Supercharger - should i keep scangauge.
Discussion in 'Performance and Tuning' started by Amo-cat3, Aug 25, 2011.
  1. Aug 25, 2011 at 11:54 AM
    Amo-cat3
    Amo-cat3 [OP] Wizard Sleeve Master
    Maui, Hawaii
    07 TRD Blown dubcab
    TRD Supercharged 4.0 w/ 2.5" Quick change Pulley, UCON EMS, URD 7th injector, AFE Stage II intake, DT Longtubes, MBRP 2.5" dual exhaust w/ Vibrant Ultra resonator, URD Y-pipe w/ vibrant v-bands (Cat free), Walboro 255 fuel pump, SS Oil catch can, Aeroforce gauges, Icon CDC 2.5 coilover set at 3", 1.5" Wleelers Progressive aal, Light racing uca, 17x8.5 Fuel Anza 4.5" backspace/-6 mm offset, Kelly Safari a/t 265/70/17, scanguage 2, AMP electric steps, bed extender, Low-pro tonneau cover, 20% tinted windows/headlights/taillights, tacoma seat covers, Image dynamic sound system w/ Pinoneer avh3200 head, assrtd stickers................
    The TRD supercharger is in and running top notch now that i have the correct X1 map installed - now i want to have minimal gauges to keep interior less cluttered. I have a scangauge II and monitor A/FR, Intake temp, water temp, and volts as my standard display. I'm definitely going to get a separate wideband and already have an AEM 0-15psi boost gauge ordered. I'm looking at the Aeroforce interceptor but having a hard time justifying to get rid of my $160 scangauge. With the interceptor i can have less gauges (can add 2 additional analog gauges for it to display) and it does what the scangauge can do and more.
    Or,
    I could keep the scangauge and get an aeroforce "analogic" gauge (w/ no obdII parameters) but can hook up 4 additional analog gauges and 2 EGT gauges. I would add the AF/R, oil pressure, fuel pressure, oil temp.
    The one parameter that the interceptor gauge has that stands out is the Tranny temp gauge (don't need separate sensor), however, if i am not towing and as a daily driver with the occasional hard boost/sprint how important is it to monitor tranny temp. This is my decision maker if anyone has some insight to the many options out there.
