Supercharger Quick Change Pulley
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 12TRDTacoma, Jun 21, 2017.
  1. Jun 23, 2017 at 8:16 PM
    #41
    SonnyBones
    SonnyBones I VOID WARRANTIES
    Jeffery
    2015 TACOMA ACCESS CAB
    Well I'll take your advice and wait on install until everything is installed on truck. So question is, how do we get these pully's? :)
    1truckdriver likes this.
  2. Jun 23, 2017 at 8:18 PM
    #42
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    Pulleyboys.com > click Qwikchange Pulley kits > M45 pulley kit for GM Cavalier/ Sun Fire. Or search in the search box part number: 5QCK
  3. Jun 23, 2017 at 8:21 PM
    #43
    SonnyBones
    Jeffery
    $150, not a bad price for so much fun!
  4. Jun 23, 2017 at 8:40 PM
    #44
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Check the price for a new pulley without the kit. I'll bet it is even cheaper. ;)
  5. Jun 24, 2017 at 11:21 AM
    #45
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Good to hear it it up and running. May the hooning begin!
    For any one else considering this mod: very worthy! Before going to the smallest pulley or even the 2.8" make sure you have upgraded your fuel pump, and have an AFR gauge.*** Critically important as you up the boost. If you live in a truly hot state, subsequent other complementing mods for tuning or cooling may be necessary as well.
  6. Jun 24, 2017 at 11:21 AM
    #46
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
  7. Jun 24, 2017 at 1:03 PM
    #47
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Currently tracking AFR's and making adjustments as necessary if needed. It is still too soon to tell if I am in the overly rich range or not with the pulley, but what's important here is that the setup works, pending adjustments to the idler pulley to the right directly below the supercharger pulley, but as previously stated, that is secondary as the belt still fully rides entirely on it, just on the edge of where it ends.
    I would say be careful choosing proper pulley size, but for those who love tinkering and tuning, the pulleys alone are cheap enough and easy enough to swap out with this setup, so swap it out daily if you please or every hour if you are really that bored. :D No more BS with this setup! Remove belt, remove 5 Allen bolts, remove, and swap, reinstall belt, bank.
    I cannot reiterate enough that at minimum what will be needed with the setup in order to properly monitor running conditions will be an AFR gauge. VERY IMPORTANT! The fuel pump upgrade should be performed as well. These mods at minimum will put you in a much better position to play around with your new setup.
    Enjoy folks! Please quote me or message me if you have any other questions.
    Again, if there is enough interest here, I will push for a group buy.
  8. Jun 24, 2017 at 1:53 PM
    #48
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
  9. Jun 24, 2017 at 1:58 PM
    #49
    12TRDTacoma
    Rob
    Concordia
    Boosted
    He'll probably really enjoy this mod. :D
  10. Jun 25, 2017 at 12:04 PM
    #50
    TRON
    TRON Well-Known Member
    All Wheel Drive X-runner
    TRD Blower, 2.3 Pulley, NST OverDrive Pulley Kit, B&M Shifter, TR Lowering Kit, Spec Clutch, Xrunner Body Kit
    Wow it apparently fits! I'm curious why your 2.5 is only getting 9.5 lbs at sea level. Seems low regardless of the 90 degrees especially since you have all 4 of your cats right? If you don't have headers then where is your AFR gauge sensor? So how lean are you at wot? Cheers
    Xionation and 12TRDTacoma[OP] like this.
  11. Jun 25, 2017 at 12:11 PM
    #51
    12TRDTacoma
    Rob
    Concordia
    Boosted
    AFR sensor is where the Y joins. It is low, I agree though I haven't driven the car much so testing has been slow. My restriction is at the Y pipe, so I'll need to mod that out, but apparently, that is actually supposed to drop boost because there is then less retriction for the actual amount of boost to flow through. I just saw it hit 10.x PSI on the boost gauge this morning actually, but in reality I had a safeguard in place until I had the chance to properly test it out. I was running at like 10.5 afr and sometimes even dropping in the 9's air. The air fuel ratio was pretty unstable up today so needless to say, my cylinders were consistently getting washed down with gas. Better than lean though.
    I removed that safeguard a while ago, retested it, and am now at a consistent 11.6-11.8/1 AFR at WOT at all times now. Perfect. :)
    Xionation likes this.
  12. Jun 25, 2017 at 12:26 PM
    #52
    SUMOTNK
    SUMOTNK Pavement Pounder / Mall Crawler
    Eddie
    NorCal/South Bay Area
    Looks like a Gen2.5 TRD Sport, but really an '08 TRD OffRoad
    TRD Supercharged / OTT Tuned
    9.5lbs with the 2.5" at sea level is AWESOME! I've only seen 7lbs with my 2.85" (+mods) at the same altitude.
    thx @12TRDTacoma for doing all the legwork (R&D) on this mod. Something tells me there might be a rash of used URD 2.85" pullies for sale soon!
  13. Jun 25, 2017 at 12:30 PM
    #53
    12TRDTacoma
    Rob
    Concordia
    Boosted
    10lbs as of right now ;) the number is soon to climb more I'm sure.
    Speaking of which, anyone want to buy a used 2.85 press on style URD stealth pulley?
    :D
    The newest problem I have right now is that I picked up so much more notable power out of it, (It even shows when I'm passing someone on the freeway when I dust them by car lengths) that I want to race everyone now. Shoot. Lol.
    Xionation and BassAckwards like this.
  14. Jun 25, 2017 at 2:11 PM
    #54
    TRON
    Having multiple cats up stream from afr sensor makes for inaccurate readings.
  15. Jun 25, 2017 at 2:15 PM
    #55
    12TRDTacoma
    Rob
    Concordia
    Boosted
    So I'm aware, but not horribly inaccurate. I'll check my readings at the AFR's with my scanner as well as fuel trims, but I'm confident things are within great range.
  16. Jun 25, 2017 at 5:03 PM
    #56
    BillDaCat8
    BillDaCat8 Well-Known Member
    Jake
    PHX
    07 4x4 Access Cab M/T
    My shit is all stock.
    I'm in for that!
  17. Jun 25, 2017 at 5:25 PM
    #57
    1truckdriver
    1truckdriver BRO
    Daniel
    Rancho Cucamonga, Ca.
    '15 DCSB Off Road 4x4 SuperWhite
    TRD SuperCharger SCS Rays 10
    x2
  18. Jun 26, 2017 at 6:45 AM
    #58
    MaK10-XRnR
    MaK10-XRnR Member
    2010 Toyota Tacoma XRunner. SWB, Fully Loaded TRD w/ Blower.
    Maybe I missed this, but you can run this 2.5" pulley without any trimming what so ever?
  19. Jun 26, 2017 at 7:30 AM
    #59
    12TRDTacoma
    Rob
    Concordia
    Boosted
    You missed out, like a lot. No you have to trim the snout.
    Also, you need to run a size smaller belt compared to stock. To make up for that half inch lost. I believe I am experiencing slippage because the boost is always a different number.
    You should run a size smaller belt once you go down to a 2.6, and 2.7 is questionable also actually.
    Xionation, Norton and Biscuits like this.
  20. Jun 26, 2017 at 7:33 AM
    #60
    MaK10-XRnR
    MaK10-XRnR Member
    Awesome,
    Thanks for the clarification, I appreciate it.
