Supercharger Dynamic Tensioner Hitting Dip Stick
Discussion in '1st Gen. Tacomas (1995-2004)' started by Exhaust, Jan 17, 2017.
  1. Jan 17, 2017 at 11:44 AM
    Exhaust
    Exhaust [OP] Well-Known Member
    Erik
    Wharton State Forest
    02 DC TRD
    Extended breather, Grey Wire mod, Tundra brakes, Rockford-Fosgate sound, General Spring HDs, 5100s + 880s, Heated Seats, TRD Supercharger, 2.1 Pulley, URD 7th Kit
    This past weekend the belt on my supercharger broke. When I went to replace it, I noticed that the dynamic tensioner was hitting the dip stick. It's been a while since my install, but does the tensioner do this when there is no belt or could the tensioner be broken?
  2. Jan 17, 2017 at 1:38 PM
    drr
    drr Primary Prognosticator
    Dan
    Seattle-ish
    02 4WD Tacoma
    Yeah when there is no load on the tensioner, it will spring back towards your dipstick. Once you put a belt on it the tensioner should be just about vertical. You can adjust where it rides by changing your alternator adjuster too if necessary.
