Supercharger Installed high idel.
Discussion in 'Performance and Tuning' started by PkTaco, Dec 3, 2011.
  1. Dec 3, 2011 at 1:03 PM
    PkTaco
    PkTaco [OP] Well-Known Member
    David
    Zanesville Ohio
    Installed a TRD Supercharger on my truck with out any real hitches. The only real problems that I ha e is that it idels high at 1250 at regular engine speeds after its warmed up. Also when I shift it will idel up about 200 rpms then shift. Any idea what the problem could be? Reversed vac lines, messed up maf sensor, throttle body, or just needs seafomed? Any advice or opinions are appreciated.
  2. Dec 3, 2011 at 1:16 PM
    hawker25
    hawker25 Well-Known Member
    colorado
    TRD Offroad
    Have you had it flashed by toyota?
  3. Dec 3, 2011 at 1:29 PM
    PkTaco
    David
    Zanesville Ohio
    Forgot to mention I have a 2003 3.4L. So I don't think it needs flashed or am I wrong?
  4. Dec 21, 2011 at 7:34 PM
    PkTaco
    David
    Zanesville Ohio
    Bump.
  5. Dec 21, 2011 at 7:43 PM
    Leggo
    Leggo slow is smooth, and smooth is fast.
    Newton,Ma.
    10 TRD Sport AC 4x4 MGM
    Kenwood HU,Infinity Kappa speakers (x4), Infinity reference tweeters(x2),10" Kicker sub, Box by Subthump, Infinty Five channel amp,DVD anytime bypass, DTRL Mod, Xtang trifecta, Fogs anytime Mod, Bed Mat,Westin running boards, Console vault, Maglite mod, Weathertechs,Autopage remote starter, Power tailgate lock, HID Bi Zenon, Hella Supertones,Rain guards,Rear leaf TSB,Steering shaft TSB, Fisher Homesteader plow, 886 reverse lights mod, Redline Hood struts, Hankook Dynapro ATM LT265/70R17, power sliding rear window, Auto dimming/on anytime Bed lights, Blue Sea fuse panel & 100amp Breaker, de- badged,Rear headrest's removed, imMrYo mirror relocation,Homeroshi grill
    if you have a vacuum leak it will idle high and higher when no load is on (between gears while shifting). Are you sure you installed all the vacuum lines? I start the engine and use a propane torch(not lit) pointing at all the points where a vacuum leak could be, waiting to hear the idle jump up. Good luck!
  6. Dec 21, 2011 at 7:48 PM
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
  7. Dec 21, 2011 at 7:50 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Could just be the truck getting settled back in after having the battery disconnected and the engine all torn apart. Give it a little bit and see what happens.
    (My 4.0L idled at about 2K for the first three start ups after my headlight retrofit...I had pulled the injector resistor pack and it had to "learn" everything all over.)
  8. Feb 23, 2012 at 11:50 AM
    PkTaco
    David
    Zanesville Ohio
    Thanks for all your help fellas. Ended up just being 2 pvc lines unplugged. Not sure how I missed them the first 3 times I looked at it but now she runs like a rape date and sounds real nice too.
