Supercharger , tuning etc ..
Discussion in '1st Gen. Tacomas (1995-2004)' started by Wide9five, Mar 27, 2018.
  1. Mar 27, 2018 at 4:47 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    When i did that there were around 200 a pop cheapest prices and then they gave me the wrong one anyways haha
  2. Mar 28, 2018 at 9:09 AM
    ZrowGz
    ZrowGz I'm a n00b.
    SLC, UT
    97 4x4 LT/Cantilever
    @1997tacomav6 <—- this guy did a sweet job on his taco.
    Talked to the methanol injection place although I don’t have a SC, and the benefits come from cooling the air going into the SC to run cooler and have denser air entering than would otherwise be possible. I’m probably wrong in some of this since I don’t have either system installed...
    Sounds like it’ll be a sweet upgrade though! Hope to see a build thread!
    1997tacomav6 likes this.
  3. Mar 31, 2018 at 9:29 AM
    1997tacomav6
    Denver
    Yup, ECU has to be 1997 forward for a TRD supercharger!
  4. Mar 31, 2018 at 12:46 PM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    i had a hard time finding mine. ended up spending $300cdn after tax and shipping.
    i think op will do good with adding a progressive meth kit.
    Dalandser likes this.
  5. Apr 1, 2018 at 2:58 PM
    xcmtb83
    xcmtb83 Well-Known Member
    Iowa
    Is ECU compatibility based on cab configuration at all? I have a '96 V6 regular cab I wouldn't mind boosting but I haven't bothered to track down an ECU. This is partly because I know it will be difficult if it needs to be from a '97 V6 regular cab.
  6. Apr 1, 2018 at 3:09 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    I don't think so. Has more to with changes to the ecu programming and insides changing. They change quite often. Sometimes every 3 months
  7. Apr 1, 2018 at 3:27 PM
    I am Root
    I am Root UID 0
    Root
    I am root
    QMEDJoe, ZrowGz and Dalandser like this.
  8. Apr 1, 2018 at 6:47 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    FIFY :p
    inwood customs likes this.
  9. Apr 1, 2018 at 6:52 PM
    inwood customs
    inwood customs Roaming potato
    Dave
    2006 v6 potato bugTuRD
    K&n, flowmaster, plastidip, chipped, hids, daves
    :rofl:
    Dalandser[QUOTED] likes this.
  10. Apr 1, 2018 at 7:10 PM
    xcmtb83
    Iowa
    In the 1st gens they change that often? Why did you recommend that one part number in particular? Any favorable characteristics to that one?
  11. Apr 1, 2018 at 7:13 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    They do unfortunately - that may be the most readily available one with compatible pin-outs afaik.
  12. Apr 1, 2018 at 7:21 PM
    xcmtb83
    Iowa
    Hey would you be willing to share your ECM part number with me? I have a '96 V6 regular cab with an EGR and I am thinking just in case the ECMs are cab style and or EGR dependent your ECM part number would be best if I decide to boost. Otherwise you could share your vin with me as that would bring up the correct ECM too using Toyota's software. TIA
  13. Apr 1, 2018 at 7:26 PM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    02 Pre Runner supercharged 4cyl
    TRD supercharger , Doug Thorley header , K&N CAI 265/75-16 Toyo open country mud terrain , 15x8 Method Racing wheels , Rancho 3" lift , 4.88 gears , Detroit Locker
    You're going to like that supercharger and power increase . I've got Supercharger on my 4cyl making as much hp as a stock V6 or more . not running a 5th injector set up just upgraded Toyota Supra "Pink" injectors and it runs awesome
    One of the best upgrades for Supercharged motor is by running a header . this helps get all that air out of your motor as fast as possible . I'm running a Doug's Headers Tri Y stepped header design that scavenges the exh out of the motor quickly and efficiently
    Wide9five[QUOTED][OP] likes this.
  14. Apr 1, 2018 at 7:48 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    yeah. They changed them a lot. Pretty interesting when I was doing research on it.
    That part number I have was just the last version really before the 98s and that one changes plugs and wiring completely and is not compatible at all with your current wiring harness.
    The favorable characteristic is that it doesn't pull the timing like the others and works with boost. You'll still need to do fuel mods though.
  15. Apr 1, 2018 at 7:52 PM
    #35
    xcmtb83
    Iowa
    Are the fuel mods required even if you run the stock pulley and all stock exhaust?
  16. Apr 1, 2018 at 7:55 PM
    #36
    Blackdawg
    Monte
    Wyoming/St. Louis
    yes usually depending on your elevation. As you are at a lower elevation Id plan on it. It'll likely ping
  17. Apr 14, 2018 at 12:13 PM
    #37
    Matt83
    Matt83 Well-Known Member
    I'm supercharged and having some sputter/bog issues at wot. I'm watching this thread closely for any helpful info.
  18. Apr 14, 2018 at 12:16 PM
    #38
    CD20H
    CD20H Well-Known Member
    Ben
    North Texas
    2004 Double Cab TRD 4x4 Limited
    Magnuson Kompressor, OME lift kit, JBA Headers, junky Sony radio.
    Because the engine is running lean. The reason for the 7th injector.
  19. Apr 14, 2018 at 3:55 PM
    #39
    1997tacomav6
    Denver
    Explain exactly what’s going on here
  20. Apr 14, 2018 at 8:23 PM
    #40
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    I've never had a problem with running lean on my 4cyl and don't need a 5th injector !!! . I'm running "Pink" Supra 310cc injectors , this set up has been on my truck since almost new
