Supercharger questions
Discussion in '1st Gen. Tacomas (1995-2004)' started by H-townTaco, May 16, 2017.
  1. May 16, 2017 at 6:28 PM
    H-townTaco
    H-townTaco [OP] New Member
    1998 Tacoma 4x4
    Plain Jane for now
    Im new to the tacoma thing but i bought a 98 with the 5vz and was qondering if it would be ok to throw a supercharger on(Urd probably), it has 200xxx miles on it, i know these engines are very reliable but i wanna be on the safe side of things
  2. May 16, 2017 at 7:35 PM
    drr
    drr Primary Prognosticator
    Dan
    Seattle-ish
    02 4WD Tacoma
    The safest side of things would be to not supercharge it. Would it be OK in the long run? Maybe. There is a guy on here with 500k on a supercharged 3.4L, and he's running the high boost pulley.
    If you're going to do it, do it right though. The engine should be fully up to date on maintenance items and have no pre-existing issues. You will want to consider fuel mods and a controller, such as the URD 7th injector setup. Proper tuning will be essential to the longevity of your engine.
  3. May 16, 2017 at 11:17 PM
    col. sandurz
    col. sandurz Well-Known Member
    Basically this^^^^
    Everything up to date and don't take any shortcuts with parts and things should go fine. But as always with cars/engines, anything is possible but he V6 is a great motor and last a long time. If the motor has any flaws the boost will expose it much quicker.
  4. May 17, 2017 at 5:53 AM
    H-townTaco
    1998 Tacoma 4x4
    Plain Jane for now
    Ok cool, i know the only person who bought it from the showroom and he was always good on maintenance, I'm going to change all the fluids and see whats what under the hood to make sure nothing leaking but he never went off roading, the axle broke because he hit a curb or something to not hit someone wh
    o was walking on the road
  5. May 17, 2017 at 9:19 AM
    Clay_916
    Clay_916 Well-Known Member
    Fort Collins, CO
    2000 x-cab 4x4
    5100's, All Pro 3" Standard leafs, 32" KM 2's
    Just do it bro.
    boostedka and PROseur like this.
  6. May 17, 2017 at 9:21 AM
    boostedka
    boostedka Well-Known Member
    James
    NM
    2013 DCSB 6MT, 2004 4runner
    You'll be fine as long at your fuel system is nice and clean. With that high of miles you should put a new fuel filter in as well as looking to either have your injectors cleaned and flow tested or just buy new injectors. This will make a huge difference in your spray pattern and fueling efficiency.
  7. May 17, 2017 at 9:24 AM
    eon_blue
    Azusa, CA
    Do it but do it right as suggested. I've been running mine since I bought it last year without the 7th injector kit but the pinging under moderate to high boost has driven me mad. I ordered the 7th injector kit today actually, should have it on in the next few weeks if all goes according to plan. Boost 'aint cheap that's for sure.
  8. May 17, 2017 at 9:27 AM
    lawless
    lawless the rent is too damn high
    Lawson
    San Jose, CA
    2012 dcsb mgm sc
    Highest mileage when adding boost? Good for TW props to be sure.
  9. May 17, 2017 at 9:36 AM
    vasinvictor
    vasinvictor Junkie
    Drew
    Arkansas
    '01 DCSB racetruck
    hx35 turbo, AEM F/IC, Transgo, custom converter, CalTracs, Elocker, 2-4" drop, 4x4 conversion (2023) on a new purple powdercoated fram, 255/55r18 street, 255/60r16 M&H Racemasters, 7.6 at 91
    Turbo'd 3 5vz at 250k+ and only sold when I got bored of them. No real long term testing though. I've bent or broken rods in 2 motors (no fuel management except methanol injection) and torn them apart and observed perfect rod bearings and crosshatching in cylinder walls. I wouldn't be afraid to boost it.
  10. May 17, 2017 at 9:56 AM
    Clay_916
    Fort Collins, CO
    2000 x-cab 4x4
    I honestly wouldn't recommend the 7th injector. Hate to bash on URD since they are a great company overall but that product is a pretty haphazard and expensive way to fix the issues IMO.
    boostedka and vasinvictor like this.
  11. May 17, 2017 at 10:02 AM
    boostedka
    James
    NM
    I agree with this. I had a 7th on a S/C 3.4 I had a few years back and it wasn't all that great and was a pain to tune since you have to upload the changes each time instead of seeing live changes. If I was to tune to more boost, I'd use a FIC or Megasquirt and either the stock or slightly larger than stock injectors.
    Clay_916[QUOTED] and vasinvictor like this.
  12. May 17, 2017 at 10:06 AM
    vasinvictor
    vasinvictor Junkie
    Drew
    Arkansas
    '01 DCSB racetruck
    AEM F/IC $380 and 440-550cc/min injectors $250. Profit.
    boostedka[QUOTED] and Clay_916 like this.
  13. May 17, 2017 at 11:03 PM
    Tacofire98
    Tacofire98 Well-Known Member
    Jake
    Castle Rock
    01 TRD
    Going along with this, I'm going to be throwing a s/c on my 01 with 475k this summer. Engine is totally fine, no sign of wear at all. My only concern is blowing out a head gasket. I'll do a compression check before putting it on but would it be a good idea to do HG before installing the S/C? Or any other pm?
    Also if you guys don't think the 7th injector is worth it, would y'all recommend just larger injectors and an aftermarket ecu?
