Supercharger Coolant Tanks 2nd run closed currently
Discussion in 'Performance and Tuning' started by mightytacoman, Jan 27, 2020.
  1. Aug 20, 2020 at 5:31 AM
    #301
    mightytacoman
    mightytacoman [OP] Mighty-known Member
    Kel
    4.5L 1grfe
    Brian Crower stroker kit, Carrillo pistons moly/ceramic coated, BC sportsman rods, arp s2000 head bolts, Darton M.I.D sleeves, Kelford race cams, Magnusson supercharger, hp tuner tuned, 650cc flow matched fuel injectors, CSF radiator, Walbro 255 fuel pump. pulleyboys quick change pulley with 2.3", fpr mod, NST crank, water and alternator pullies, 160° mishimoto thermostat. Puma On-board air, Radflo CDC ext coilovers with 14" 700# springs, extended length rear Radflo shocks with CDC, Dakar leak pack, Brute Force Fab front bumper galvanized and powder coated, DTRL mod, yellow fogs, fog anytime mod, relocated rear differential breather, synthetic fluids, custom airbox, tundra sized intake. 76mm throttle body, secondary air filter removed, Airflow snorkel, 4x innovation sliders powder coated, URD equal length headers, DT y-pipe, Aero-Turbine 2525xl exhaust dumped over axle, seat belt chime disabled, Warn 8000i winch, 1- 20" slim light bar in grill, 42" curved roof light both with custom brackets. Mesh grill, Brute Force Fab rear bumper with extra reverse lights, u bolt flip kit, SS extended brake lines, hockey puck bump stop extension, AT shackle flip kit, Light Racing UCA's, 4crawler 1.5" bodylift. custom built front and mid skid plates, re-geared to 4.56s, windows tinted 25%, Sony stereo, 8" skar sub-woofer, 1000 watt mono amp, retrofit headlights with legal demon eye, Kryptek Marathon seat covers. North Star agm 27f battery, Helo 791 rims, 315/75/r16 Mt/r ARB front air locker
    Yes indeed. I plan on doing a second run but not at this time. Mostly likely in the winter when other work slows down some. Really busy this month finishing a job for a nearby airport for instance.
    Since nobody seemed to like the overflow option and they were all just capped off. I was thinking of going to a wide mouth top like my overpriced competitor uses. Something along these lines. Would like some input for y'all though. Ones I would use wouldn't be finished black like this but raw aluminum instead
  2. Aug 20, 2020 at 6:50 AM
    #302
    420taco
    420taco Well-Known Member
    Justin
    PA
    Count me in...
    mightytacoman[OP] likes this.
  3. Aug 20, 2020 at 11:54 AM
    #303
    74cam
    74cam Automotive Engineer
    Michigan
    2010 Tacoma TRD Sport 6spd
    TRD Supercharged, 3 inch lift, TRD beadlock wheels
    I'd be interested in the 2nd run as well...noticed my stock tank is leaking. I like the wide mouth option too! :thumbsup:
  4. Aug 23, 2020 at 3:03 PM
    #304
    Voodoo Rufus
    Voodoo Rufus Well-Known Member
    Bakersfield, CA
    07 Sport Indigo Ink DCSB 4WD
    Magnuson S/C, Relentless armor, Icon/Dakar suspension, Konig CountersteerX 17", KO2's, Hellwig rear swaybar, BudBuilt Trac Bar, Level 10 VBU, Weathertech floorliners, Cravenspeed antenna, Redline elite hood struts, RollnLock, Satoshi, CBI sliders
    Got my unit painted and installed. Ended up leaving the barb off as the pressure cap should do the job of sealing it. Might stuff a plug of JB weld or something into the thread holes for good measure.
  5. Aug 25, 2020 at 10:31 PM
    #305
    lemon177
    lemon177 Well-Known Member
    Matthew
    Oahu
    09 tacoma 4x4 sport pyrite mica
    TRD supercharger, URD 2.85" stealth pulley, TRD exhaust, TRD intake, DTLT headers, URD y-pipe, TRD boost gauge, PLX DM100 touch with OBDII and SM-AFR modules, 885 OME 3", Icon UCAs, Satoshi grill, Solid rear window, SCS stealth 6, 285/75/17 toyo AT2.
    Damn! I want that new run cap!!
    Keep us all updated, I may run mine for the time being and pick that up
  6. Aug 26, 2020 at 6:27 AM
    #306
    JacksonTacoma
    JacksonTacoma Well-Known Member
    James
    Jackson, MI
    2015 S/C TRD Pro
    Magnuson SC, 2.5 pulley, hptuner, FPR mod, AFE Intake, URD longtube headers, JFR Y-pipe, 255 Deatschwerks, 76mm TB, Banks 3" exhaust, cam gears
    I like this new idea
  7. Aug 26, 2020 at 6:55 PM
    #307
    lemon177
    Matthew
    Oahu
    Got it installed, very stealth
  8. Sep 14, 2020 at 6:09 PM
    #308
    MightyMouseTom
    MightyMouseTom Balance off road vs on road performance
    Tom
    San Antonio, Texas
    2013 Black DCSB
    2inch lift, 285/75/17 Nitto Trails Grapplers, Billy 6112/5100s AAL, Alpine Design Cab mount relocation, TRD Supercharger w/URD pulley, Volant Ram Air Intake, TRD Exhaust, Katzkin, TechDeck, Ram mounts, Audio w/hideaway kicker amp, CBI skid, Custom grille, and SS3 fogs
  9. Sep 14, 2020 at 6:20 PM
    #309
    mightytacoman
    Kel
    4.5L 1grfe
    Perhaps this winter when work slows down a bit.
  10. Oct 3, 2020 at 8:28 PM
    #310
    Georgeth1022
    Georgeth1022 Well-Known Member
    Shaun
    West Hills CA
    2013 BAJA w/ too many mods
    Too many to list
    So...is it winter yet??? Would really like one of these
  11. Oct 8, 2020 at 6:54 AM
    #311
    BenMara
    BenMara That Asian RedNeck
    Ben
    Belton, SC
    2011 DC 4x4 SCed
    TRD Blower, Ham Radio, DBA T2 Rotors
    Put me on the list for the next Run
  12. Nov 26, 2020 at 1:08 PM
    #312
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    I'm interested in this second run as well.
  13. Nov 26, 2020 at 6:02 PM
    #313
    mightytacoman
    Kel
    4.5L 1grfe
    Let me see if it's feasible for another run right now
    BenMara likes this.
  14. Nov 26, 2020 at 8:51 PM
    #314
    Kini
    Kini Well-Known Member
    Alaska
    2008 FJ Cruiser
    Me too!
  15. Nov 27, 2020 at 4:54 AM
    #315
    dcoursler
    dcoursler They call me Tater Salad
    Derrick
    Alabaster, AL
    2012 TRD Off Road
    Currie Rock Jock High Pinion 60, JD Fab EVERYTHING, Fox shocks, Radflo Shocks, Archive Garage all the other things, spinny thing on top of the motor
  16. Nov 27, 2020 at 5:36 AM
    #316
    mightytacoman
    Kel
    4.5L 1grfe
    I believe I have all interested parties marked on pg 1. If your name isn't there and you want it to be-let me know
    JacksonTacoma likes this.
  17. Nov 28, 2020 at 3:40 AM
    #317
    Biscuits
    Biscuits Thorny Crown of Entropy
    Swiggity swangin' biggity bangin'
    I'd be in for a 2nd GB.
  18. Nov 29, 2020 at 11:30 AM
    #318
    mightytacoman
    Kel
    4.5L 1grfe
    Good news for y'all. I should be able to start making resi coolant tanks starting in about 3 weeks. I'm gonna wait till Wednesday to let people jump on the list then it'll be closed again as I'm buying material enough for the list + 1-2
  19. Nov 29, 2020 at 7:22 PM
    #319
    Athlaos
    Athlaos Destruction Mode
    Leigh
    Edmonton
    2011 SR5 Manual TRD SC 1.87" pulley
    A flux retro-capacitance encabulator
    Put me down for TWO of these in the 2nd run!!
  20. Nov 30, 2020 at 4:21 AM
    #320
    mightytacoman
    Kel
    4.5L 1grfe
    Got ya down.
