Supercharger fail
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Jfaircloth83, Jul 7, 2023.
  1. Jul 7, 2023 at 6:41 PM
    Jfaircloth83
    Jfaircloth83 [OP] Active Member
    Jared
    2019 tacoma sr
    Mk3 rotrex c30 supercharger lce header, mbrp lightweight exhaust
    I installed a mk3 c30 rotrex supercharger on my 2019 sr with >60000 miles. Install went ok. Tube flew off throttle body. But reattached,went fine for 2 weeks. Whistle and all. After a 10 mile trip (straight) back down to 25 mph truck started shuddering and stalled to a stop. High atf warning light. Wont start. High atf. Low oil pressure, sounds rumbly on attempting to start it. Stalls out with a squeak
    Anyone, please help. Worst nightmare. Thanks
  2. Jul 7, 2023 at 6:57 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    How many miles on the spark plugs? Maybe @Torspd has a clue.
    Torspd likes this.
  3. Jul 7, 2023 at 6:58 PM
    Jfaircloth83
    Jared
    2019 tacoma sr
    New ngk's 42 miles
    Steves104x4 likes this.
  4. Jul 7, 2023 at 7:00 PM
    eurowner
    eurowner Duke Sky
    Scoty
    Did you buy the truck new?
    Jfaircloth83[OP] likes this.
  5. Jul 7, 2023 at 7:01 PM
    Jfaircloth83
    Jared
    2019 tacoma sr
    Yeah. 3 miles.
  6. Jul 7, 2023 at 7:08 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Any codes?
  7. Jul 7, 2023 at 7:11 PM
    Jfaircloth83
    Jared
    2019 tacoma sr
    Im getting a scan tool this weekend. Check engine is on after stall. I actually got it a .25 mile down the road but, same. Check, trac off low oil press. High atf.
  8. Jul 7, 2023 at 7:17 PM
    eurowner
    eurowner Duke Sky
    Scoty
    Put is all back to stock and tow it to the dealer if you have warranty.
    cryptolime, Auzea, 9TRDTCO and 5 others like this.
  9. Jul 7, 2023 at 7:18 PM
    Jfaircloth83
    Jared
    2019 tacoma sr
    That is so much work
  10. Jul 7, 2023 at 7:19 PM
    eurowner
    eurowner Duke Sky
    Scoty
  11. Jul 7, 2023 at 7:21 PM
    Jfaircloth83
    Jared
    2019 tacoma sr
    Thanks man
  12. Jul 7, 2023 at 7:22 PM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    High atf means your trans temps are too high
    Auzea and Jfaircloth83[OP] like this.
  13. Jul 7, 2023 at 7:35 PM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    I don't know squat about superchargers, but what you describe does not sound good at all. Best of luck brother!
    Carry on.
    Jfaircloth83[OP] and Chew like this.
  14. Jul 7, 2023 at 7:47 PM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    Start with the obvious; go back through everything and look for unplugged, melted, frayed wires and connectors.
    Not sure on this setup, but pull the belt off the blower and see if it’s locked up, or truck runs okay without.
  15. Jul 7, 2023 at 8:10 PM
    Jfaircloth83
    Jared
    2019 tacoma sr
    Thanks man.
  16. Jul 7, 2023 at 8:56 PM
    TnShooter
    Deogee
    STOCK
    Not necessarily, not on a 3rd Gen.
    A bad crank sensor can cause both the warning messages OP has.
    I’m not saying it’s the crank sensor.
    But the 3rd Gen trucks throw warnings messages that have nothing to do with the actual problem.
  17. Jul 7, 2023 at 9:49 PM
    Jfaircloth83
    Jared
    2019 tacoma sr
    I like this. it sounds pretty congested on startup attempts though. No smoke. No smell though. A screech stall sound and jiggly motor though.which worries me. I didnt even open it up past 90
  18. Jul 7, 2023 at 9:52 PM
    Veet-88
    Veet-88 Well-Known Member
    18 Tacoma DCLB sport
    What tune/supporting mods were done with the super charger install?
    cryptolime and wrightme43 like this.
  19. Jul 7, 2023 at 10:10 PM
    Jfaircloth83
    Jared
    2019 tacoma sr
    None at all. Im starting to think this was a mistake
    hayrider2.0 and MalinoisDad like this.
  20. Jul 7, 2023 at 10:10 PM
    Jfaircloth83
    Jared
    2019 tacoma sr
    Just the wiring of the mk3 ecu3 control unit as instructed
