supercharger question for Gen2
Discussion in '2nd Gen. Tacomas (2005-2015)' started by glamis3000, Aug 13, 2011.
  1. Aug 13, 2011 at 4:40 PM
    glamis3000
    glamis3000 [OP] Well-Known Member
    Brant
    Cottage Grove OR
    '96 toyota tacoma 240k miles
    3in lift, 31x10.5x15 toyo mt, tinted windows,
    my buddy just ordered the TRD supercharger and he will have it on tuesday! he was wondering if the URD pulley would work on the stock supercharger?? we are pretty sure it will fit with no problem but just wanted to make sure.. thanks for the responses!
  2. Aug 13, 2011 at 5:55 PM
    extremachn1
    extremachn1 I am an asshole, deal with it!
    Turd Furgison
    Tucson, AZ
    BAD ASS SUPERCHARGED BEAST
    TRD S/C, TRD quick shifter, AFE CAI, Magnaflow cat back exhaust, Fox racing shocks, TC UCA, All-pro expo leafs, Bestop soft top, Wet Okole black seat covers, Scan gauge II.
    The URD 2.8 inch under drive pulley will work on the trd supercharger with no midifacations.
  3. Aug 13, 2011 at 6:26 PM
    Armsmaster
    Armsmaster Well-Known Member
    Bill
    New Jersey
    2006 TRD Sport 4x4 longbed
    Pro Comp 3 inch Lift, Total Chaos Upper Control Arm, and more to come...
    hey how much did he pay for the supercharger?:cool:
  4. Aug 13, 2011 at 6:50 PM
    rossk35
    rossk35 Do Work Son!
    hawaii
    07 TRD Sport Supercharged
    TRD S/C/TRD Intake/TRD Boost Gauge/DT Headers/OEM TL/ZKW retro/Pioneer DVD w/Ipod/Magnaflow/20% Tint/BHLM/JL 10" sub, JL VR components, JL 450/4 amp/Helwig Sway bar/Viper 791/ 18" limited 4runner rims
  5. Aug 13, 2011 at 8:11 PM
    glamis3000
    Brant
    Cottage Grove OR
    ok we thought it wouldn't have any modifications. but will it effect the reflash for the s/c?
    he paid 3700 for everything! and he is wanting the URD pulley for more boost and we want to install it all together. im hoping to talk him into the URD short shifter as well!!
  6. Aug 13, 2011 at 8:23 PM
    Gincoma
    Gincoma Special Edition Member
    Salt Lake City UT
    RIPieces 2005 Tacoma, adios 2011 :'(
    Factory Monster Truck Package with reverse gear.
    URD will give you at least 1lb more boost depending on elevation....itll be an easy install...if you guys need help i can help threw PM since I done install before...anyways goodluck man he'll love the SC :)
  7. Aug 13, 2011 at 8:36 PM
    gsxr6er
    gsxr6er New Member
    So it is safe to put the urd pulley on w/o any changes to the initial reflash after installing the s/c?
  8. Aug 13, 2011 at 8:39 PM
    Gincoma
    Salt Lake City UT
    Itll be fine if you head over to xr-underground they have tons more info then what I can provide there all about boost over there
  9. Aug 13, 2011 at 8:53 PM
    glamis3000
    Brant
    Cottage Grove OR
    oh you decided to make yourself account on here!! welcome to tacoma world Anthony.. youll spend a lot more money because of this site, its addicting!!
  10. Aug 13, 2011 at 9:00 PM
    glamis3000
    Brant
    Cottage Grove OR
    has anyone done the 7th injector for the s/c on the 4.0 v6? does it perform well with it? how much boost does it get out of it? just trying to help out gsxr6er.. with the best results for his new s/c..
  11. Aug 13, 2011 at 9:07 PM
    rossk35
    hawaii
    7th doesn't up the boost. It allows you to run more because it cools the air down before it enters the cylinders. You need an additional controller for it. No more x-1 are available to purchase. Only options are the map-ecu 2 or 3 which you can use a pnp harness, but if you have an 09+ your out of luck unless you hard wire it in.
    Also you would also need bigger primary injectors if you go with a smaller pulley then the 2.8.
    Don't need anything else if your only going to run the 2.8 or nst pulley for upping the boost.
  12. Aug 26, 2011 at 12:12 PM
    wormfood
    wormfood Well-Known Member
    David
    Missouri
    2011 Tacoma TRD
    TRD Super Charger, UWS, All Pro expedition leaf spring pac, Icon stage 4 suspension, B.A.M.F LCA Skid plates, TC weld-on upper coil bucket tower gussets, TC weld-on spindle gussets with sway bar mounts. RTT, Thule Roof Rack, Thule, Leitner Active Cargo System, Warn Zeon 10 Winch, All Pro Front Bumper, All Pro Apex Sliders, Nilight - 60005C-A 20Inch 126W Spot Flood Combo Led Light Bar.
    As said, very new. Can't comment on the OPs question, but pricing was asked about along the way.
    I can add this:
    Picking my Taco up today (25Aug2011), working out the TRD 4.0L V6 SUPERCHARGER install.
    I am in TX, this is what I have so far:
    Round Rock, TX (my dealer, waiting for a counter quote vs Killeen):
    " I got the parts department to cut the price down to $4000. Then service said they would charge 10 hours of labor at $98 an hour. so your total cost would end up being $4980 installed."
    Killeen, TX:
    "We can do $3850.00 for the TRD supercharger and the fit kit. Labor will be at a discounted rate of 70/hr. for a total of $560.00 if you purchase the supercharger through us. ($4410) If you purchase the supercharger elsewhere, labor will be 95/hr. for a total of $760."
    Temple, TX:
    "The parts price with tax is $4871.25 ($4500.00 for parts and $371.25 for tax.)
    The labor cost for install is $660.00 (this is six hours of labor.)
    Total cost of parts and installation will be $5531.25."
    Quick thoughts:
    • book says 6 hours, but unless the shop has done a few, it will take them longer, so a 6 hr labor quote most likely means they have never done one.:p or have done a lot, ask.
    • you can get this wrapped into the over all financing.
    • This has a cool factor of 10, and minus adding two Labrador Retriever puppies to your ride, the SC is the best bang for your buck upgrade to get chicks!:D
    It would be cheaper being a crack addict...:D
    Taco_Jedi likes this.
