Supercharger
Discussion in 'Technical Chat' started by ThomasMore66, Jan 14, 2015.
  1. Feb 25, 2015 at 7:10 PM
    #261
    tacomonazul
    tacomonazul Well-Known Member
    Luis
    SOCAL
    07 DCSB LT/4LINK
    http://www.tacomaworld.com/forum/2nd-gen-builds/227832-my-never-end-build.html
    The guy is local so he'll give me all complete parts and uninstall it from his and install it on mine so I'll be sure it has everything
  2. Feb 25, 2015 at 7:13 PM
    #262
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    Well, if it works like that, then go for it! I'm pretty sure there are some non reusable parts, so research that
  3. Feb 25, 2015 at 7:58 PM
    #263
    ThomasMore66
    ThomasMore66 [OP] We can't stop here, this is bat country!
    Dallas/Fort Worth & Durango
    Best toy ever!
  4. Feb 26, 2015 at 1:04 AM
    #264
    tacomonazul
    Luis
    SOCAL
    07 DCSB LT/4LINK
    What should I service?
  5. Mar 5, 2015 at 6:00 PM
    #265
    ThomasMore66
    Isn't the m90 a screw...been a while since I looked that up.
  6. Mar 5, 2015 at 6:34 PM
    #266
    Doc.SS
    Doc.SS ︻╦╤─
    Frank
    O'side
    T4R SR5
  7. Mar 5, 2015 at 6:52 PM
    #267
    Doc.SS
    Doc.SS ︻╦╤─
    Frank
    O'side
    T4R SR5
    I can't remember the Australian company that makes a replacement for a lot of eaton products.
  8. Mar 5, 2015 at 6:57 PM
    #268
    VolcomTacoma
    Jeff
    NorCal
    What exactly happens when you 'port' a Supercharger? for $700 for a 10% boost I'm curious.
  9. Mar 5, 2015 at 6:58 PM
    #269
    Doc.SS
    Doc.SS ︻╦╤─
    Frank
    O'side
    T4R SR5
    It moves more air, efficiency is the key. They reduce turbulence
  10. Mar 5, 2015 at 7:07 PM
    #270
    VolcomTacoma
    Jeff
    NorCal
    Interesting.
  11. Mar 5, 2015 at 7:31 PM
    #271
    ThomasMore66
    I found somebody to weld on a bung for my afr gauge. Now I need to get back to picking gauges. Then I'll be ready for the pulley. Tell me more about porting.
  12. Mar 5, 2015 at 8:26 PM
    #272
    VolcomTacoma
    Jeff
    NorCal
    What are the downsides to this? -700$ ?
  13. Mar 5, 2015 at 9:19 PM
    #273
    VolcomTacoma
    Jeff
    NorCal
    Hmmm, might be worth sending off since mine is still in the box sitting in the garage...
  14. Mar 5, 2015 at 9:37 PM
    #274
    VolcomTacoma
    Jeff
    NorCal
    Yea this Union strike set my buying a new truck back by about a year. so that gives me more time to get parts and stuff fabbed how I want it lol. Then I can find the perfect truck and drop it off immediately at a fab shop
  15. Mar 5, 2015 at 10:43 PM
    #275
    VolcomTacoma
    Jeff
    NorCal
    Haha. Nah, hoping to have camburg front and rear and all shocks bought and all gussets ready to burn in so I'll only have to pay for labor.
  16. Mar 6, 2015 at 2:39 AM
    #276
    thewarriordinghy
    thewarriordinghy General Lee's Titan
    Ben
    Georgia
    2017 Nissan Titan 4x4
    Temporarily Stock
    do they make a full s/c?
  17. Mar 6, 2015 at 5:41 AM
    #277
    Doc.SS
    Doc.SS ︻╦╤─
    Frank
    O'side
    T4R SR5
    It's Harrop TVS and for some reason I can't find squat for them. Maybe it's my phone. I had a supercharged cobalt and they made a replacement. I believe they make Eaton replacements, but I can't find anything . They aren't cheap though.
  18. Mar 6, 2015 at 5:43 AM
    #278
    Doc.SS
    Doc.SS ︻╦╤─
    Frank
    O'side
    T4R SR5
  19. Mar 6, 2015 at 8:15 AM
    #279
    Sterdog
    Sterdog Offline
    I am Groot
    People's Democratic Republic of Canuckistan
    15 FoST
    So is someone gutting there S/C to better internals? Sorry I've missed this page for a while. Wouldn't a smaller pulley and some tuning be a simpler means to the same end? Or do both...
  20. Mar 6, 2015 at 9:04 AM
    #280
    VolcomTacoma
    Jeff
    NorCal
    I'm considering getting mine ported, AND a smaller pulley...could be fun :)
