PM
    Foozer
    Utah
    2021 TRD Pro - MGM
    265/75/16 BFG KO2
    I disabled traction control, maybe it's just the altitude then.. do you have an automatic or manual?
  17. Jun 12, 2014 at 5:45 PM
    Large
    Large Red
    Auto, they were mud tires so there was less tire touching the ground.. only thing I could think of.
  18. Jun 12, 2014 at 5:46 PM
    Foozer
    Utah
    2021 TRD Pro - MGM
    265/75/16 BFG KO2
    And that was with the abs on? Could it be the altitude difference?
  19. Jun 12, 2014 at 6:21 PM
    Foozer
    Utah
    2021 TRD Pro - MGM
    265/75/16 BFG KO2
    Yeah I definitely feel the boost especially between 20-30 mph and 70 to 100 mph. But off the line it's not as noticeable
