SuperCharger Questions and Problems
Discussion in '1st Gen. Tacomas (1995-2004)' started by headbasha, May 14, 2013.
  1. May 14, 2013 at 1:31 PM
    headbasha
    headbasha [OP] Member
    2003 Tacoma 4x4 TRD Off Road
    SuperCharger
    Hello,
    I just bought my first 2003 Toyota Tacoma TRD Off Road SR5 4x4 Double cab. It has 125k miles, It has the gen 2 Supercharger.
    Its not running right at all, i have it at my local mechanic and he is working on it. We are replacing plugs, boots for now. I have some pictures that needs diagnosed by some toyo techs who has a S/C and modded it. This S/C looks like its been modded at one time and then taken off. Not sure what is going on. Can anyone explain what is going on? The truck runs fine till you hit boost levels or around 2500 RPM it starts stuttering and just acting lazy. Its also only making around 3 lb of boost.
    Mechanic said it looks like it has a 7th injector but its not hooked to anything. There are additional wires that go down and into the fire wall and into the glove box. I havent taken it apart yet to see what they go to.
  2. May 14, 2013 at 3:08 PM
    SDSam
    SDSam from Dirt bike to Dezert Couch
    San Diego
    00 Tacoma prerunner
    Icon Shocks, BTF front, Deaver f67, 33's on stocks, Fiberwerxs 1pc, TDR S/C, Bed & Eng Caged
    Find out where and what the wires go to for that injector, then replace your fuel filter unless it was just done? maybe have him do a fuel pump test? find the vacuum diagram for the Supercharger and make sure it is right and the Check valve is installed and working (its on the instructions) maybe also have him do a compression test and see how the motor is doing.
  3. May 14, 2013 at 3:09 PM
    headbasha
    SuperCharger
    I looked up a install guide to the URD 7th injector kit and started a reverse break down of it and pulled out the glove box and found out it is a TRD 7th Injector Kit.
    Everything looks intact and still hooked up once i pulled up their install guide. I still dont know why my truck is not running properly though.
    Any Ideas? I guess time will tell after i get the IK22 plugs and boots in.
  4. May 14, 2013 at 4:00 PM
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    Could be the spark plugs. If the gap is too big (from improper gapping or over wear), the boost can "blow out" the spark, causing a miss fire. Also sounds like there may be a sensor issue (MAF and O2 sensors should be checked).
  5. May 14, 2013 at 4:17 PM
    bellassaiw10
    bellassaiw10 Formally afroman5015
    Currituck NC
    09 LMM 2500HD Duramax
    Take it off and sell it to me
  6. May 14, 2013 at 4:22 PM
    headbasha
    SuperCharger
    What is the gap in the plug suppose to be? Ive searched around and its saying anywhere from 32 to 42. Im using the IK22 like i said earlier.
    Here are some of the pics, flew out sat morning at 4am to houston, tx, drove back to Alabama and got home at 10pm. 18hr journey over 1200 miles.
  7. May 15, 2013 at 3:57 AM
    DAMOS
    DAMOS Well-Known Member
    Eugene, Oregon
    04 Dub Cab TRD 4x4
    TRD sc Magna flow cat back
    no cel?
  8. May 15, 2013 at 4:33 AM
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    I think its .040-.044. Pull one out and post a picture.
    You should be using a dual prong spark plug too. It wont make a difference really, but the single prong will wear out too fast (the Tacoma sparks twice every 4 strokes).
  9. May 15, 2013 at 9:56 AM
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Just a thought, someone had a similar issue and couldnt figure it out for a while. Turned out to be a clogged cat converter.
  10. May 15, 2013 at 11:03 AM
    nigglewiggle60
    nigglewiggle60 Well-Known Member
    Nigel
    Oakhurst, CA
    2003 DC 4x4 TRD supercharged
    Supercharger, toolbox, seat covers, rubber mats.
    Are you putting in the 91 or higher fuel?
  11. May 15, 2013 at 1:06 PM
    headbasha
    SuperCharger
    Ok, here goes and update.
    Just did a top end service, tune up, clean. New ik22 plugs, new ngk wire set, new fuel filter, new plug boots. The miss is gone. But now its shooting cat conv pieces out the tail pipe. It is also only making 2lb boost and is very slow.
    It's at the exhaust shop now removing the cats, it had 2.
  12. May 15, 2013 at 1:24 PM
    C O R E
    C O R E Christian Off Road Engineering
    Clint
    South Texas
    03 TRD 4x4 5spd v6
    Line-X bedliner, bedlined toolbox, Satoshi Grille, bedlined stock old school wheels, Pioneer DEH-X9500BHS head unit, Deck plate mod, ISR mod, K&N Drop-in, Thrush muffler dumped @ rear axle, Grey wire mod, +5mph fender stripes
    This ^^
  13. May 15, 2013 at 1:35 PM
    jberry813
    jberry813 Making TW Great Again Moderator
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    That was me...I had lack of power...not lack of boost. I was actually over boosting with clogged cats.
    If the cats were clogged if the supercharger was doing it's job, you'd be making MORE boost, not less. The back pressure would build up and back into the manifold. At least that's exactly what happened when my cats were clogged. On a good day I boost around 8, with clogged cats I was over 11.
    Start your IK22 gap at .043 and tune to your liking
    Only 2 lbs of boost sounds like a different problem. Could be any number of issues. Anything from simple shit like just a crack in the vacuum line to the boost gauge (also happened to me). Belt could be slipping (check for belt dust around the snout and pulley. Can't tell if you have the dynamic or manual belt tensioner, but loose belt can cause lack of boost. The s/c actuator or vacuum line to the actuator could have a hole in the diaphragm causing it to not shut the actuator under boost. Worst case it could be the rotor inside the supercharger. Gonna cost you about $1000 for a full s/c rebuild including new rotor.
  14. May 15, 2013 at 2:15 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    96.5 FrankenTaco & 03 Stock dbl cab
    BFG KM2 33x12.5 tires, Wheelers Type B rims, Allpro 1.5'' Wheel spacers w/extended thread lug nuts 2 Alpine 10'' Type Xs 2 Kicker 6X9s 4 Sony 5 1/4s Pioneer 4100 HU Sway bar removed 4 Hella 500 HIDs Frankenstein Leaf packs 1'' lift shackles Eibach coils 5100s front 10'' 5150s rear BAMF BPV bracket Deckplate mod Elite Front bumper Magnaflow 14'' muffler Elite Off Road Rear bumper with Tire gate with jerry can and fold down table, BAMF sliders, Custom Homemade Bed, rack/roof rack, CVT Mt. Shasta Roof Top Tent, 20lb CO2 tank, BAMF diff skid custom front skid, GM CS144 140 amp alternator Blitzpro 21s HAWK side LEDs Blitzpro Custom made side mirror lights, LightForce 240 Blitz llights, Piaa 510 ION fogs, XRC8 Winch w/in cab controls,
    Sounds like a massive vacuum leak to me somewhere.
  15. May 15, 2013 at 4:11 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    A pinhole vacuum leak could be enough to prevent the actuator from closing and sending the boost down the intake.
  16. May 15, 2013 at 4:14 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yea true I guess
    I'd start checking hoses and clamps.
  17. May 15, 2013 at 5:00 PM
    headbasha
    SuperCharger
    I've relayed the info, I really hope it is the vacuum issue. If it is the supercharger then who rebuilds them? What kind of turn around time is a rebuild? Is there anything else that can be done to the sc besides rebuilding it?
    If it is a vacuum issue. What kind of maintenance should be done to the sc. I've read a few different things about it should be maintenance free for 100k miles and other people say service nose cone at 60k.
    I wanted to upgrade the trd 7th injector to the URD and add the 2.2 pulley but now the whole damn system has me concerned. If the supercharger did go bad and needs rebuild what did it do to the rest of the engine.
  18. May 15, 2013 at 5:10 PM
    chvymechanic
    chvymechanic Well-Known Member
    Thomas
    New Hampshire
    04 Limited TRD Off Road 4x4 Xtra Cab
    Stuff and Thangs
  19. May 15, 2013 at 5:15 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    If you're not comfortable doing the s/c work, Magnuson can do anything and everything for it. They actually manufacture the s/c for TRD. When I had mine rebuilt it was back in my hands in about 2.5 weeks from the time I dropped it off at UPS.
    As far as s/c maintenance, it depends on how far you want to take it. You can do as little as replace the oil, to seals, to bearings, and including the nose cone as you mentioned. There's only 1 vacuum hose on the supercharger, and it goes directly to the actuator so that's simple. Visibly you can open the actuator to see if there's a hole in the actuator diaphragm. The actuator itself is only around 40 bucks.
    Supercharger/rotor can go bad for any number of reasons, mostly because of sand/dirt/salt particles entering into the intake. Open air filters such as K&N are the number one cause. If you run an aftermarket intake, make sure you run a prefilter screen over the filter.
  20. May 15, 2013 at 5:26 PM
    chvymechanic
    Thomas
    New Hampshire
    Stuff and Thangs
    I had to buy the actuator for my supercharger and bought it from Magnuson and I was told on ttora that it would be around $40. I guess that's what they use to charge, I paid $70. Just an FYI/update.
