Supercharger Coolant Tanks 2nd run closed currently
Discussion in 'Performance and Tuning' started by mightytacoman, Jan 27, 2020.
  1. May 21, 2020 at 10:12 AM
    #201
    zippsub9
    zippsub9 Well-Known Member
    Halfmoon, NY
    14 DCLB
    Shit bolted onto other shit, and junk.
    I wouldn't think an overflow would be necessary. It isn't under much pressure so 220 would be water boiling point and this coolant doesn't get anywhere close to that.
  2. May 21, 2020 at 10:50 AM
    #202
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
    I don’t plan on running an overflow, and the cap is just there mostly to keep dust out. If by some strange situation it needed to overflow, it will probably blast the cap off. Maybe one day I will route a vac line down below the truck since coolant is flammable and probably wouldn’t be good to send it straight to the header area :D
    Norton and mightytacoman[OP] like this.
  3. May 21, 2020 at 12:40 PM
    #203
    Scott B.
    Scott B. Well-Known Member
    Scott
    Georgia
    2015 ACLB SR5 4x4 Expo
    I just received mine! It looks great!
    I think I will paint it black - let it blend in.
  4. May 21, 2020 at 1:28 PM
    #204
    mightytacoman
    mightytacoman [OP] Mighty-known Member
    Kel
    4.5L 1grfe
    Brian Crower stroker kit, Carrillo pistons moly/ceramic coated, BC sportsman rods, arp s2000 head bolts, Darton M.I.D sleeves, Kelford race cams, Magnusson supercharger, hp tuner tuned, 650cc flow matched fuel injectors, CSF radiator, Walbro 255 fuel pump. pulleyboys quick change pulley with 2.3", fpr mod, NST crank, water and alternator pullies, 160° mishimoto thermostat. Puma On-board air, Radflo CDC ext coilovers with 14" 700# springs, extended length rear Radflo shocks with CDC, Dakar leak pack, Brute Force Fab front bumper galvanized and powder coated, DTRL mod, yellow fogs, fog anytime mod, relocated rear differential breather, synthetic fluids, custom airbox, tundra sized intake. 76mm throttle body, secondary air filter removed, Airflow snorkel, 4x innovation sliders powder coated, URD equal length headers, DT y-pipe, Aero-Turbine 2525xl exhaust dumped over axle, seat belt chime disabled, Warn 8000i winch, 1- 20" slim light bar in grill, 42" curved roof light both with custom brackets. Mesh grill, Brute Force Fab rear bumper with extra reverse lights, u bolt flip kit, SS extended brake lines, hockey puck bump stop extension, AT shackle flip kit, Light Racing UCA's, 4crawler 1.5" bodylift. custom built front and mid skid plates, re-geared to 4.56s, windows tinted 25%, Sony stereo, 8" skar sub-woofer, 1000 watt mono amp, retrofit headlights with legal demon eye, Kryptek Marathon seat covers. North Star agm 27f battery, Helo 791 rims, 315/75/r16 Mt/r ARB front air locker
    I've never had a black starburst :confused: lmao.
    Glad you're happy with it buddy :cheers:
    loginfailed and nudavinci64 like this.
  5. May 21, 2020 at 1:58 PM
    #205
    TheFang
    TheFang No Big Deal
    SoCal
    Tacoma TRD Sport
    TRD Exhaust, URD Short Shift, TRD Supercharger, Hellwig rear sway bar, TWM shift knob, limo tint, URD Y-pipe, URD LT Headers, URD Rear O2 Sim, Custom tube front and rear bumpers, LED spot pods, K&N CAI
    So close I can almost taste the starbursts...
    12TRDTacoma likes this.
  6. May 21, 2020 at 2:48 PM
    #206
    Scott B.
    Scott
    Georgia
    Blackberry or licorice. But I think marketing wouldn't like them - black things in the big bag of brightly colored squares. LOL
  7. May 21, 2020 at 4:11 PM
    #207
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    You know what they say. Once you...
  8. May 21, 2020 at 4:32 PM
    #208
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
  9. May 22, 2020 at 3:07 PM
    #209
    Boozng
    Boozng I don't know what I'm doing here.
    Dave
    626, 661, 323, 310, 760
    MGM DCSB TRD Sport 4x4 Supercharged
    FOX 2.5/2.0, Camburg UCAs, 33" BFGs, Pelfreybilt Armor
    Holy crap! I don't know why I haven't been getting notifications from this thread! Thank goodness I'm still on the list! @mightytacoman
    mightytacoman[OP] likes this.
  10. May 22, 2020 at 4:14 PM
    #210
    mightytacoman
    Kel
    4.5L 1grfe
    Haven't taken anyone off the list, hopefully that doesn't burn me. Sent ya back a pm.
  11. May 22, 2020 at 6:53 PM
    #211
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    1 time run?? I want in:anonymous:
    zerotimeouts and RyanL like this.
  12. May 22, 2020 at 7:43 PM
    #212
    mightytacoman
    Kel
    4.5L 1grfe
    You're added :thumbsup:
    BassAckwards[QUOTED] likes this.
  13. May 24, 2020 at 2:45 PM
    #213
    mightytacoman
    Kel
    4.5L 1grfe
    BassAckwards and rmepilot like this.
  14. May 24, 2020 at 3:45 PM
    #214
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    You and you're fancy welding skills. :p
    mightytacoman[OP] and rmepilot like this.
  15. May 25, 2020 at 4:31 AM
    #215
    mightytacoman
    Kel
    4.5L 1grfe
    Lots of practice this week! 120ft of aluminum handrail and on a different job- 3 flights of steel stairs started. I'll leave the stainless work to @Roostfactor though. That's my least favorite to weld.
  16. May 25, 2020 at 6:11 AM
    #216
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Defintely more involved than aluminum. A lot more.
  17. Jun 3, 2020 at 1:55 PM
    #217
    mightytacoman
    Kel
    4.5L 1grfe
    Apologies for the delays guys. My main guy broke his foot so I've been picking up his slack while he's on lighter duty. Should have tanks in the mail tomorrow though for those next in line.
    cory02taco and TheFang like this.
  18. Jun 3, 2020 at 2:09 PM
    #218
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    Can I be added?
  19. Jun 3, 2020 at 2:11 PM
    #219
    mightytacoman
    Kel
    4.5L 1grfe
    Yes sir. I'll put ya down.
  20. Jun 3, 2020 at 2:12 PM
    #220
    Lucario Runner
    Robert
    06 Toyota 4Runner
    thx m8
