Supercharger
Discussion in 'Technical Chat' started by ThomasMore66, Jan 14, 2015.
  1. Oct 12, 2015 at 10:39 PM
    #461
    Lord Helmet
    Lord Helmet Prepare To Attack
    Nick
    '24 X3 M40i
    :laugh:
  2. Oct 13, 2015 at 8:11 AM
    #462
    snowmanwithahat
    snowmanwithahat Well-Known Member
    2013 Spruce Mica DCSB, TRD OR, V6, Auto
    Must suck to live in a state with those restrictions... Michigan might suck for a lot of things but vehicle laws are not one of them.
  3. Oct 13, 2015 at 10:54 AM
    #463
    snowmanwithahat
    Think big picture, not just a supercharger on a taco.
    I really enjoy the ability to have an open-air BOV on my cars, or a catless setup to hear the turbos purr. Straight piped V8s or a catless V8 with a flowmaster. The small percentage of people who modify vehicles as projects, toys, for fun, whatever... they won't be the straw that breaks the camel's back when it comes to pollution.
    Don't worry though, our non-emissions inspection freedom is definitely not worth the salt we have to endure in the winter. You're not missing out.
  4. Oct 17, 2015 at 8:29 AM
    #464
    GT7
    GT7 One piece at a time
    Grant
    Phoenix
    2013 DCLB
    Did anyone have a problem with a aftermarket bumper and the intercooler pump?
  5. Oct 17, 2015 at 8:42 AM
    #465
    ThomasMore66
    ThomasMore66 [OP] We can't stop here, this is bat country!
    Dallas/Fort Worth & Durango
    I've wondered this too.
    GT7[QUOTED] likes this.
  6. Oct 17, 2015 at 10:05 AM
    #466
    Sterdog
    Sterdog Offline
    I am Groot
    People's Democratic Republic of Canuckistan
    15 FoST
    Yes, I had problems fitting my winch in with the pump. I ended up building a plate and lightly bolting in the pump, I was only able to get one bolt down from the pump to the plate, as well as securing it with some heavy zip ties just in case. Not ideal, but it's held together fine.
  7. Oct 17, 2015 at 3:14 PM
    #467
    ThomasMore66
    What bumper?
  8. Oct 17, 2015 at 5:22 PM
    #468
    Sterdog
    Sterdog Offline
    I am Groot
    15 FoST
    usoffroad hidden winch mount
  9. Oct 17, 2015 at 5:27 PM
    #469
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Good data point, I was actually looking at that one. What winch are you running?
  10. Oct 17, 2015 at 6:10 PM
    #470
    Sterdog
    Sterdog Offline
    I am Groot
    15 FoST
    Superwinch LS8500. It's actually a fairly small winch and fits well other than with the S/C pump. To be honest, the pump is literally right where the winch is supposed to go, so no matter what winch you use it's not go to fit there without modifications on the pump mounts with that bumper installed.
  11. Oct 18, 2015 at 1:46 AM
    #471
    ThomasMore66
    You mean this? https://www.usoffroad.us/2012-2015-tacoma-version-2-0/
  12. Oct 18, 2015 at 7:55 AM
    #472
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Sterdog likes this.
  13. Oct 18, 2015 at 9:54 AM
    #473
    Sterdog
    Sterdog Offline
    I am Groot
    15 FoST
    Yup that's the one
  14. Dec 16, 2015 at 9:47 AM
    #474
    68vert
    68vert Well-Known Member
    AZ
    DCSB 4X
    You SC'd guys with boost gauges; just curious how much boost you saw before & after the 2.85 pulley swap? Trying to decide between a 10psi and 15 psi boost gauge.
  15. Dec 16, 2015 at 10:04 AM
    #475
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    go with the 10 PSI gauge. I was seeing about 5.5-6.5 depending on temps pre pulley, and now I see 8 if its 40 degrees outside and Im about to hit redline in 4th lol. You could probably go with the 2.7 pulley and still mever max out the 10 psi gauge. Its a bitch trying to see if im at 7.5 or 8 when im punching it sometimes lol with my 15 psi gauge
    68vert[QUOTED] likes this.
  16. Dec 16, 2015 at 10:28 AM
    #476
    68vert
    AZ
    DCSB 4X
    Thank you Volcom. That's exactly the info i was looking for. Was the 2.8 pulley hard to put on?
  17. Dec 16, 2015 at 10:32 AM
    #477
    VolcomTacoma
    Jeff
    NorCal
    Not at all. Get the tool URD supplies, have 2 people. Get a good pulley pulling tool, that part takes a few minutes. Pop your new pulley in the oven before all else, its not gonna melt. Once the old one is off, clean up the snout, throw a little oil on it, have one guy standing by with tools, ensure you both know your job! I pulled the pulley out of the oven, threw the strap wrench on it asap, and put in place, Rob had the pulley tool in hand for me, I started getting the pulley on while he held the strap wrench. We found out its faster if one guy holds the strap wrench and the wrench keeping the pulley tool from turning while you turn the wrench pushing the pulley on. From oven to done was about 2-3 minutes lol
    68vert likes this.
  18. Dec 16, 2015 at 10:33 AM
    #478
    VolcomTacoma
    Jeff
    NorCal
    Doing it yourself would be a serious bitch, i highly recommend an extra set of hands
  19. Dec 16, 2015 at 12:03 PM
    #479
    68vert
    AZ
    DCSB 4X
    K, gotcha. I just read one or 2 horror stories about a member getting his SC snout messed up while trying to remove the pulley. But I also read various problems with the SC install and mine went fairly smooth other than searching for flying bolts.
    Oh, BTW just called speedhut and had em change my boost gauge from 15 to 10psi.
    Greatful for the first hand info. Thanks again.
  20. Dec 16, 2015 at 12:11 PM
    #480
    68vert
    AZ
    DCSB 4X
    My VSC bracket hit the SC also so I had to rework it plus made a couple custom brackets to relocate the SC coolant reservoir so I can keep my catch can in the current location as it conveniently drains through the inner fenderwell.
