Supercharger
Discussion in 'Technical Chat' started by ThomasMore66, Jan 14, 2015.
  1. Jun 17, 2015 at 4:13 PM
    #361
    ThomasMore66
    ThomasMore66 [OP] We can't stop here, this is bat country!
    Dallas/Fort Worth & Durango
  2. Jun 17, 2015 at 4:46 PM
    #362
    ThomasMore66
    I think my truck just went up in value.
  3. Jun 18, 2015 at 7:18 AM
    #363
    Sterdog
    Sterdog Offline
    I am Groot
    People's Democratic Republic of Canuckistan
    15 FoST
    That's an impressive potato.
    Lord Helmet likes this.
  4. Jun 18, 2015 at 7:51 AM
    #364
    AK 08TACO
    AK 08TACO Well-Known Member
    Kyle
    Wasilla, AK
    That's seems pretty good! Anyone dyno Theirs beforehand to see what they were making?
  5. Jun 18, 2015 at 7:58 AM
    #365
    AK 08TACO
    Kyle
    Wasilla, AK
    Yeah I was thinking 190ish too, I think 20% seems about right?
  6. Jun 22, 2015 at 1:42 PM
    #366
    ThomasMore66
    I want to revisit the CAI on the 2013+ engines. Why does Toyota think I'll lean out? Is this a real concern?
  7. Jun 22, 2015 at 1:54 PM
    #367
    Sterdog
    Sterdog Offline
    I am Groot
    15 FoST
    The supercharger has a very fat open loop mixture programmed in so that Toyota doesn't have to worry about anyone blowing their engines with it on in stock form. Anything that could lean out that mixture is a good thing but bad by Toyota's book.
  8. Jun 22, 2015 at 2:45 PM
    #368
    ThomasMore66
    Let's assume I finally get the AFR installed (I do have an Ultragauge and I'm always watching the lambda and it seems close to 1 most of the time except on deceleration), what reading is too lean? I don't know that I've ever seen anything greater than 1.2 or less than 0.85. So, 0.85*14.7 = 12.4. On decel it might say 1.2 for an instant which would be 17.64, but that's under zero load. Under load it's never over 1. I made a long pull on a grade the other day in OK running 85-90 and it just hung out at 0.85. Gas gauge was probably moving the entire time.
    Edit: I fixed my Ultragauge on lambda all the way home from work. OMG! I never appreciated how rich the mix is. I see an AFE intake in my future.
  9. Jun 23, 2015 at 10:14 PM
    #369
    ThomasMore66
    Dude, it's rich all the time! You kept saying that but I was letting the pages scroll and only saw lambda part of the time. I froze the page and it's always rich under acceleration. Time for an AFE CAI.
  10. Jul 8, 2015 at 11:10 PM
    #370
    Taco Suave
    Taco Suave Taco Fever
    Griffin
    Oxnard
    2012 TRD Off Road
    Go fast stuff
    So if i were to buy a fit kit from the dealer before their gone and buy a supercharger used would I have all the parts I need? Or are there parts that come with the supercharger that are hard to find too?
  11. Jul 9, 2015 at 10:05 AM
    #371
    Taco Suave
    Griffin
    Oxnard
    2012 TRD Off Road
    Go fast stuff
    Ok thanks, that's what I figured but I just couldn't find a definite answer.
  12. Jul 9, 2015 at 9:42 PM
    #372
    ThomasMore66
    Gadget says the AFE works fine. I really need to let my checkbook cool off...
  13. Jul 9, 2015 at 9:47 PM
    #373
    1truckdriver
    1truckdriver BRO
    Daniel
    Rancho Cucamonga, Ca.
    '15 DCSB Off Road 4x4 SuperWhite
    TRD SuperCharger SCS Rays 10
    Don't know if you posted this yet, but have you done the smaller pulley yet?
  14. Jul 9, 2015 at 9:55 PM
    #374
    preybird1
    preybird1 02 taco on 37's
    Russ
    Salt lake city Utah
    2002 taco s\c
    Trd S\C with nosecone hybrid bearing upgrade kit. 2.0 urd pulley, 7th injector kit-urd "6 fabtech lift with 3" body lift. 20" XD spy wheels with toyo open country r\t's in 37"x 12.50x20. Front and rear diffs re-geared to 4.88 dirty 30 drive axles. and a rhino pack clutch. Custom exhaust and huge mudflaps!
    No toyota announced on June 26th that all superchargers will cease as of this date. There words: The supercharger program for toyota has ended and will no longer be available on vehicles after 2015..............I dont know if im down with a non supercharged modified "OTTO" engine Thats going to be expensive if it breaks direct port dual fuel injection and VVT yeah ill be watching from far away!
  15. Jul 10, 2015 at 3:01 AM
    #375
    ThomasMore66
    Not yet. So many things I want to do. What I need to do is finish the projects that are still in the garage. Brand new set of retros been sitting out there for weeks.
  16. Jul 15, 2015 at 9:48 PM
    #376
    Sterdog
    Sterdog Offline
    I am Groot
    15 FoST
    Mine does :notsure:
    I have the newer second generation volant intake and base model redline hood struts.
  17. Jul 16, 2015 at 3:44 PM
    #377
    Sterdog
    Sterdog Offline
    I am Groot
    15 FoST
    Hmm I'll check mine tonight when I get home from my trip but mine fit fine :notsure:
  18. Jul 19, 2015 at 11:42 PM
    #378
    Taco Suave
    Griffin
    Oxnard
    2012 TRD Off Road
    Go fast stuff
    So I ended up getting a SC installed last week:woot:
    So after a trip up to mammoth and about 700 miles of driving I believe my idle is acting weird. I my truck is a manual btw. So what happens is after accelerating in any gear up to about 2.5k or higher and put in the clutch, the RPMs go down to idle, as they should, and then go back up to almost 2k and then back down to idle. It goes up and down several times, depending on how high the RPMs were when I let it go. It's almost like it's slowly bouncing back down to idle. Sorry for the bad description but it's kind of hard to describe. Anyone else experience anything like this? I'm almost certain it did not do this before. Any help would be great!
  19. Jul 20, 2015 at 3:46 AM
    #379
    Blacktaco2042
    Blacktaco2042 Well-Known Member
    wisconsin
    supercharger/trd cat back 3inch lift 265/75/16 duratracs bumper guard led bar
    sounds like a vacuum leak somewhere. you should take it back and see what is leaking
    12TRDTacoma likes this.
  20. Jul 20, 2015 at 4:13 AM
    #380
    ThomasMore66
    That was exactly my thought. Surging is often linked to vac leaks.
