Supercharger or Turbocharger for 2011 TX Pro
Discussion in 'Performance and Tuning' started by ggalvan210, Nov 23, 2011.
  1. Nov 23, 2011 at 9:17 PM
    ggalvan210
    ggalvan210 [OP] Member
    Goose
    Clarksville, TN
    2011 Tacoma TX Pro
    what would you'all recommend for my 2011 TX Pro, supercharger or turbo charger. pros and conn's
  2. Nov 23, 2011 at 10:05 PM
    Hayes
    Hayes Well-Known Member
    Brandon
    Denver, CO
    2011 Regular Cab Tacoma 4x4
    I recommend you search. This has been covered many many times.
    What are you looking for? Top end power, low end torque? That all matters when making a decision.
  3. Nov 23, 2011 at 10:06 PM
    Blasphemous
    Blasphemous Well-Known Member
    San Fernando Valley, CA
    2012 TRD Sport DC 4x4
    TRD SC, Stealth Pulley, DTLT Headers, URD MK3 Catback Exhaust, AFE II Intake
    Depends on your budget and how much power you want.
    But in the end unless you really want to get into it you will most likely end up with a TRD/URD supercharger. Both are great platforms for making good amounts of power.
    TRD is known for it's insta-boost (almost) and URD is known for it's crazy top end power. Pick your demon.
  4. Nov 23, 2011 at 10:54 PM
    extremachn1
    extremachn1 I am an asshole, deal with it!
    Turd Furgison
    Tucson, AZ
    BAD ASS SUPERCHARGED BEAST
    TRD S/C, TRD quick shifter, AFE CAI, Magnaflow cat back exhaust, Fox racing shocks, TC UCA, All-pro expo leafs, Bestop soft top, Wet Okole black seat covers, Scan gauge II.
    I have the TRD and it was good but I added the URD under drive pulley and now the thing is a BEAST.
  5. Nov 23, 2011 at 11:00 PM
    Detective_Dan
    Detective_Dan "Place original and witty user title here"
    Colorado Springs
    2014 DCSB Beast / 2016 Yamaha FZ-07
    Pelfreybilt Front Plate Bumper, Brute Force Fab High Clearance Rear Bumper, Pelfreybilt Sliders, OME 886/Dakars, SCS F5's, 33" Ko2's, Cobra 75WXST/3' Firestik, oil catch can, aero turbine 2525, rear differential breather extension, bedmat, weathertech digital fit front/rear, BHLM, custom shiftknob (made by me),
    he cant use a URD supercharger, he has a 2011. thanks for playing
  6. Nov 23, 2011 at 11:03 PM
    cummins6speed
    cummins6speed Well-Known Member
    '05 4Runner Limited Edition
    Custom extended travel 2.5" King RR coilovers, 1.25" Camburg uniball uppers, homebuilt tube bumper
    What are you trying to do with the truck? What do you want to spend. I don't recommend those remote mount turbos if thats what you were thinking about
  7. Nov 23, 2011 at 11:03 PM
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Toyos, Baja Designs, TC, SDHQ
    this;)
  8. Nov 23, 2011 at 11:09 PM
    Blasphemous
    Brain farted.
  9. Nov 29, 2011 at 10:19 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Why won't the URD MKII or III fit on the '11? No significant changes were made to the engine or engine bay on that model. However, I know for a fact that Gadget mentioned, after looking at some pictures of the '12 engine bay, that some modification to the kit's components would be necessary to make it fit on the '12.
    Don't be fooled by the "warranty" claim. First off, it is considered an aftermarket warranty, that gets rolled into the factory warranty. Depeding on how many miles you have on your truck, having Toyota install the s/c could be worth the warranty since it will be with the rest of the power train warranty. If you onlyhave a few miles left, say something that you will reach in less than a year, then it wouldn't be worth it due to the fact that if you install it yourself you will have a full one year warranty.
    Some dealerships also don't feel like dealing with the warranty of those aftermarket parts though. Even though they sell them. Usually they don't know about the Magnuson Moss Act either and for that matter neither do most buyers.
    So I have some questions for you now. Do you off-road frequently?
    How much power do you see a goal? Depending on that will depend on how much extra money you will have to spend to get there.
    Do you have supporting mods to supply the necessary fuel for the power you will soon have or want to reach? Fuel pump, injectors, possible fuel pressure regulator.
    Depending on which s/c, or turbo for that matter, which ecu do you plan on using? I highly advise against the Toyota reflash, as it causes more headache and problems than not.
    Depending on the ECU, is there a quality known shop that is close and can tune it?
    If you want the most power (torque and hp, which is also easily adjustable forward or back), do you have the time to leave you vehicle at a quality shop for them to build a kit?
  10. Nov 29, 2011 at 7:53 PM
    Detective_Dan
    Colorado Springs
    it will "fit" on the 2011, just doesnt mate with the ECU well IIRC
  11. Nov 29, 2011 at 8:09 PM
    907taco
    907taco Alaskan Assassin
    Bobby
    Alaska
    2010 BlackSandPearl 4x4
    ultimate lift kit ( toytec ) ome dakar leaf pack , w/ extended length billies, LR uca's, Pro comp 7089s, KM2's 285 70 17, neoprene seat covers, weather techs, CBI sliders w/kickout, URD ss, cab mount chop, VHT night shade tint>tails,3rd B-light. Debadged. Grillecraft grille, rear diff breather mod. CBI Moab front bumper, warn M8000 winch, HID kragens 7", Hella's micro fogs. retrofit headlights HIDS, LED solutions maps/license! 886 back up light mod,
    i wish i had this problem, hmmmmmmmmmmm turbo or supercharger...... good luck op> i vote supercharger!
  12. Nov 29, 2011 at 8:12 PM
    Detective_Dan
    Colorado Springs
    Ouranos likes this.
  13. Nov 29, 2011 at 8:29 PM
    03evo8gsr
    03evo8gsr Member
  14. Nov 29, 2011 at 8:32 PM
    03evo8gsr
    03evo8gsr Member
  15. Nov 30, 2011 at 4:54 AM
    Gadget@URD
    Gadget@URD Well-Known Member Vendor
    Southern Maryland USA
    URD Supercharged XRunner
    URD is aggressively working to solve this little problem.
    URD just solved the issue with the X-1 not being available any more and designed and manufactured a whole new BETTER EMS. Now we are going to make it work on the 09 and later trucks!!
    It is the UNFAIR ADVANTAGE called the UCON Flex.
    G
  16. Nov 30, 2011 at 11:23 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Map-Ecu, check, as long as there isn't a reflash done before it. Then it can be hit and miss. The reflash sometimes rejects the adjustments to fueling made by the Map-Ecu3 on the 09+ models.
    AEM has been making extension harnesses for the 05-08 models for quite some time. Recently Dezod wired into that harness, so that one of their nicer EMS units will be plug in play. That is on X-roller's Tacoma, which is an 05-08.
    URD has that same extension harness.
    ProEFI has a wired up plug n play harness as well for the same 05-08 models. I am using that on my truck with the Pro128 EMS. For the 09+ they have a flying lead harness. Has to be wired in.
    URD is working on making plug n play connectors for the 09+ models, as Gadget mentioned. Not the easiest thing to do. Seems to be a very guarded plug.
    Powerfab here in Houston has done two turbos on 05+ Tacomas. They are thinking about making a kit as well. Just waiting to see the EMS options and chose the best one.
    The URD kit will work, you just need something that you can wire in yourself, or wait a little longer for URD to come out with the plug n play connectors....
  17. Nov 30, 2011 at 2:18 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    At the time that I had said that, it was still just "in the works". It is a done deal now though. :)
    There is only one other company that has the plugs right now. Their EMS is lacking in its ability.
    Once URD has their plugs, that will be the best system that plug in play, by far. :D
  18. Nov 30, 2011 at 3:04 PM
    Speed Freek
    Speed Freek Tacoma Whisperer!
    Vista, Ca, Lake Havasu, Az.
    98 Tacoma V8 (LS1) swap
    LS1-T56 swap, Z06 ported heads, cam, Titanium valves, Kevlar clutch. Now building a forged stroker (383) and all the ponies! Old setup was rod-knockin on heaven's door...
    Wow I cant believe it cost $2500 out the door, amazing...but no tune yet, so there is another $$$ but still the price of the hardparts and labor is very competitive..
  19. Nov 30, 2011 at 3:25 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    I would like to see some more and close up pics of the turbine inlet tubing. Something looks a bit off in the picture.
  20. Nov 30, 2011 at 4:03 PM
    triumphx
    triumphx Well-Known Member
    Austin, TX
    X-runner/cummins
    You could buy my turbo kit in the for sale section :thumbsup:
