Supercharger
Discussion in 'Technical Chat' started by ThomasMore66, Jan 14, 2015.
  1. Feb 19, 2015 at 3:23 AM
    #241
    ThomasMore66
    ThomasMore66 [OP] We can't stop here, this is bat country!
    Dallas/Fort Worth & Durango
  2. Feb 19, 2015 at 7:29 AM
    #242
    TXpro4X4
    TXpro4X4 Fuck Cancer!
    Bryan
    Costa Mesa, CA
    2011 TOY
    If i lick this frog will i get a supercharger?:eek:
  3. Feb 19, 2015 at 8:52 AM
    #243
    Sterdog
    Sterdog Offline
    I am Groot
    People's Democratic Republic of Canuckistan
    15 FoST
    No, but you will get AIDS. That's something I guess....
  4. Feb 19, 2015 at 9:05 AM
    #244
    thewarriordinghy
    thewarriordinghy General Lee's Titan
    Ben
    Georgia
    2017 Nissan Titan 4x4
    Temporarily Stock
    Can't forget the herps man.... Easy +100 hp and tourque while broken out!
  5. Feb 19, 2015 at 9:14 AM
    #245
    Sterdog
    Sterdog Offline
    I am Groot
    15 FoST
    Dude, you only get the SuperherpAIDS if you lick the frogs bung hole. Everyone knows that. Beside, at those power levels you'd need to buy a new rear differential to handle all that power whenever you break out and who wants to do that :p.
  6. Feb 19, 2015 at 9:33 AM
    #246
    thewarriordinghy
    Ben
    Georgia
    Temporarily Stock
    Tundra axle swap!
  7. Feb 23, 2015 at 8:55 AM
    #247
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    I think you should just go the Ford route and pipe in some V8 engine sounds through your radio.
  8. Feb 23, 2015 at 8:57 AM
    #248
    Sterdog
    Sterdog Offline
    I am Groot
    15 FoST
    :rofl: Are they still doing that? I know our Ecoboosts don't at work, you can definitely hear the Turbos when you lay into the throttle at all.
  9. Feb 23, 2015 at 9:10 AM
    #249
    VolcomTacoma
    Jeff
    NorCal
    Nonononono I'm saying do that to your potato. They make little blue tooth plug ins that simulate engine noise when you accelerate
  10. Feb 23, 2015 at 9:13 AM
    #250
    VolcomTacoma
    Jeff
    NorCal
  11. Feb 23, 2015 at 9:18 AM
    #251
    Sterdog
    Sterdog Offline
    I am Groot
    15 FoST
    :facepalm:
    This is something that even 16 y/o's think is stupid I hope.
  12. Feb 23, 2015 at 3:41 PM
    #252
    thewarriordinghy
    Ben
    Georgia
    Temporarily Stock
    rocklobster tried to advertise that to me on another forum.... its not a Toyota sound so it aint good enough!
  13. Feb 23, 2015 at 3:53 PM
    #253
    Sterdog
    Sterdog Offline
    I am Groot
    15 FoST
    What about... wait for it... GEARS + BLOWER + SMALLER PULLEY + VALVE BODY UPGRADE = MUTHA' FUCKING WIN!!! I'm just kidding around with the yelling, but that's the path I'm going down.
    I just learned I'm getting a bonus this year :D :D :D.
  14. Feb 23, 2015 at 4:31 PM
    #254
    ThomasMore66
    GTO is faster, hands down. The drama of the Tacoma is epic, especially in 4wd and lifted. Crowd favorite.
  15. Feb 23, 2015 at 6:55 PM
    #255
    ThomasMore66
    I'll run for you.
  16. Feb 24, 2015 at 4:27 AM
    #256
    thewarriordinghy
    Ben
    Georgia
    Temporarily Stock
    it was on Tacoma forum.... I was complaining it wasn't loud enough and you showed this for a solution...
  17. Feb 24, 2015 at 4:04 PM
    #257
    ThomasMore66
  18. Feb 24, 2015 at 5:48 PM
    #258
    ThomasMore66
    U-joints probably don't either.
  19. Feb 25, 2015 at 6:38 PM
    #259
    tacomonazul
    tacomonazul Well-Known Member
    Luis
    SOCAL
    07 DCSB LT/4LINK
    http://www.tacomaworld.com/forum/2nd-gen-builds/227832-my-never-end-build.html
    Just got the refund from fedex, a friend is selling me a complete s/c kit for $2500 used. Its still on his truck running, should I take it or buy new? Is it a good deal?
  20. Feb 25, 2015 at 7:07 PM
    #260
    VolcomTacoma
    Jeff
    NorCal
    Just buy new, bro. Everyone that tries to buy used ends up spending more cash trying to track down all the parts that didn't make it
