Supercharger
Discussion in 'Technical Chat' started by ThomasMore66, Jan 14, 2015.
  1. Jan 17, 2015 at 10:29 PM
    #101
    Lord Helmet
    Lord Helmet Prepare To Attack
    Nick
    '24 X3 M40i
    That sounds like the direction I'm going on the performance side. Suspension upgrade is next after that. :cheers:
  2. Jan 17, 2015 at 10:52 PM
    #102
    Lord Helmet
    Nick
    '24 X3 M40i
    It'll be good if you ever put it in a muscle car that's getting boost.
  3. Jan 17, 2015 at 11:12 PM
    #103
    ThomasMore66
    ThomasMore66 [OP] We can't stop here, this is bat country!
    Dallas/Fort Worth & Durango
    Meanwhile, back to my question about how hard is the 2.85 install...
  4. Jan 18, 2015 at 4:51 AM
    #104
    thewarriordinghy
    thewarriordinghy General Lee's Titan
    Ben
    Georgia
    2017 Nissan Titan 4x4
    Temporarily Stock
    ask gadget?
  5. Jan 18, 2015 at 6:58 AM
    #105
    ThomasMore66
    Back before you guys went all crash-test, I had asked how hard the install is. Since I let the dealer install the SC, I didn't have the opportunity to go through the belt install process. Seems like it ought to be fairly easy, but after staring at the pulleys last night I'm not sure which one to loosen to take tension off the belt.
  6. Jan 18, 2015 at 7:16 AM
    #106
    CleanupBoss
    CleanupBoss Well-Known Member
    Chet
    Sparks, NV
    SR 5 with Leer shell
    S/C w/ Gibson exhaust Araid CAI, afr/boost gauges in Craven Speed mount, LED camper shell lighting kit clear bra, fogs, Leer shell w/keyless entry & Thule roof rack system Pop & Lock tailgate handle Rugged country 30" light bar for lower front bumper, Baja Designs SR2 flush mount rear bumper lights, DB Customz grill w/ 3" cube lights, Viair 2 gal tank, Viar Compressor
  7. Jan 18, 2015 at 7:19 AM
    #107
    Eric NJ
    Eric NJ Well-Known Member
    New Jersey
    How many MPG do you LOSE when going with the supercharger?
  8. Jan 18, 2015 at 7:27 AM
    #108
    trianimal
    trianimal Certified
    TX
    2007 Tacoma TRD Off-Road DC 4x4 BSP
    TRD Supercharger, URD UCONN EMS, URD 2.85 pulley, URD 7th Injector, DTLT Headers, URD Y-Pipe, URD 02 Sensor, Walbro 255 fuel pump, TRD cat-back exhaust, TRD CAI, Donahoe Racing (pre-Icon) 2.5" dia. adj. front & rear resi shocks, All-Pro Offroad 3" rear leafs, All-Pro Offroad U-bolt flip kit, All Pro-Offroad Aluminum Skid Plate, Light Racing UCAs, Tom Woods 1-piece driveshaft, Shrockworks sliders, Avid light bar w/o lower tubes and a pair of Rigid Industries Dually LED Driving lights, Toytec diff drop, Color matched grille, Diaz Devil Horns, Redline hood struts, EZ Down tailgate, Undercover bed cover, 750 watts of sound (JVC, Morrel, Rockford-Fosgate & Infinity), BHLM w/ PIAA 4000K, FLM w/PIAA 4000K, LED interior lights. FN wheels with Toyo Open Country A/T II 285/75R 16 tires
    Just need to buy the install tool and heat the pulley. I did mine several years ago, check out my build/pics
    Good luck and drive safe
  9. Jan 18, 2015 at 7:30 AM
    #109
    trianimal
    trianimal Certified
    TX
    Also check the tension bolts on the idler wheel, use a pry bar and wood block to take tension off the belt
  10. Jan 18, 2015 at 7:31 AM
    #110
    Lord Helmet
    Nick
    '24 X3 M40i
    I don't have the instructions right in front of me but if I remember correctly the tensioner bolt should be right next to the water pump. There should be a slotted bracket this bolt screws into. For the pulley it is recommended you get a HD three teeth pulley puller. Autozone, pep boys, etc... should be able to rent it out for you instead of buying it. for install you could buy that install tool Gadget sells or you can try the heat and freeze method which has been tried before with good results.
  11. Jan 18, 2015 at 8:14 AM
    #111
    WHPLSH3
    WHPLSH3 Fortified with horsepower-adding goodness...
    Vance
    Alberta
    Supercharged Spruce Mica 6spd 4x4
    Build thread coming soon!
    I can't speak for everyone, but my mileage stayed the same. I don't drive it balls to the wall all the time either though. The extra little bit that these engines are short when climbing a long grade or towing something reasonably heavy is where it really helps.
    Best investment ever! :burnrubber:
  12. Jan 18, 2015 at 8:51 AM
    #112
    Sterdog
    Sterdog Offline
    I am Groot
    People's Democratic Republic of Canuckistan
    15 FoST
    I do a good mix of highway, gravel, and town driving. I haven't seen much change in mpg with the S/C installed.
    I will say it's critical to heat up that pulley before trying to install it. I've read/heard of some installs that went sideways when people did not heat the pulley for long enough. Other than that it seems like a straight forward install if you have the right tools (pry bar, 3 tooth gear puller, and the pulley install tool.)
  13. Jan 18, 2015 at 12:10 PM
    #113
    ThomasMore66
    Looks like heating would make it expand and make it harder to install. I'll have to check out Gadget.
  14. Jan 18, 2015 at 12:46 PM
    #114
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    Lol you want it to expand. The pulley is press fit on the nose cone, so you want the pulley to expand, and shoot some cold stuff on the nose cone (where the pulley mounts...I might be calling it wrong) to make it smaller I E contract, then the pulley will slide on a little easier and when both of them reach ambient temp, they will stay together. Otherwise you're trying to force something with a hole in it, almost the exact same size as pole coming off the SC.
  15. Jan 18, 2015 at 2:30 PM
    #115
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    zero.............its the drivers fault if MPG is lost, the blower has a bypass valve
  16. Jan 18, 2015 at 3:11 PM
    #116
    ThomasMore66
    Hmm. I really like that blower whine. My mileage is down because I have a lot of stop and go. I like the go part.
  17. Jan 18, 2015 at 3:12 PM
    #117
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    I was at just above 300 miles yesterday before my gas light came on, and Im quite hard on the truck
    AFE stage 2 Si makes the whine more prominent
  18. Jan 18, 2015 at 3:13 PM
    #118
    ThomasMore66
    I was thinking it would expand in all directions and the hole would get smaller.
  19. Jan 18, 2015 at 3:14 PM
    #119
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    thats quote worthy right thar :rofl:
  20. Jan 18, 2015 at 3:16 PM
    #120
    ThomasMore66
    Somebody got it!
