SUPERCHARGER???
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tacoman714, Nov 26, 2019.
  1. Nov 28, 2019 at 5:17 PM
    Tacoman714
    Tacoman714 [OP] Member
    Frank
    2014 Tacoma 2.7l double cab
    Did you have it done or did the work yourself
  2. Nov 28, 2019 at 5:32 PM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    buy it real quick and be the tester for the rest of us? :rofl:
  3. Nov 28, 2019 at 5:45 PM
    jowybyo
    jowybyo Well-Known Member
    Joe
    Baltimore, MD
    '14 MGM DCSB Postrunner 4wd Conversion, Debadged
    Did most of it myself. Outsourced a couple things. I chose a complicated path which was probably not ideal. Otherwise, about 90%+ is bolt on. You’re mostly just swapping parts. The hardest part is gathering all the information so you know what needs to be done.
  4. Jan 31, 2021 at 2:40 PM
    Tacoman714
    Frank
    Sorry for the late response but do you by chance have a parts list you could post ? I’ve been searching everywhere and can’t get a straight answer
  5. Jan 31, 2021 at 3:02 PM
    jowybyo
    Joe
    Baltimore, MD
    What answers did you get?
  6. Jan 31, 2021 at 3:04 PM
    Tacoman714
    Frank
    keep finding 4x4 swaps for access cab 4 cyl, and for the v6 double cabs just don’t wanna get thrown off mixing things up I figured better to ask someone who’s done it with the exact same set up
  7. Jan 31, 2021 at 5:08 PM
    jowybyo
    Joe
    Baltimore, MD
    The general parts list is the same. The access cab 4 cyl swap thread will exactly apply to your truck. You can follow that list exactly.
  8. Jan 31, 2021 at 8:46 PM
    Tacoman714
    Frank
    Will the drive shafts work from the access cab on my double cab
  9. Jan 31, 2021 at 8:52 PM
    Tacoman714
    Frank
    And also if I got an fj cruiser transfer case would that eliminate most of the electrical process and it should just bolt on to the 4x4 trans from the 4x4 2tr
  10. Feb 1, 2021 at 4:39 AM
    jowybyo
    Joe
    Baltimore, MD
    I think so. But I’m not sure. It was cheaper and easier for me to have my driveshaft cut down. I think it needs to be 13” shorter. Cost me $125 to have that done.
  11. Feb 1, 2021 at 4:41 AM
    jowybyo
    Joe
    Baltimore, MD
    Yup. You’ll still need to wire a switch to engage the front differential. But that really no harder than wiring up any other accessory like a light bar.
  12. Feb 1, 2021 at 9:43 PM
    Tacoman714
    Frank
    i can’t find a post that fits my need now I’m only running into v6 4x4 swaps. Do you know of any swaps for the I4? would have to get parts from the same year? Sorry for all these questions but I really wanna finally get the wheels rolling on this swap!
  13. Feb 2, 2021 at 4:34 AM
    jowybyo
    Joe
    Baltimore, MD
    The only difference in the swap between the 4-cylinder and the v6 is which transmission model you are getting, the driveshaft lengths, and the gear ratio that’s in the front differential. All the other parts are exactly the same. You don’t need to get parts from the same year but I’d stick to 2012-2015. Though there might be parts from earlier and later years that are interchangeable.
    @Brian422 Can you link your thread on the conversion?
  14. Feb 2, 2021 at 6:06 AM
    Brian422
    Brian422 I fell into the pit that is TW
    Brian
    Birmingham, AL
    2012 DBCSB F/R Locked, 35's ,Long travel, 23 Tundra 4x4 limited
    Not Stock
    https://www.tacomaworld.com/threads/brians-f-r-locked-postrunner-build.610146/page-23#post-24046452
  15. Feb 11, 2021 at 3:13 PM
    #35
    allmotorrex
    allmotorrex Grove St. Fab
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    NWF crawlbox, 5.29s, rear Detriot, front Harrop, 37" SXIIs, 17x9" KMC Grenade Crawl beadlocks, Dirt King 3.5" LT kit with King shocks, Fox 12" smooth body RR, BAMF shock kit, AP 3" springs, ext. brake lines, custom 1 piece driveshaft with .135 wall tubeing, GSF front rock crawling bumper, GSF rear bumper, Relentless Fab ifs skid, BAMF k/o sliders, X2O 10K comp. winch, TP glass fenders, OKled 20"bar, EBS dimpled/slotted rotors, EBS green pads, custom K&N CAI, LCE headers, FM Super 44 w/h turn down, URD MAF, Spec clutch, LCE heavy flywheel, URD short shifter, TMPer M1 Abrams shift knob, Amsoil oil, Cobra 75wxst w/h 4' firestix, Grillcraft, FXR TRS, T1 eyelids, custom ADV Monster 60 lights, bed lights, speedo light mod, Glow Shift volt/oil pres gauges, Glow shift 2g column pod, Optima yellow tops dual battery setup w/h IBS system, Pioneer DEH-P7200HD head unit, Pioneer 600W 4ch & 350w 2ch amps for doors and sub, Wet Oakle covers
    I was interested in the title of this thread but with only 2 pages, 1 being about 4x4 conversion and the other not providing much supercharger info, it's just about useless. :rolleyes: I'd be interested in pricing though as a competition to the URD kit, which isn't exactly cheap.
  16. Apr 3, 2024 at 11:50 AM
    #36
    SteelChinTaco
    SteelChinTaco Active Member
    Priced at $4500 right now on their website, with a 2.7l Tacoma specific kit now I think. I know this is old thread but I came across that s/c recently and it's intriguing
    straitbad01 likes this.
