Supercharger
Discussion in 'Technical Chat' started by ThomasMore66, Jan 14, 2015.
  1. Sep 30, 2015 at 12:53 PM
    #441
    ThomasMore66
    ThomasMore66 [OP] We can't stop here, this is bat country!
    Dallas/Fort Worth & Durango
    Lots of us could afford more and choose to drive a Tacoma. I just like trucks and I like trucks that can move.
  2. Sep 30, 2015 at 1:48 PM
    #442
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    Pretty much this.
  3. Sep 30, 2015 at 6:30 PM
    #443
    ThomasMore66
    They're like the same price in my world.
  4. Oct 1, 2015 at 7:20 PM
    #444
    ThomasMore66
    "Availability" thread is going to hell.
  5. Oct 1, 2015 at 8:03 PM
    #445
    VolcomTacoma
    Jeff
    NorCal
    Ok, these threads are worthless now, Magnuson is re-releasing the superchargers unbranded as TRD.
  6. Oct 1, 2015 at 8:09 PM
    #446
    Lord Helmet
    Lord Helmet Prepare To Attack
    Nick
    '24 X3 M40i
    Link?
  7. Oct 1, 2015 at 8:11 PM
    #447
    VolcomTacoma
    Jeff
    NorCal
    Google? They are releasing the 3.4 SC's soon, the 4.0's should be right behind that.
    I'm guessing right around the Toyota price though...3.4 is at LCE for $3000, So I'm betting the 4.0 SC will be around $3500-$4500
    GreyWolfGhost likes this.
  8. Oct 1, 2015 at 8:14 PM
    #448
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
  9. Oct 1, 2015 at 8:20 PM
    #449
    tacomatrd22
    tacomatrd22 TRD SuperCharged Tacoma
    Daniel
    Fort Smith, AR
    Supercharged tacoma
    FlowMaster Super 44 2" lift Gray wire Fog light
    It looks so weird without the TRD badge on top of it. A sticker can always help that :rolleyes:
  10. Oct 2, 2015 at 3:37 AM
    #450
    ThomasMore66
    I'm not surprised. It only made financial sense for Magnuson to step into the void. Might also free up some new/different parts.
  11. Oct 2, 2015 at 10:34 AM
    #451
    armyoffoo
    armyoffoo Scrotie McBoogerballs
    Houston, TX
    2018 Tundra CM TRD Sport
    Here is an Email I got from LCE performance, maybe they can get a hold of the 1grfe superchargers and fit kits as well, doesn't specifically mention them.
    Unless you live on another planet, you most likely heard that Toyota Japan has
    killed the TRD supercharger program, upsetting Toyota owners and sky-rocketing
    the prices of the few available units.
    Toyota contracted Magnuson to build the entire TRD Supercharger line,
    and as of recent, Maguson purchased all rights to produce
    the same units once again. LCE as Magnuson dealers, tracked down the superchargers straight
    from the source. We are happy to annouce the comeback of these awesome superchargers.
    The Magnuson Supercharger is the exact same unit as the "TRD" Supercharger internally,
    just without the TRD boss on the casting (for obvious reasons) and a slightly updated exterior.
    Installation and maintenance are the same and they are backed up by years of experience from
    one of the most reputable companies around.
    Magnuson is also adding a bit more bang for your buck by introducing a
    3 year/30,000 mile warranty on the charger itself!
  12. Oct 2, 2015 at 10:43 AM
    #452
    VolcomTacoma
    Jeff
    NorCal
    I wish magnuson was improving on the design a bit for more HP. I asked David at Magnuson chargers about a different SC for our trucks with more hp, and he said nope. They add hundreds of HP to other vehicles and 60 to ours lol. Hopefully URD gets that ECU harness done soon so I can get a UCON hooked up and see where it puts me. In retrospect, the URD SC is putting out good numbers because of the additional supporting mods as well as tuneability. I'm betting with UCON, 7th injector and water/meth injection, and the 2.7 pulley, i could easily pull 350+ to the wheels
  13. Oct 2, 2015 at 10:46 AM
    #453
    armyoffoo
    Houston, TX
    As soon as URD puts out their UCON for 2012+, I'll be buying one with the 7th also. Then hopefully will be upgrading to URD blower in February.
  14. Oct 2, 2015 at 10:54 AM
    #454
    VolcomTacoma
    Jeff
    NorCal
    Yuuuuuup. Ill at least be getting a UCON to start
  15. Oct 8, 2015 at 1:31 AM
    #455
    chooch
    chooch Member
    Josh
    2009 Pre-Runner TRD Sport
  16. Oct 11, 2015 at 6:28 AM
    #456
    ThomasMore66
    We Ned a group buy on gauges. Probably not enough interest, but I still haven't purchased mine.
    GT7 likes this.
  17. Oct 11, 2015 at 1:05 PM
    #457
    VolcomTacoma
    Jeff
    NorCal
    You realize they are working on CARB approval as we speak? I don't imagine they will get turned down since they were CARB approved when they were sold through Toyota, yet still manufactured through Magnuson....so now that Magnuson is selling on their own...I see no issues.
    GreyWolfGhost and nfs257 like this.
  18. Oct 12, 2015 at 5:14 PM
    #458
    ThomasMore66
    Spent the weekend in Boston sans truck. Very cool town, but it felt good to feel some boost and here the whine today.
  19. Oct 12, 2015 at 8:22 PM
    #459
    VolcomTacoma
    Jeff
    NorCal
    Go look on Magnuson's website, all of their blowers are 50 state carb legal. I highly highly doubt it won't be carb legal.
  20. Oct 12, 2015 at 8:30 PM
    #460
    VolcomTacoma
    Jeff
    NorCal
    yea, that one's clearly for racing. Anyways, when you're done trolling, we all know it's gonna be carb legal.
