supercharger now making the clutch slip
Discussion in '1st Gen. Tacomas (1995-2004)' started by sctrdtaco03, Jan 7, 2010.
  1. Jan 7, 2010 at 4:32 PM
    sctrdtaco03
    sctrdtaco03 [OP] Ah yeah that guy
    scott
    Port Orchard,Wa
    Taco
    first gen trd supercharger throttle body coolant delete gray wire mod rear diff breather extension King coilovers All pro uca's toytec 2" shackle extension rear billy 5100 water meth injection urd 6 injector upgrade other assorted goodies custom AZ pinstripe on sides
    Hey throwing it out to see if anyone has problems with this. I just put a TRD first gen (grey) supercharger and my 3.4 TRD edition taco. About two weeks of driving the clutch starts to slip pretty bad in fourth and fifth under full throttle above 2k when the engine starts to make power. I don't see how a clutch could go bad this quick the truck has less than 50k on the whole thing. anyone have any ideas let me know. :confused:
  2. Jan 7, 2010 at 4:33 PM
    sctrdtaco03
    scott
    Port Orchard,Wa
    Taco
    the truck is a 03 extended cab btw
  3. Jan 7, 2010 at 4:35 PM
    Idrivetoys
    Idrivetoys Well-Known Member
    Yuma AZ
    I need a 4 door DC 4x4
    a clutch is a mechanical piece of gear that can go bad whenever its time, however most do not, some do. Also adding the additional stress of a S/C can decrease its life permitting it has a manufacturers defect as well. If it slips it slips, bite the bullet and pick up a nice replacement to avoid any further troubles.
    on a side note, how does the s/c perform compared to stock and whats your fuel mileage looking like.
  4. Jan 7, 2010 at 4:41 PM
    sctrdtaco03
    scott
    Port Orchard,Wa
    Taco
    It pulls like a mofo and gets about 16mpg honest thats average for me I dont goose it all the time but get into it every now and then. The torque gain is really noticeable it starts at about 1.5k and keeps going. It does ping at 1.5k-2k so I cant get into it hard between that, but cruzing is fine for those rpm's besides that I cant complain.
  5. Jan 7, 2010 at 4:45 PM
    Idrivetoys
    Yuma AZ
    have you had the ecu flashed for more fuel? at least that's why i read about, not sure if model s/c matters but i heard it was necessary, i haven't looked into it too much, not til my re enlistment later this year
  6. Jan 7, 2010 at 4:54 PM
    05trdsport
    05trdsport Well-Known Member
    Calgary AB CAN
    2005 TRD Sport Silver
    K&N cold air intake, Aroturbine exhaust OME 885's on OME Nitrochargers, Total Chaos UCA, 1-1/4" wheel spacers, TRD sport wheels coated flat black, dick cepek AT 285/70/17, Alcan AAL/OME rear struts, Blacked out front valance, bhlm headlights, nav/ipod eclipse headunit. URD maf calibrator with map option. Supercharger in the works.
    whenever you do an upgrade like a supercharger/turbocharger you should definatly do a clutch with a higher clamp load(act, exedy, etc) and reflash your ecu. if its pinging then i would get the ecu reflashed asap or your next post will be wtb: 3.4L tacoma motor. :D
  7. Jan 7, 2010 at 5:09 PM
    sctrdtaco03
    scott
    Port Orchard,Wa
    Taco
    can I get the stock ecu flashed? I looked at urd for the 7th injector kit. any suggestions besides that?
  8. Jan 7, 2010 at 5:13 PM
    05trdsport
    Calgary AB CAN
    Dealership if its a trd blower
  9. Jan 7, 2010 at 6:33 PM
    sctrdtaco03
    scott
    Port Orchard,Wa
    Taco
    even for the first gen?
  10. Jan 7, 2010 at 6:49 PM
    HBMurphy
    HBMurphy Ban Pending
    Paul
    So California Coast
    09 Off Road Delete Model
    None
    Worn clutch/pressure plate making clutch slip.
  11. Nov 11, 2010 at 12:39 AM
    sctrdtaco03
    scott
    Port Orchard,Wa
    Taco
    so went with a stage 3 Comp clutch from URD gadget is the shit if you didn't know.
  12. Nov 11, 2010 at 4:44 PM
    Avsguy33
    Avsguy33 Well-Known Member
    I have gone through plenty of clutches within the last couple years. My GTO is on its 7th within 5 years and 58K miles. More power is more stressfull on everything but sure is addictive. Looks like the Stage 3 clutch for the taco is a good clutch. I have been looking into that for mine once mine finally goes.
