Supercharger Noise Drive Oil Change?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SManZ, Dec 27, 2011.
  1. Dec 27, 2011 at 8:36 AM
    SManZ
    SManZ [OP] el tráfico más lento se queda derecha
    Haymarket, VA
    '10 Supercharged 4x4 Sport 6-spd
    TRD Supercharger, King 2.5" extended travel remote-resi coilovers, OME Dakar leaf packs, King 2.5" extended travel rear shocks, Total Chaos UCAs, MBRP turndown exhaust, TRD intake, TRD Quickshifter, Goodridge SS brake lines, EBC Sport Rotors, Hawk HPS pads, TRD FJ Cruiser Special Edition 16" Anthracite Rims, Spidertrax wheel spacers, 265/75R16 A/T, Autometer oil pressure, oil temp gauges, TRD boost gauge, PLX DM-100 OBD II scanner, flexpod mounts, A-pillar gauge pods
    Anyone changed the nose drive oil on a 1GR TRD S/C?
    I've so far found very little on this topic for the 1GR. Here's something Gadget put together for the 3.4L;
    http://www.gadgetonline.com/SuperNose.htm
    I've got 25K on my S/C and wondering if the same recommended 30K holds true for the 1GR setup. Anyone have specifics on the location of the drain plug and type of oil it takes? It would be sweet if this could be done without removing the S/C from the motor...
  2. Dec 27, 2011 at 8:47 AM
    JKlam
    JKlam Well-Known Member
    Toyota sells an oil specific for the supercharger, the part number is 08885-80108, well at least in Canada it is. As for where the drain plug is, I don't know that answer.
  3. Dec 27, 2011 at 9:22 AM
    BUZZCUT
    BUZZCUT Well-Known Member
    Georgia
    2007 AC TRD OFFROAD
    Highly unlikely of a drain. On my super coupe I used a large syringe to suck out the old fluid and refill it with new.
  4. Dec 27, 2011 at 9:51 AM
    SManZ
    Haymarket, VA
    JKlam - thanks for the part number! Will do some more research to see if I can find an acceptable substitute. I found some for $37/bottle and I'm reading its only for a few ounces, so the stuff is quite expensive.
    Cool :) I just got a motorcycle fork oil level tool. Its basically a large syringe with a long and thin plastic tube. Should work nicely.
    Now...just need to locate the plug and find out how much oil this thing needs!
  5. Dec 27, 2011 at 2:27 PM
    BUZZCUT
    Georgia
    2007 AC TRD OFFROAD
    If that is an eaton s/c which I think it is then any oil for an eaton s/c will work. Ford sell a 4 ounce bottle just for the lightnings I dont have a price for it though.
    http://www.toyotaracing.com/trd/parts_catalog/superchargers/eaton_roots_type.html
