Superdave's: Lift installs, mechanic, service
Discussion in 'Southern California' started by Superdave1.0, Aug 25, 2020.
  1. Apr 27, 2025 at 8:48 AM
    #461
    1buzzbait
    Murph
    murrilin
    98 yamaha grizzly-09 Primo XL custom cover, D-plates, divider, raised grates
  2. Apr 27, 2025 at 4:02 PM
    #462
    HB Taco
    HB Taco Well-Known Member
    Curt
    Huntington Beach, CA
    2019 F150 FX4 S Crew 3.5 TT
    Damn Dave now I'm hangry! Good thing we already have a couple Rib Eyes set aside for tonight. Might be getting them going sooner then later. :D
  3. Apr 28, 2025 at 4:51 PM
    #463
    cactuscooler8
    cactuscooler8 New Member
    So Dave installed 6112 (front) and 8100 smoothies (back) over the weekend.
    What an incredible job he did installing the parts. He was very detailed oriented and was great to chat with.
    Thanks Dave!
    clenkeit, StayinStock, jackn7 and 6 others like this.
  4. May 3, 2025 at 6:45 PM
    #464
    Superdave1.0
    Superdave1.0 [OP] Grandma Dave
    SoCal
    LX470, 2025 Civic Si
    1st gen Taco over for a sweet mod. Tundra big brake upgrade and stainless brake lines front and back! So cool that the calipers bolt right on, aside from some minor trimming of the dust shield. If I had a 3rd gen 4runner or 1st gen Tacoma I would be doing this.
  5. May 6, 2025 at 8:28 PM
    #465
    Kathya02
    Kathya02 New Member
    Kathya
    2001 grey Tacoma SR5
    Hi Dave,
    I was wondering if I could set up an appointment with you. It seems as if my 2001 Tacoma may need its engine rebuilt…
    Thanks!
    -Kat
  6. May 6, 2025 at 8:33 PM
    #466
    Superdave1.0
    SoCal
    Hello there! I wouldn't do this as a side job. But I will send you a PM with some options to hopefully help you out.
  7. May 6, 2025 at 10:19 PM
    #467
    MGMDesertTaco
    Which wheel studs are these? (last picture)
  8. May 7, 2025 at 8:04 AM
    #468
    Superdave1.0
    SoCal
    The customer had them shipped from Japan.
  9. May 10, 2025 at 5:46 PM
    #469
    mannyhernz
    mannyhernz Well-Known Member
    SoCal
    Had my UCA's and coilovers installed by Dave today...awesome work and knowledgeable guy..detail oriented and great work!
    StayinStock, jackn7, IEsurfer and 3 others like this.
  10. May 11, 2025 at 6:23 PM
    #470
    Superdave1.0
    SoCal
    No problema jefe! Con mucho gusto.
    Was a nice day, thank you for the opportunity and nice set up man!
  11. May 11, 2025 at 6:32 PM
    #471
    Superdave1.0
    SoCal
    2 trucks yesterday. Was 95 degrees here in SoCal. :bananadead:
    20250510_124059.jpg 20250510_173025.jpg 20250510_164508.jpg 20250510_182732.jpg
  12. May 11, 2025 at 8:44 PM
    #472
    xmountaingoatx
    xmountaingoatx Active Member
    2014 Tacoma Regular Cab 2.7L 5MT
    Bilstein 5100s/5160s, ICON RXTs Stage II, 255/85/17 Toyo Open Country ATIII, LCE Header, Hurst Shifter, Tundra front brakes, GFC v2
    Another great job by Dave - 5160s and Icon RXTs Stage 2 on my regular cab 2nd gen. Dave is knows all the tricks to make install a breeze and keep my rig running down the trail smoothly. Got rid of the sag in the rear and picked up a few extra inches, plus the rear end rides so much smoother and tighter on the road and off. Thanks, man!
  13. May 11, 2025 at 10:35 PM
    #473
    IEsurfer
    IEsurfer Well-Known Member
    Socal
    Badass single cab I too used to have a single cab with a gfc that Dave worked on lol
  14. May 18, 2025 at 5:53 PM
    #474
    Superdave1.0
    SoCal
    Got down on this 4runner today. Lots of new parts! LCA's, tie rod ends, CV axle, brake pads and rotors. Was a beautiful day today in SoCal for wrenching. Got rid of the customers shimmy at 50mph!
    20250518_114657.jpg 20250518_112220.jpg 20250518_122726.jpg 20250518_130408.jpg 20250518_160033.jpg 20250518_171248.jpg
    StayinStock, jackn7, IEsurfer and 4 others like this.
  15. May 18, 2025 at 6:07 PM
    #475
    MGMDesertTaco
    Even the floor jack matches. :rofl:
    I should probably order new cam bolts and hardware for my lca swap. Do you load those up with anti seize?
  16. May 18, 2025 at 7:08 PM
    #476
    Superdave1.0
    SoCal
    Anti seize would probably be best. I've been using grease since that's what I've got on hand lately.
    It's always a gamble with the LCA hardware (cam/caster bolts). I've definitely had to cut a few LCA out with a reciprocating saw.
    :sawzall:
    MGMDesertTaco[QUOTED] likes this.
  17. May 18, 2025 at 7:32 PM
    #477
    vivid02
    vivid02 Buy a Tesla…..I need the gas.
    Edwin
    SoCal
    2021 Tacoma TRD Off Road 4x4 DCSB
    OEM+
    Electrical work….does your electrical work include diagnosis on a 2008 Sequoia O2 sensor reading 0 volts ? :D
    It may have been shorted after the cat was stolen and wires cut. Two brand new denso o2 sensors and same, 0 volts.
    I might keep fooling around a bit more since I have until next year for until smog check is due :)
    1buzzbait and Superdave1.0[OP] like this.
  18. May 18, 2025 at 9:29 PM
    #478
    Superdave1.0
    SoCal
    That's a tough one. I'm ok at diag but by no means a master. I do have a fancy snap on scanner that might be able to help. Feel free to come by and I can try to figure it out!
  19. May 24, 2025 at 7:21 PM
    #479
    Superdave1.0
    SoCal
    2nd gen Tacoma over for a steering rack & pinion replacement. Got lucky and the steering was perfectly centered on the first try!
  20. May 31, 2025 at 5:51 PM
    #480
    Superdave1.0
    SoCal
    Single cab 5 lug over for some maintenance! Spark plugs, rear diff fluid and engine oil change. This truck is SUPER clean and has only 50k miles. Im jelly.
    20250531_115922.jpg 20250531_121912.jpg 20250531_122146.jpg 20250531_122329.jpg
    IEsurfer, jackn7, 1buzzbait and 2 others like this.
